I'm using JLinkExe (J link commander) for Linux to flash the application firmware on NRF51822_QF_AA target. The following have worked so far, but I'd like to confirm and have some doubts. The typical JLinkExe session invoked as root on my Linux system is as below:
$ sudo JLinkExe
Info: Found Cortex-M0 r0p0, Little endian.
Info: FPUnit: 4 code (BP) slots and 0 literal slots
Info: CoreSight components:
Info: ROMTbl 0 @ F0000000
Cortex-M0 identified.
Target interface speed: 100 kHz
J-Link>si 1
J-Link>speed 2000
J-Link>device nrf51822
J-Link>loadbin testing.bin 0x16000
J-Link>r
J-Link>g
J-Link>exit
The reason, I pass
0x16000
as the address to loadbin, because this is the same load address that I've set in my linker configuration file under ~/nrf_sdk_v6.1.0/nrf51822/Source/templates/gcc/gcc_nrf51_s110_xxab.ld.
snip from gcc_nrf51_s110_xxab.ld:
SEARCH_DIR(.)
GROUP(-lgcc -lc -lnosys)
MEMORY
FLASH (rx) : ORIGIN = 0x00016000, LENGTH = 0xA000
RAM (rwx) : ORIGIN = 0x20002000, LENGTH = 0x2000
INCLUDE "gcc_nrf51_common.ld"
I see the same load address in the final map file. snip from testing.map:
Memory Configuration
Name Origin Length Attributes
FLASH 0x00016000 0x0002a000 xr
RAM 0x20002000 0x00002000 xrw
*default* 0x00000000 0xffffffff
My questions are:
Is it correct way of doing, or Am I missing something ? According to this thread, I should invoke loadbin as
In that same thread, what does, w4 4001e504 1 stands for and why is it needed? I'm not sure if I invoked it for the first time or not, but all other times, I'm not invoking that (w4 4001e504 1) command during flashing the application firmware .
J-Link>w4 Syntax: w4 <Addr>, <Data>
My environment is:
- Linux + ARM GNU Toolchain
- Target: nrf51822QF_AA (256kB flash memory)
- Flash utility: JLinkExe for Linux
- Segger J-link interface between the target board and PC
- Softdevice s110
- Custom application firmware
