Can't establish LTE connection with CONFIG_NRF_MODEM_LIB_TRACE_ENABLED turned on.
I have built on the CoAP example a POST request to the server. This works now without any problems.
I do send the received signal power within my POST. To get the power I use the AT command: AT+CESQ
The problem arises after roughly 20 min where the code get stuck in the <at_cmd_write> function. The timer interrupt callbacks still working correctly.
To get a clue what the problem could be, I wanted to do a modem trace. But if I add the configuration : CONFIG_NRF_MODEM_LIB_TRACE_ENABLED=y, the code get stuck already in the modem_configure() function from the example.
What could be the problem, or how can I track down the problem?
I'm using the VS Code extension as my development environment, the SDK Version 1.7.0 and Modem Version 1.3.0.
My config files are:
0216.prj_qemu_x86.conf2335.overlay-carrier.conf
I'm not 100% sure if I configured everything correct that all of these are used for the west build.
Thanks in advance.
