Hello!
I've seen similar posts about this issue:
https://devzone.nordicsemi.com/f/nordic-q-a/57105/nrf9160-modem-stuck-in-searching
https://devzone.nordicsemi.com/f/nordic-q-a/55154/lte-network-detected-but-never-connected
https://devzone.nordicsemi.com/f/nordic-q-a/80359/nrf9160-modem-firmware-1-3-0-intermittent-fails-to-register-in-lte-network-lte-m
However, none of these have solved my issue. My Problem might be different from others.
So my software/firmware has been running perfectly fine for a while. What it basically does is take a picture with adafruit vc0706 every minute and send that picture to AWS through LTE divided into several packages. Until recently when I accidentally broke the vc0706 and replaced it with a new vc0706 (same model and version). I'm currently using an Icarus IoT board to control the camera and when booting it up after switching, it connected successfully, took a picture, waited a minute, and during the sending of the second image disconnected from MQTT and now it is not able to reconnect to LTE. I've tried this with 4 different Icarus IoT Boards now and they all experience the same faith.
So this is what appears in the LTE link monitor:
2021-10-28T03:49:20.902Z DEBUG modem << *** Booting Zephyr OS build v2.3.0-rc1-ncs3 *** 2021-10-28T03:49:20.903Z DEBUG modem << Flash regionsDomainPermissions 2021-10-28T03:49:20.904Z DEBUG modem << 00 02 0x00000 0x18000 Securerwxl 2021-10-28T03:49:20.904Z DEBUG modem << 03 31 0x18000 0x100000 Non-Securerwxl 2021-10-28T03:49:20.904Z DEBUG modem << Non-secure callable region 0 placed in flash region 2 with size 32. 2021-10-28T03:49:21.187Z DEBUG modem << SRAM regionDomainPermissions 2021-10-28T03:49:21.188Z DEBUG modem << 00 07 0x00000 0x10000 Securerwxl 2021-10-28T03:49:21.189Z DEBUG modem << 08 31 0x10000 0x40000 Non-Securerwxl 2021-10-28T03:49:21.189Z DEBUG modem << PeripheralDomainStatus 2021-10-28T03:49:21.190Z DEBUG modem << 00 NRF_P0 Non-SecureOK 2021-10-28T03:49:21.190Z DEBUG modem << 01 NRF_CLOCK Non-SecureOK 2021-10-28T03:49:21.191Z DEBUG modem << 02 NRF_RTC0 Non-SecureOK 2021-10-28T03:49:21.191Z DEBUG modem << 03 NRF_RTC1 Non-SecureOK 2021-10-28T03:49:21.192Z DEBUG modem << 04 NRF_NVMC Non-SecureOK 2021-10-28T03:49:21.192Z DEBUG modem << 05 NRF_UARTE1 Non-SecureOK 2021-10-28T03:49:21.192Z DEBUG modem << 06 NRF_UARTE2 SecureSKIP 2021-10-28T03:49:21.193Z DEBUG modem << 07 NRF_TWIM2 Non-SecureOK 2021-10-28T03:49:21.193Z DEBUG modem << 08 NRF_SPIM3 Non-SecureOK 2021-10-28T03:49:21.193Z DEBUG modem << 09 NRF_TIMER0 Non-SecureOK 2021-10-28T03:49:21.194Z DEBUG modem << 10 NRF_TIMER1 Non-SecureOK 2021-10-28T03:49:21.195Z DEBUG modem << 11 NRF_TIMER2 Non-SecureOK 2021-10-28T03:49:21.195Z DEBUG modem << 12 NRF_SAADC Non-SecureOK 2021-10-28T03:49:21.196Z DEBUG modem << 13 NRF_PWM0 Non-SecureOK 2021-10-28T03:49:21.197Z DEBUG modem << 14 NRF_PWM1 Non-SecureOK 2021-10-28T03:49:21.197Z DEBUG modem << 15 NRF_PWM2 Non-SecureOK 2021-10-28T03:49:21.197Z DEBUG modem << 16 NRF_PWM3 Non-SecureOK 2021-10-28T03:49:21.198Z DEBUG modem << 17 NRF_WDT Non-SecureOK 2021-10-28T03:49:21.198Z DEBUG modem << 18 NRF_IPC Non-SecureOK 2021-10-28T03:49:21.198Z DEBUG modem << 19 NRF_VMC Non-SecureOK 2021-10-28T03:49:21.199Z DEBUG modem << 20 NRF_FPU Non-SecureOK 2021-10-28T03:49:21.199Z DEBUG modem << 21 NRF_EGU1 Non-SecureOK 2021-10-28T03:49:21.200Z DEBUG modem << 22 NRF_EGU2 Non-SecureOK 2021-10-28T03:49:21.200Z DEBUG modem << 23 NRF_DPPIC Non-SecureOK 2021-10-28T03:49:21.200Z DEBUG modem << 24 NRF_GPIOTE1 Non-SecureOK 2021-10-28T03:49:21.201Z DEBUG modem << 25 NRF_REGULATORS Non-SecureOK 2021-10-28T03:49:21.201Z DEBUG modem << SPM: NS image at 0x1c200 2021-10-28T03:49:21.201Z DEBUG modem << SPM: NS MSP at 0x2002f208 2021-10-28T03:49:21.202Z DEBUG modem << SPM: NS reset vector at 0x1ea0d 2021-10-28T03:49:21.202Z DEBUG modem << SPM: prepare to jump to Non-Secure image. 2021-10-28T03:49:21.387Z DEBUG modem << *** Booting Zephyr OS build v2.3.0-rc1-ncs3 *** 2021-10-28T03:49:21.388Z DEBUG modem << Camera VC0706 2021-10-28T03:49:21.389Z DEBUG modem << Initializing camera 2021-10-28T03:49:24.395Z DEBUG modem << 640x480 2021-10-28T03:49:24.412Z DEBUG modem << Setting up compression ratio 2021-10-28T03:49:24.427Z DEBUG modem << Current compression ratio is 55 2021-10-28T03:49:24.429Z DEBUG modem << Provisioning certificates 2021-10-28T03:49:24.571Z DEBUG modem << LTE Link Connecting ... 2021-10-28T03:49:57.740Z DEBUG modem << +CEREG: 2,"0901","020A6016",7,0,0,"11100000","11100000" 2021-10-28T03:49:57.788Z DEBUG modem << +CSCON: 1 2021-10-28T03:49:59.660Z DEBUG modem << +CEREG: 5,"0901","020A6016",7,,,"11100000","11100000" 2021-10-28T03:49:59.665Z DEBUG modem << LTE Link Connected! 2021-10-28T03:49:59.820Z DEBUG modem << IPv4 Address found 16.170.29.125 2021-10-28T03:50:03.419Z DEBUG modem << [mqtt_evt_handler:271] MQTT client connected! 2021-10-28T03:50:03.420Z DEBUG modem << Connected with TLS 2021-10-28T03:50:04.412Z DEBUG modem << Exiting power saving mode 2021-10-28T03:50:05.435Z DEBUG modem << Taking picture 2021-10-28T03:50:05.451Z DEBUG modem << Reading picture length 2021-10-28T03:50:05.467Z DEBUG modem << Image size: 30052 bytes 2021-10-28T03:50:05.468Z DEBUG modem << Reading picture 2021-10-28T03:50:10.485Z DEBUG modem << Picture taken successfully 2021-10-28T03:50:10.487Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:11.696Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 42196 2021-10-28T03:50:11.697Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:12.336Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 16422 2021-10-28T03:50:12.337Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:12.977Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 37429 2021-10-28T03:50:12.977Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:13.361Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 58401 2021-10-28T03:50:13.376Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:14.021Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 5940 2021-10-28T03:50:14.022Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:14.672Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 26974 2021-10-28T03:50:14.672Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:15.301Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 48373 2021-10-28T03:50:15.301Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:15.940Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 3354 2021-10-28T03:50:15.940Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:16.592Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 24388 2021-10-28T03:50:16.593Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:17.231Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 45753 2021-10-28T03:50:17.231Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:18.687Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 1166 2021-10-28T03:50:18.703Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:19.396Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 49393 2021-10-28T03:50:19.396Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:19.792Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 6470 2021-10-28T03:50:19.793Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:20.192Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 19539 2021-10-28T03:50:20.193Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:20.581Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 32685 2021-10-28T03:50:20.581Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:20.994Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 45400 2021-10-28T03:50:20.994Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:21.415Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 58914 2021-10-28T03:50:21.415Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:21.862Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 7076 2021-10-28T03:50:21.863Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:22.180Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 21839 2021-10-28T03:50:22.182Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:22.596Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 32261 2021-10-28T03:50:22.612Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:23.001Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 46399 2021-10-28T03:50:23.001Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:23.379Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 59066 2021-10-28T03:50:23.380Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:23.715Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 6015 2021-10-28T03:50:23.731Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:24.114Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 17561 2021-10-28T03:50:24.115Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:24.503Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 30081 2021-10-28T03:50:24.504Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:24.900Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 42815 2021-10-28T03:50:24.900Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:25.305Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 55857 2021-10-28T03:50:25.306Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:25.620Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 3526 2021-10-28T03:50:25.620Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:26.041Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 13912 2021-10-28T03:50:26.042Z DEBUG modem << Publishing 358 bytes to topic: vistek/pilot len: 12 2021-10-28T03:50:26.421Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 27627 2021-10-28T03:50:26.421Z DEBUG modem << Picture sent successfully 2021-10-28T03:50:26.422Z DEBUG modem << Entering power saving mode 2021-10-28T03:50:26.422Z DEBUG modem << +CSCON: 0 2021-10-28T03:50:26.437Z DEBUG modem << +CEREG: 5,"0901","01E3500B",7,,,"11100000","11100000" 2021-10-28T03:50:26.441Z DEBUG modem << +CSCON: 1 2021-10-28T03:50:30.245Z DEBUG modem << +CSCON: 0 2021-10-28T03:51:04.405Z DEBUG modem << Exiting power saving mode 2021-10-28T03:51:05.429Z DEBUG modem << Taking picture 2021-10-28T03:51:05.445Z DEBUG modem << Reading picture length 2021-10-28T03:51:05.461Z DEBUG modem << Image size: 32216 bytes 2021-10-28T03:51:05.462Z DEBUG modem << Reading picture 2021-10-28T03:51:10.484Z DEBUG modem << Picture taken successfully 2021-10-28T03:51:10.485Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:51:11.056Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 42197 2021-10-28T03:51:11.056Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:51:11.381Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 60980 2021-10-28T03:51:11.381Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:51:11.695Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 6028 2021-10-28T03:51:11.696Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:51:12.015Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 16380 2021-10-28T03:51:12.016Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:51:12.340Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 26869 2021-10-28T03:51:12.340Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:51:12.658Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 37486 2021-10-28T03:51:12.658Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:51:12.978Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 47941 2021-10-28T03:51:12.979Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:51:13.311Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 58425 2021-10-28T03:51:13.311Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:51:13.630Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 3802 2021-10-28T03:51:13.630Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:51:13.939Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 14269 2021-10-28T03:51:13.939Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:51:14.264Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 24398 2021-10-28T03:51:14.264Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:51:14.568Z DEBUG modem << [mqtt_evt_handler:315] PUBACK packet id: 35015 2021-10-28T03:51:14.584Z DEBUG modem << Publishing 1026 bytes to topic: vistek/pilot len: 12 2021-10-28T03:51:17.121Z DEBUG modem << [mqtt_evt_handler:282] MQTT client disconnected -128 2021-10-28T03:51:17.122Z DEBUG modem << ERROR: mqtt_input -128 2021-10-28T03:51:17.122Z DEBUG modem << Error while sending picture 2021-10-28T03:51:17.122Z DEBUG modem << +CSCON: 1 2021-10-28T03:51:17.169Z DEBUG modem << +CEREG: 2,"0901","01E3500B",7,0,10,"11100000","11100000" 2021-10-28T03:51:18.433Z DEBUG modem << +CSCON: 0 2021-10-28T03:51:26.924Z DEBUG modem << *** Booting Zephyr OS build v2.3.0-rc1-ncs3 *** 2021-10-28T03:51:26.925Z DEBUG modem << Flash regionsDomainPermissions 2021-10-28T03:51:26.925Z DEBUG modem << 00 02 0x00000 0x18000 Securerwxl 2021-10-28T03:51:26.925Z DEBUG modem << 03 31 0x18000 0x100000 Non-Securerwxl 2021-10-28T03:51:26.926Z DEBUG modem << Non-secure callable region 0 placed in flash region 2 with size 32. 2021-10-28T03:51:27.208Z DEBUG modem << SRAM regionDomainPermissions 2021-10-28T03:51:27.209Z DEBUG modem << 00 07 0x00000 0x10000 Securerwxl 2021-10-28T03:51:27.209Z DEBUG modem << 08 31 0x10000 0x40000 Non-Securerwxl 2021-10-28T03:51:27.210Z DEBUG modem << PeripheralDomainStatus 2021-10-28T03:51:27.210Z DEBUG modem << 00 NRF_P0 Non-SecureOK 2021-10-28T03:51:27.210Z DEBUG modem << 01 NRF_CLOCK Non-SecureOK 2021-10-28T03:51:27.210Z DEBUG modem << 02 NRF_RTC0 Non-SecureOK 2021-10-28T03:51:27.211Z DEBUG modem << 03 NRF_RTC1 Non-SecureOK 2021-10-28T03:51:27.211Z DEBUG modem << 04 NRF_NVMC Non-SecureOK 2021-10-28T03:51:27.212Z DEBUG modem << 05 NRF_UARTE1 Non-SecureOK 2021-10-28T03:51:27.213Z DEBUG modem << 06 NRF_UARTE2 SecureSKIP 2021-10-28T03:51:27.213Z DEBUG modem << 07 NRF_TWIM2 Non-SecureOK 2021-10-28T03:51:27.213Z DEBUG modem << 08 NRF_SPIM3 Non-SecureOK 2021-10-28T03:51:27.214Z DEBUG modem << 09 NRF_TIMER0 Non-SecureOK 2021-10-28T03:51:27.214Z DEBUG modem << 10 NRF_TIMER1 Non-SecureOK 2021-10-28T03:51:27.215Z DEBUG modem << 11 NRF_TIMER2 Non-SecureOK 2021-10-28T03:51:27.215Z DEBUG modem << 12 NRF_SAADC Non-SecureOK 2021-10-28T03:51:27.216Z DEBUG modem << 13 NRF_PWM0 Non-SecureOK 2021-10-28T03:51:27.216Z DEBUG modem << 14 NRF_PWM1 Non-SecureOK 2021-10-28T03:51:27.216Z DEBUG modem << 15 NRF_PWM2 Non-SecureOK 2021-10-28T03:51:27.217Z DEBUG modem << 16 NRF_PWM3 Non-SecureOK 2021-10-28T03:51:27.217Z DEBUG modem << 17 NRF_WDT Non-SecureOK 2021-10-28T03:51:27.217Z DEBUG modem << 18 NRF_IPC Non-SecureOK 2021-10-28T03:51:27.218Z DEBUG modem << 19 NRF_VMC Non-SecureOK 2021-10-28T03:51:27.218Z DEBUG modem << 20 NRF_FPU Non-SecureOK 2021-10-28T03:51:27.219Z DEBUG modem << 21 NRF_EGU1 Non-SecureOK 2021-10-28T03:51:27.219Z DEBUG modem << 22 NRF_EGU2 Non-SecureOK 2021-10-28T03:51:27.219Z DEBUG modem << 23 NRF_DPPIC Non-SecureOK 2021-10-28T03:51:27.220Z DEBUG modem << 24 NRF_GPIOTE1 Non-SecureOK 2021-10-28T03:51:27.220Z DEBUG modem << 25 NRF_REGULATORS Non-SecureOK 2021-10-28T03:51:27.220Z DEBUG modem << SPM: NS image at 0x1c200 2021-10-28T03:51:27.220Z DEBUG modem << SPM: NS MSP at 0x2002f208 2021-10-28T03:51:27.221Z DEBUG modem << SPM: NS reset vector at 0x1ea0d 2021-10-28T03:51:27.221Z DEBUG modem << SPM: prepare to jump to Non-Secure image. 2021-10-28T03:51:27.408Z DEBUG modem << *** Booting Zephyr OS build v2.3.0-rc1-ncs3 *** 2021-10-28T03:51:27.409Z DEBUG modem << Camera VC0706 2021-10-28T03:51:27.409Z DEBUG modem << Initializing camera 2021-10-28T03:51:30.416Z DEBUG modem << 640x480 2021-10-28T03:51:30.432Z DEBUG modem << Setting up compression ratio 2021-10-28T03:51:30.448Z DEBUG modem << Current compression ratio is 55 2021-10-28T03:51:30.449Z DEBUG modem << Provisioning certificates 2021-10-28T03:51:30.592Z DEBUG modem << LTE Link Connecting ... 2021-10-28T03:52:03.826Z DEBUG modem << +CEREG: 2,"0901","01E3500B",7,0,0,"11100000","11100000" 2021-10-28T03:52:03.874Z DEBUG modem << +CSCON: 1 2021-10-28T03:52:04.082Z DEBUG modem << +CEREG: 4,"0901","01E3500B",7,0,15,"11100000","11100000" 2021-10-28T03:52:05.330Z DEBUG modem << +CSCON: 0 2021-10-28T03:52:05.362Z DEBUG modem << +CEREG: 4,"FFFE","FFFFFFFF",7,0,15,"11100000","11100000" 2021-10-28T03:52:06.130Z DEBUG modem << +CEREG: 2,"76C1","030D6B01",7,0,15,"11100000","11100000" 2021-10-28T03:52:06.162Z DEBUG modem << +CSCON: 1 2021-10-28T03:52:06.482Z DEBUG modem << +CEREG: 0,"76C1","030D6B01",7,0,8,"11100000","11100000" 2021-10-28T03:52:07.730Z DEBUG modem << +CSCON: 0
Currently, I'm using the 1.3.1 modem firmware. I would also like to note that if allowed to run for a while the board eventually connects to LTE, but is not able to fetch any IP address and proceeds to disconnect again. I sadly do not have the error messages given, but I can try again and see what comes up. The error message is shown in the comments. I highly doubt the issue here is with the camera since the information it sends is still the same and has nothing to do with LTE, but I'm open to suggestions.
