Updating Serial DFU command requires bootloader verify python script to be run before it starts successfully
I am working on NRF52840 DK board, trying to run Mesh DFU example code.
The issue I am facing is that I have to run Bootloader Verify python script before the Serial DFU command every time.
D:\nRF5-SDK-for-Mesh-master\nrf5_SDK_for_Mesh_v5.0.0_src>nrfutil --verbose dfu serial -pkg dfu_test.zip -p COM5 -b 115200 -fc --mesh
Upgrading target on COM5 with DFU package D:\nRF5-SDK-for-Mesh-master\nrf5_SDK_for_Mesh_v5.0.0_src\dfu_test.zip. Flow control is enabled.
Flushing com-port...
Opened com-port
Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0, application size: 129816
Sending DFU start packet, afterwards we wait for the flash on target to be initialized before continuing.
1: PC -> target: 0502aabbccdd
2: PC -> target: 0502aabbccdd
3: PC -> target: 0502aabbccdd
Closing serial port...
Aborted!
D:\nRF5-SDK-for-Mesh-master\nrf5_SDK_for_Mesh_v5.0.0_src>nrfjprog --reset
Applying system reset.
Run.
Opened com-port
Aborted!
D:\nRF5-SDK-for-Mesh-master\nrf5_SDK_for_Mesh_v5.0.0_src>python tools/dfu/bootloader_verify.py 683751236 COM21
Reading UICR..                  OK.
Reading Device page..           OK.
Resetting device..              OK (In application)
Checking serial connection..    OK.
Bootloader verification OK.
Run.
Opened com-port
target -> PC: 0582aabbccdd
Got echo response
Sending DFU init packet
Sending ready packet
1: PC -> target: 1378fdff040f3ed67a6859000000010002000000
target -> PC: 16a6045900000001000200000059000000010001000000
target -> PC: 1378fdff04000000000059000000010002000000
target -> PC: 03847800
    The device is reset as part of the bootloader verification. I suspect there is some issue with the device or bootloader that makes it hang, and the reset during bootloader verification makes it work again. Have you experienced any other issues with the device? Does it seem to work as intended, before / after the failed DFU attempt?
    Terje
  • Hello Terje,
    Working with: nrf5_SDK_for_Mesh_v5.0.0_src AND nRF5_SDK_17.0.2_d674dde using SES
    Boot-loader Verification and reset command required all the time before starting the DFU process In Win10. Today I tried the same process and found that In Ubuntu20 its works without Boot-loader verification some times.
    Yes, Required Boot-loader verification and Reset commands every time DFU fails in Win10.
    Let me know if below issue required new post.
    Now, Another issue after starting DFU is, it stops every time after uploading 33 segments of data. for more details please fine below logs and RTT logs.
    33 Segments of Data: using armcc Boot-loader
    240/more Segments of Data: using gccarmemb Boot-loader
    Serial DFU Log :
    Opened com-port
    Got echo response
    target -> PC: 1378fdff040f3ed67a6859000000010002000000
    Sending start packet
    1: PC -> target: 1478fcff00003ed67a68ffffffffc67e000000000c
    target -> PC: 0da2010459000000010002000000
    Waiting for 4.4 seconds for flash bank erase to complete.
    Sending firmware file
      [------------------------------------]    1%  00:20:301: PC -> target: 1978fcff01003ed67a6800f003206d7302005573020057730200
    1: PC -> target: 1978fcff02003ed67a68597302005b7302005d73020000000000
    1: PC -> target: 1978fcff03003ed67a680000000000000000000000005f730200
    1: PC -> target: 1978fcff04003ed67a6861730200000000006373020065730200
    1: PC -> target: 1978fcff05003ed67a6867730200677302008d1b030067730200
    1: PC -> target: 1978fcff06003ed67a68677302006773020015dc030067730200
    1: PC -> target: 1978fcff07003ed67a686773020067730200c9b2030067730200
    1: PC -> target: 1978fcff08003ed67a6867730200677302006773020067730200
    1: PC -> target: 1978fcff09003ed67a6867730200fd400400edcc020067730200
    1: PC -> target: 1978fcff0a003ed67a686141040067730200addf030067730200
    1: PC -> target: 1978fcff0b003ed67a6867730200677302006773020067730200
    1: PC -> target: 1978fcff0c003ed67a6867730200677302000000000000000000
    1: PC -> target: 1978fcff0d003ed67a6867730200677302006773020067730200
    1: PC -> target: 1978fcff0e003ed67a6867730200677302006773020067730200
    1: PC -> target: 1978fcff0f003ed67a6867730200677302006773020000000000
    1: PC -> target: 1978fcff10003ed67a6800000000677302000000000067730200
    1: PC -> target: 1978fcff11003ed67a6800000000000000000000000000000000
    1: PC -> target: 1978fcff12003ed67a6800000000000000000000000000000000
    1: PC -> target: 1978fcff13003ed67a6800000000000000000000000000000000
    1: PC -> target: 1978fcff14003ed67a6800000000000000000000000000000000
    1: PC -> target: 1978fcff15003ed67a6800000000000000000000000000000000
    1: PC -> target: 1978fcff16003ed67a6800000000000000000000000000000000
    1: PC -> target: 1978fcff17003ed67a6800000000000000000000000000000000
    1: PC -> target: 1978fcff18003ed67a6800000000000000000000000000000000
    1: PC -> target: 1978fcff19003ed67a6800000000000000000000000000000000
    1: PC -> target: 1978fcff1a003ed67a6800000000000000000000000000000000
    1: PC -> target: 1978fcff1b003ed67a6800000000000000000000000000000000
    1: PC -> target: 1978fcff1c003ed67a6800000000000000000000000000000000
    1: PC -> target: 1978fcff1d003ed67a6800000000000000000000000000000000
    1: PC -> target: 1978fcff1e003ed67a6800000000000000000000000000000000
    1: PC -> target: 1978fcff1f003ed67a6800000000000000000000000000000000
    1: PC -> target: 1978fcff20003ed67a6800000000000000000000000000000000
    1: PC -> target: 1978fcff21003ed67a68344935480a1a02d0072291438d463349
    2: PC -> target: 1978fcff21003ed67a68344935480a1a02d0072291438d463349
    3: PC -> target: 1978fcff21003ed67a68344935480a1a02d0072291438d463349
    4: PC -> target: 1978fcff21003ed67a68344935480a1a02d0072291438d463349
    5: PC -> target: 1978fcff21003ed67a68344935480a1a02d0072291438d463349
    6: PC -> target: 1978fcff21003ed67a68344935480a1a02d0072291438d463349
    7: PC -> target: 1978fcff21003ed67a68344935480a1a02d0072291438d463349
    8: PC -> target: 1978fcff21003ed67a68344935480a1a02d0072291438d463349
    9: PC -> target: 1978fcff21003ed67a68344935480a1a02d0072291438d463349
    10: PC -> target: 1978fcff21003ed67a68344935480a1a02d0072291438d463349
    Failed to upgrade target. Error is: Lost connection in the middle of the transfer
    Possible causes:
    - bootloader, SoftDevice or application on target does not match the requirements in the DFU package.
    - baud rate or flow control is not the same as in the target bootloader.
    - target is not in DFU mode. If using the SDK examples, press Button 4 and RESET and release both to enter DFU mode.
    - if the error is ERROR_BUSY at the beginning of the DFU process,increase the value of PAGE_ERASE_TIME_MAX by few milliseconds.
    RTT Device Log :
    00> <t:          3>, main.c,  228, ----- Bluetooth Mesh DFU Example -----
    00> <t:       8756>, nrf_mesh_dfu.c,  753, Version info: BL(ver, id): 0x01 0x01 SD: 0x0100
    00> <t:       8759>, nrf_mesh_dfu.c,  755, Version info: APP company: 0x00000059 id: 0x0001 version: 0x00000001
    00> <t:       8772>, serial_handler_prov.c,  267, Generating encryption keypair...
    00> <t:      13545>, main.c,  234, Initialization complete!
    00> <t:      18213>, main.c,  255, Enabling serial interface...
    00> <t:      18216>, mesh_app_utils.c,   66, Device UUID (raw): 029B2B0326AE408B9DCD1D32796AB396
    00> <t:      18219>, mesh_app_utils.c,   67, Device UUID : 029B2B03-26AE-408B-9DCD-1D32796AB396
    00> <t:      18230>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 0, count 15, interval: periodic, handle: FFFE
    00> <t:      18235>, nrf_mesh_dfu.c,  593,   SERIAL TX (type: 65534)
    00> <t:      18243>, main.c,  263, DFU example started!
    00> <t:      18314>, main.c,  116, mesh_evt_handler >> Entering into [85599]
    00> <t:      18318>, main.c,  116, mesh_evt_handler >> Entering into [199291]
    00> <t:      18324>, main.c,  116, mesh_evt_handler >> Entering into [0]
    00> <t:    1551950>, nrf_mesh_dfu.c,  418,   New firmware!
    00> <t:    1551953>, main.c,  116, mesh_evt_handler >> Entering into
    00> [536888796]
    00> <t:    1551956>, main.c,   79, DFU type Application
    00> <t:    1551959>, main.c,  124, Requesting DFU transfer with bank at 0x0008C000
    00> <t:    1551962>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 0, count 3, interval: periodic, handle: FFFD
    00> <t:    1551966>, nrf_mesh_dfu.c,  565, Killing a TX slot prematurely (repeats done: 5).
    00> <t:    1551970>, nrf_mesh_dfu.c,  593,   SERIAL TX (type: 65533)
    00> <t:    1619610>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 0, count 3, interval: periodic, handle: FFFD
    00> <t:    1619614>, nrf_mesh_dfu.c,  593,   SERIAL TX (type: 65533)
    00> <t:    1686416>, nrf_mesh_dfu.c,  458,   DFU start
    00> <t:    1686418>, main.c,  116, mesh_evt_handler >> Entering into [536888796]
    00> <t:    1686423>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 1, count 6, interval: exponential, handle: FFFC
    00> <t:    1774562>, nrf_mesh_dfu.c,  357, Erase complete (0x8C000)
    00> <t:    1774566>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    1923593>, nrf_mesh_dfu.c,  482,   DFU segment rx: 1/8114
    00> <t:    1923598>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 2, count 3, interval: exponential, handle: FFFC
    00> <t:    1923611>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    1923615>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    1940557>, nrf_mesh_dfu.c,  482,   DFU segment rx: 2/8114
    00> <t:    1940561>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 3, count 3, interval: exponential, handle: FFFC
    00> <t:    1940575>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    1940578>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    1957515>, nrf_mesh_dfu.c,  482,   DFU segment rx: 3/8114
    00> <t:    1957520>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 4, count 3, interval: exponential, handle: FFFC
    00> <t:    1957533>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    1957537>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    1975394>, nrf_mesh_dfu.c,  482,   DFU segment rx: 4/8114
    00> <t:    1975399>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 5, count 3, interval: exponential, handle: FFFC
    00> <t:    1975412>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    1975416>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    1992393>, nrf_mesh_dfu.c,  482,   DFU segment rx: 5/8114
    00> <t:    1992397>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 6, count 3, interval: exponential, handle: FFFC
    00> <t:    1992411>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    1992414>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2009406>, nrf_mesh_dfu.c,  482,   DFU segment rx: 6/8114
    00> <t:    2009411>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 7, count 3, interval: exponential, handle: FFFC
    00> <t:    2009425>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2009428>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2026802>, nrf_mesh_dfu.c,  482,   DFU segment rx: 7/8114
    00> <t:    2026807>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 1, count 3, interval: exponential, handle: FFFC
    00> <t:    2026820>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2026824>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2044224>, nrf_mesh_dfu.c,  482,   DFU segment rx: 8/8114
    00> <t:    2044229>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 2, count 3, interval: exponential, handle: FFFC
    00> <t:    2044242>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2044246>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2061183>, nrf_mesh_dfu.c,  482,   DFU segment rx: 9/8114
    00> <t:    2061187>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 3, count 3, interval: exponential, handle: FFFC
    00> <t:    2061201>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2061204>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2078211>, nrf_mesh_dfu.c,  482,   DFU segment rx: 10/8114
    00> <t:    2078216>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 4, count 3, interval: exponential, handle: FFFC
    00> <t:    2078229>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2078233>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2095620>, nrf_mesh_dfu.c,  482,   DFU segment rx: 11/8114
    00> <t:    2095625>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 5, count 3, interval: exponential, handle: FFFC
    00> <t:    2095638>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2095642>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2113110>, nrf_mesh_dfu.c,  482,   DFU segment rx: 12/8114
    00> <t:    2113114>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 6, count 3, interval: exponential, handle: FFFC
    00> <t:    2113127>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2113131>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2130116>, nrf_mesh_dfu.c,  482,   DFU segment rx: 13/8114
    00> <t:    2130120>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 7, count 3, interval: exponential, handle: FFFC
    00> <t:    2130134>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2130137>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2147544>, nrf_mesh_dfu.c,  482,   DFU segment rx: 14/8114
    00> <t:    2147548>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 1, count 3, interval: exponential, handle: FFFC
    00> <t:    2147562>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2147565>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2164633>, nrf_mesh_dfu.c,  482,   DFU segment rx: 15/8114
    00> <t:    2164638>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 2, count 3, interval: exponential, handle: FFFC
    00> <t:    2164651>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2164654>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2181709>, nrf_mesh_dfu.c,  482,   DFU segment rx: 16/8114
    00> <t:    2181713>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 3, count 3, interval: exponential, handle: FFFC
    00> <t:    2181726>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2181730>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2199247>, nrf_mesh_dfu.c,  482,   DFU segment rx: 17/8114
    00> <t:    2199252>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 4, count 3, interval: exponential, handle: FFFC
    00> <t:    2199265>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2199269>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2216228>, nrf_mesh_dfu.c,  482,   DFU segment rx: 18/8114
    00> <t:    2216232>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 5, count 3, interval: exponential, handle: FFFC
    00> <t:    2216246>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2216249>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2233200>, nrf_mesh_dfu.c,  482,   DFU segment rx: 19/8114
    00> <t:    2233204>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 6, count 3, interval: exponential, handle: FFFC
    00> <t:    2233217>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2233221>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2250746>, nrf_mesh_dfu.c,  482,   DFU segment rx: 20/8114
    00> <t:    2250751>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 7, count 3, interval: exponential, handle: FFFC
    00> <t:    2250764>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2250767>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2267730>, nrf_mesh_dfu.c,  482,   DFU segment rx: 21/8114
    00> <t:    2267735>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 1, count 3, interval: exponential, handle: FFFC
    00> <t:    2267748>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2267752>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2285264>, nrf_mesh_dfu.c,  482,   DFU segment rx: 22/8114
    00> <t:    2285269>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 2, count 3, interval: exponential, handle: FFFC
    00> <t:    2285283>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2285286>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2302639>, nrf_mesh_dfu.c,  482,   DFU segment rx: 23/8114
    00> <t:    2302644>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 3, count 3, interval: exponential, handle: FFFC
    00> <t:    2302657>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2302661>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2320526>, nrf_mesh_dfu.c,  482,   DFU segment rx: 24/8114
    00> <t:    2320531>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 4, count 3, interval: exponential, handle: FFFC
    00> <t:    2320544>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2320547>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2337469>, nrf_mesh_dfu.c,  482,   DFU segment rx: 25/8114
    00> <t:    2337473>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 5, count 3, interval: exponential, handle: FFFC
    00> <t:    2337487>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2337490>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2354995>, nrf_mesh_dfu.c,  482,   DFU segment rx: 26/8114
    00> <t:    2354999>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 6, count 3, interval: exponential, handle: FFFC
    00> <t:    2355013>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2355016>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2372059>, nrf_mesh_dfu.c,  482,   DFU segment rx: 27/8114
    00> <t:    2372064>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 7, count 3, interval: exponential, handle: FFFC
    00> <t:    2372077>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2372081>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2388973>, nrf_mesh_dfu.c,  482,   DFU segment rx: 28/8114
    00> <t:    2388977>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 1, count 3, interval: exponential, handle: FFFC
    00> <t:    2388991>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2388994>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2406022>, nrf_mesh_dfu.c,  482,   DFU segment rx: 29/8114
    00> <t:    2406027>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 2, count 3, interval: exponential, handle: FFFC
    00> <t:    2406041>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2406044>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2423006>, nrf_mesh_dfu.c,  482,   DFU segment rx: 30/8114
    00> <t:    2423011>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 3, count 3, interval: exponential, handle: FFFC
    00> <t:    2423024>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2423028>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2440498>, nrf_mesh_dfu.c,  482,   DFU segment rx: 31/8114
    00> <t:    2440502>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 4, count 3, interval: exponential, handle: FFFC
    00> <t:    2440516>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2440519>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2457485>, nrf_mesh_dfu.c,  482,   DFU segment rx: 32/8114
    00> <t:    2457489>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 5, count 3, interval: exponential, handle: FFFC
    00> <t:    2457502>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2457506>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    2475412>, nrf_mesh_dfu.c,  482,   DFU segment rx: 33/8114
    00> <t:    2475417>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 6, count 3, interval: exponential, handle: FFFC
    00> <t:    2475430>, nrf_mesh_dfu.c,  352, Write complete (0x2003FE98)
    00> <t:    2475434>, nrf_mesh_dfu.c,  361, Flash idle.
    00> <t:    5359000>, nrf_mesh_dfu.c,  325, ABORT Timeout fired @675543701
    00> <t:    5359003>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 0, count 15, interval: periodic, handle: FFFE
    00> <t:    5359008>, nrf_mesh_dfu.c,  593,   SERIAL TX (type: 65534)
    00> <t:    5359012>, main.c,  116, mesh_evt_handler >> Entering into [536888852]
    00> <t:    5359017>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 0, count 15, interval: periodic, handle: FFFE
    00> <t:    5359021>, nrf_mesh_dfu.c,  565, Killing a TX slot prematurely (repeats done: 0).
    00> <t:    5359025>, nrf_mesh_dfu.c,  593,   SERIAL TX (type: 65534)
    For Above DFU process i have used the default DFU example from Mesh source and following command process:
    1:   nrfutil dfu genpkg --application examples/dfu/build/dfu_nrf52840_xxAA_s140_7.2.0_Release/dfu_nrf52840_xxAA_s140_7.2.0.hex --company-id 0x00000059 --application-id 1 --application-version 2 --sd-req 0x0100 --mesh dfu_test.zip
    2: python2 tools/dfu/device_page_generator.py -d nrf52840_xxAA -sd "s140_7.2.0"
    3: nrfjprog --eraseall
    4: nrfjprog --program bin/softdevice/s140_nrf52_7.2.0_softdevice.hex --chiperase
    5: nrfjprog --program bin/bootloader/gccarmemb/mesh_bootloader_serial_gccarmemb_nrf52840_xxAA.hex
    6: nrfjprog --program examples/dfu/build/dfu_nrf52840_xxAA_s140_7.2.0_Release/dfu_nrf52840_xxAA_s140_7.2.0.hex
    7: nrfjprog --program bin/device_page_nrf52840_xxAA_s140_7.2.0.hex
    8: nrfjprog --reset
    9: python2 tools/dfu/bootloader_verify.py 683751236 /dev/ttyACM0
    10: nrfjprog --reset
    11: nrfutil --verbose dfu serial -pkg dfu_test.zip -p /dev/ttyUSB0 -b 115200 -fc --mesh
  • Thanks,
    Solved DFU issue by changing Serial port from ttyUSB0 to ttyACM0 in Step 11.
