Hi Team,
These are the SDA and SCL lines of nRF52832 connected to a sensor. the clock frequency defined in the code is 400 KHz, but its coming as 200 KHz on oscilloscope. I think this is due to the weak internal pull up resistors. I believe this should improve if we add external pullup resistors.
1) I know that the poor shape of the signals are due to weak internal pullup resistors. Can I ask you if this poor shape can cause reading wrong data ? For the first square (marked red), shows that the data is changing during the rising edge of clock. We are currently reading correct values, but is this prone to errors ?
2) I sometimes notice noise on SDA line as shown in the above figure. Is it okay to notice such spikes during the negative cycle of clock ? Can this cause wrong data ? How can I avoid this ?
