nrf_fstorage not working
I am trying to use the **persistent** flash area of my nRF52.
I created a separate zone (PERSISTENT_FLASH) in my LD script as follows:
MEMORY
  FLASH (rx) : ORIGIN = 0x26000, LENGTH = 0x52000
  PERSISTENT_FLASH(rw): ORIGIN = 0x77000, LENGTH = 0x1000
  RAM (rwx) :  ORIGIN = 0x20002bf0, LENGTH = 0xd410
I try the following C code:
#define FSTORAGE_START  0x77000
#define FSTORAGE_LEN    0x01000
void callback(nrf_fstorage_evt_t * p_evt)
  NRF_LOG_DEBUG("callback");
NRF_FSTORAGE_DEF(nrf_fstorage_t my_instance) =
    .evt_handler    = callback,
    .start_addr     = FSTORAGE_START,
    .end_addr       = FSTORAGE_START + FSTORAGE_LEN,
void test_flash()
    ret_code_t rc;
    rc = nrf_fstorage_init(
        &my_instance,       /* You fstorage instance, previously defined. */
        &nrf_fstorage_sd,   /* Name of the backend. */
        NULL                /* Optional parameter, backend-dependant. */
    NRF_LOG_DEBUG("1===> %d %s", rc, nrf_strerror_get(rc));
    char buf_i[] = "1234567890123456";
    rc = nrf_fstorage_write(
        &my_instance,   /* The instance to use. */
        FSTORAGE_START, /* The address in flash where to store the data. */
        buf_i,          /* A pointer to the data. */
        16,             /* Lenght of the data, in bytes. */
        NULL            /* Optional parameter, backend-dependent. */
    NRF_LOG_DEBUG("2===> %d %s", rc, nrf_strerror_get(rc));
    char buf_o[24];
    rc = nrf_fstorage_read(
        FSTORAGE_START,     /* The address in flash where to read data from. */
        buf_o,              /* A buffer to copy the data into. */
        16                  /* Lenght of the data, in bytes. */
    buf_o[16] = '\0';
    NRF_LOG_DEBUG("3===> %d %s `%s'", rc, nrf_strerror_get(rc), buf_o);
I get the following output:
00> <debug> app: 1===> 0 NRF_SUCCESS
00> <debug> app: callback
00> <debug> app: 2===> 0 NRF_SUCCESS
00> <debug> app: 3===> 0 NRF_SUCCESS `'
What am I missing here?
I am using SDK nRF5_SDK_17.0.2_d674dde, with softdevice s132_nrf52_7.2.0_softdevice.hex.
Thanks a lot!
  • HI,
    How do you verify that this doesn't work? did you check the content of the flash? Also did you take a look at the flash_fstorage example in the SDK? And can you check that you are using the correct backend when calling nrf_fstorage_init?
    Did you consider using the Flash Data Storage (FDS) module? that is created as a file system on top of fstorage, and might save you some trouble implementing your own solution.
  • I know this doesn't work because of the last NRF_LOG_DEBUG (line 4 in the last snippet of my original post). As you can see in my post, I init, write, and read. But the last operation doesn't have the expected outcome.
    I considered the FDS, but I only want to write a couple characters, I don't need a whole filesystem for that.
    My code is mostly extracted from the SDK, only smaller. I read the documentation many times and I don't understand what isn't working.
    Thanks for your help.
    I think you might be trying to read the flash content before it is actually written. I think you have to wait for the NRF_FSTORAGE_WRITE_RESULT before you can read it again, see Writing data.
    You could also take a look at the fstorage example in our SDK -> nRF5_SDK_17.1.0_ddde560\nRF5_SDK_17.1.0_ddde560\examples\peripheral\flash_fstorage
