Windows 8.1 bonding/pairing error
Hello all, before I decided to write my own question I read the forum thoroughly. How ever no aid found to solve my problem. At first I want to make "just work" bonding(pairing) to encrypt further communication. I saw many nordic examples for this using DeviceManager+pstorage. However my RAM budget could not allow usage of this lib. I try to do this manually without saving keys in flash( at present revision). When initiate pairing from windows 8.1 the flow are next (in debug):
BLE_GAP_EVT_CONNECTED
BLE_GAP_ROLE_PERIPH (ID 3)
BLE_GAP_EVT_SEC_PARAMS_REQUEST
   Sec params from host:
   Bond: 1
   Io_caps: 4
   kdist_central: 124
   kdist_periph: 219
   max_key_size: 16
   min_key_size: 0
   mitm: 1
   oob: 0
My peripheral answers:
 uint32_t res=sd_ble_gap_sec_params_reply(ble_evt->evt.gap_evt.conn_handle,BLE_GAP_SEC_STATUS_SUCCESS,&m_sec_params,NULL);
where m_sec_params are:
        #define SEC_PARAM_BOND                       1
        #define SEC_PARAM_MITM                        0
        #define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE
        #define SEC_PARAM_OOB                         0
        #define SEC_PARAM_MIN_KEY_SIZE           7
        #define SEC_PARAM_MAX_KEY_SIZE          16
 BLE_GAP_EVT_AUTH_STATUS
      Auth status: 0x88 , Src: Remote
      //BLE_GAP_SEC_STATUS_UNSPECIFIED            0x88  /**< Unspecified reason. */
    Disconnect from host, reason 19
      //BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION           0x13
      /**< Remote User Terminated Connection. */
When initiate pairing from Android the flow are next:
BLE_GAP_ROLE_PERIPH (ID: 3)
  Bond: 1
  Io_caps: 4
  kdist_central: 231
  kdist_periph: 119
  max_key_size: 16
  min_key_size: 0
  mitm: 1
  oob: 0
BLE_GAP_EVT_CONN_SEC_UPDATE
Auth status: 00, Src: Local
//Success.
Than I have a look on examples: and found that windows 8.1 paired correctly when at BLE_GAP_EVT_SEC_PARAMS_REQUEST peripheral answers:
uint32_t res=sd_ble_gap_sec_params_reply(ble_evt->evt.gap_evt.conn_handle,BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,NULL,NULL);
Then central (windows) disconnects and reconnects. Now it is possible to work with device. The problem is that Android do not support such trick. i.e. BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP and show the pairing failure. Please help to make device bondable/pairable on both win and android devices. Or may be it would beter to show key pieces of code from DM where it made properly.
best regards.
