Best way to modify examples in SDK 8.1
I'm getting started with SDK 8.0. The examples complied and flashed for me relatively painlessly on OSX, and the project organization is easy to understand.
Now I am looking at modifying the HID keyboard example for a device that I am building. I've copied the project folder over and created a custom_board.h for my prototype.
Sitting down to actually write code, I am beginning to wonder what the best way to architect my modifications in without clobbering the BSP backend. I basically just want to set up 12 buttons to send a predefined keypress, and use a combination of those buttons to start advertising mode, etc. My two main issues are:
-The device I am building has 12 buttons and BSP only supports 8
-I want to use button combinations/presses/releases to initiate events like initiate advertising, etc, and it seems like BSP is limited to using a few buttons and detecting a few event types.
Can someone recommend the best way for me to proceed? It makes me nervous to be hacking directly on the support libraries, and I am unsure of the best way to unweave the necessary parts from the event stack provided by the SDK.
-Maybe there an easy way to disable parts of the backend event generation stuff and cleanly instantiate the button config and event detection/handling directly in main.c?
-And also generate commands for the softdevice?
Thank you!
