Mesh dimming example client with generic_level_server element integrated to receive mesh messages
I am using the SDK v17 with the Mesh SDK v5 and the nRF52 development kits and I'm using SEGGER.
SETUP:
I have a mesh network with:
1 dimming client
1 dimming server
2 dimming client/server
Description:
I have integrated the generic level server into my 2 clients so that the 2 clients can send and receive messages to each other as well as receive messages from the dimming client. I have the 1 client that sends dimming levels to the 1 dimming server and the 2 dimming client/servers to control the dimming as well but they have a motion sensor on board so that they can dim the LEDs up and down when motion is sensed and when it is not. The 1 dimming server is simply dimming an LED based on the messages sent to it from the 2 dimming client/servers and the 1 dimming client they are provisioned to publish to all nodes.
The Issue:
Everything is working well but the issue that I am seeing is that on each of the 2 dimming client/servers they are receiving their own messages into the generic_level_server.c inside of static void handle_set(access_model_handle_t model_handle, const access_message_rx_t * p_rx_msg, void * p_args). They are also receiving each others messages there, which is what I want. I believe that they are receiving their own messages or that maybe this function being called somewhere.
Goal:
To allow the 2 dimming level client/servers to be able to send messages to each other without going into void_handle_set when they themselves send a message out and to only go into this function when they receive a message.
Is there a way to prevent this from happening with every message that is sent and are the dimming client/servers in fact, immediately receiving their own messages that they are sending out?
Furthermore, do I need to create separate client and server elements so that the 2 client/servers can send/receive messages to each other and then use the generic level client and generic level server element to receive the messages to the 1 dimming client and send messages to the 1 dimming server?
Thank you
