Blocking UART with timeout using soft timers.
I am trying to use UART APIs in blocking mode to receive data from another controller.
I intend to have a timeout on receiving function so not to stuck if no byte is received from the other controller. Here is the snippet of UART receive function:
//soft timer timeout handler
static void uart_timer_handler(void * p_context)
    uart_to = 1;
//uart rx function with timeout
//parameter in  - uart input data expected
//parameter len - length of the input data in bytes.
uint8_t uart_read_nrf(char *in, uint8_t len)
    uint16_t index = 0;
    //while the expected data is not received.
    while((strncmp(data_array, in, len) != 0))
        switch(uart_to)         //timeout flag from soft timer
            case 1:             //if time out flag is set by soft timer event
                uart_to = 0;
                nrf_drv_uart_rx_disable(&app_uart_inst);
                return 1;
            case 0:             //continue receiving if timeout have not occurred yet
                nrf_drv_uart_rx(&app_uart_inst, &data_array[index], 1);
                index++;
    return 0;
And in main function I am starting the soft timer with 2 sec of timeout like this:
uart_to = 0;
app_timer_start(UART_TIMER, APP_TIMER_TICKS(2000), NULL);
uart_read_nrf("ON", 2);
I am intentionally passing the wrong data "ON" instead of "OK", just to check the time out functionality of the code. But the code get stuck in the following do while loop of nrfx_uarte_rx() function from nrfx_uarte.c
do {
            endrx  = nrf_uarte_event_check(p_instance->p_reg, NRF_UARTE_EVENT_ENDRX);
            rxto   = nrf_uarte_event_check(p_instance->p_reg, NRF_UARTE_EVENT_RXTO);
            error  = nrf_uarte_event_check(p_instance->p_reg, NRF_UARTE_EVENT_ERROR);
        } while ((!endrx) && (!rxto) && (!error));
I am using SDK version 15.0.0 and SEGGER Embedded studio for Arm V5.32a with S140 Softdevice. My target is nRF52840 rev2.
Thanking in advance.
Shivek
