I've made a basic QSPI setup for an MT25QU512. By default the QSPI driver is using 24-bit addressing. To access all of the memory, I'd like to set up the QSPI driver to use 32-bit addressing (via address-size-32). In order to do that, a command needs to be sent to the flash to put it into 32-bit mode: ENTER 4-BYTE ADDRESS MODE (B7h). How would I go about sending that command to the flash chip? Is there some way to use the Zephyr flash driver interface to send an arbitrary command?
