nrf_radio_cca_configure, how to use?
API doc says
__STATIC_INLINE void nrf_radio_cca_configure	(	nrf_radio_cca_mode_t 	cca_mode,
uint8_t 	cca_ed_threshold,
uint8_t 	cca_corr_threshold,
uint8_t 	cca_corr_cnt
Function for configuring the IEEE 802.15.4 clear channel assessment.
Parameters
cca_mode	Mode of CCA.
cca_ed_threshold	Energy Detection threshold value.
cca_corr_threshold	Correlator Busy Threshold.
cca_corr_cnt	Limit of occurances above Correlator Threshold. When not equal to zero the correlator based signal detect is enabled.
Specs says:for ed_threshold:
PRF[dBm] = ED_RSSIOFFS + ED_RSSISCALE x VALHARDWARE
ED_RSSIOFFS is -92, ED_RSSISCALE is 4.
So if I want to set the threshold 4dBm above -92, shall I put number 1 to hardware register?
I just want to double check that my understanding is correct.
Also I want to confirm that there is no way to set threshold lower than -92dBm.
What about cca_corr_threshold?
  • Hi
    Yes, that is correct.
    Correct.
    It is the same as the EDSAMPLE register, as mentioned in this paragraph of the specification:
    The conversion from CCAEDTHRES, CCA or EDLEVEL value to dBm can be done with the following equation, where VALHARDWARE is the hardware-reported values, being either CCAEDTHRES, CCA or EDLEVEL, and constants ED_RSSISCALE and ED_RSSIOFFS are from electrical specifications:
    Figure 18. Conversion between hardware value and dBm
    Best Regards
    Torbjørn
  • Thanks. Will give it a try!
