Cannot connect to nRF when in direct advertisement mode
Hello, I'm trying to manage connecting to my board (nRF52840-DK) which direct advertise (low prio) with peer address set to MAC address of my PC running Linux with bluez 5.62-1. Unfortunately I cannot connect to the board, no matter what. I develop the board with Zephyr RTOS. This is the code responsible for setting up advertisement:
static void bt_ready(void)
  int err;
  bt_addr_le_t dir_addr;
  const char *address = "D8:8F:76:5B:57:7E";
  const char *type = "public";
  if ((err = bt_addr_le_from_str(address, type, &dir_addr))) {
    printk("Bt_addr_le_from_str error: %d\n", err);
  err = bt_le_adv_start(BT_LE_ADV_CONN_DIR_LOW_DUTY(&dir_addr), ad, ARRAY_SIZE(ad), NULL, 0);
  if (err) {
    printk("Advertising failed to start (err %d)\n", err);
    return;
  printk("Advertising successfully started\n");
If i set the advertisement mode to BT_LE_ADV_CONN_NAME, then there is no problem - the device is scannable and connectable.
My question is - can someone post any code or describe any method that will allow me to connect my PC to the board?
  • Hi
    Are you certain that the PC you're using support scanning and connecting to directed advertising devices? Quite a few devices don't support this, for example all iOS devices as far as I know.
    The nRF Desktop application in the nRFConnect SDK should be able to do directed advertising, so you can take a look at that sample for reference.
    Simon
  • Hi Simon, thanks for a fast reply.
    I'm not sure if my PC supports a direct connection. How can I check it?
    Do you know if Raspberry Pi 4 supports it?
  • Hi
    Raspberry Pi 4 and BlueZ v5.62-1 should support directed advertising from what I can tell, but please make sure that your scanning device is doing active scanning. I'm not too familiar with the BlueZ stack, so you'll need to find out exactly how, but I assume you set this in the scan parameters.
    Simon
  • You're right, it is possible to scan for a device that advertise directly (I managed to do it using hciconfig and hcitool). However I just cannot manage to connect to the device, even though my scanner sees it. I'll dig into it. Thanks for your help.
  • Ok, I managed to connect to the board using bettercap tool. Now, what's happening is that after my PC disconnects from the board I cannot start direct advertisement again. What I tried to do was to start it in the disconnection callback:
    static void bt_start_adv_direct(const char *address, const char *type) {
      printk("Begin direct advertising to %s (%s).\n", address, type);
      int err;
      if (err) {
        return;
      printk("Advertising successfully started, directed to: %s\n", address);
    static void disconnected(struct bt_conn *conn, uint8_t reason) {
        printk("Disconnected (reason 0x%02x)\n", reason);
        bt_start_adv_direct(address, type); // global arrays
    Logs from nRF:
    *** Booting Zephyr OS build v2.6.1-rc1-21-g42d7e712063b  ***
    Set up button at GPIO_0 pin 11
    Set up LED at GPIO_0 pin 13
    Address: DB:94:18:97:FE:0D (random)
    Bluetooth initialized
    Begin direct advertising to 18:1D:EA:9C:EF:E5 (public).
    Advertising successfully started, directed to: 18:1D:EA:9C:EF:E5
    Connected
    Disconnected (reason 0x13)
    Advertising failed to start (err -22)
    As you can see, advertisement sets up when I call the `bt_start_adv_direct` for the first time in my main function, but it fails when called from the `disconnected` callback. I don't understand why the error code is 22 (afaik it's "Invalid argument" error). What should I do to restart advertisement after disconnection?
