How do I switch the target from a Nrf51422_xxAC to Nrf51422_xxAB in Keil
I have a development board with the AC variant, but for my custom board I have an AB. I am able to flash code using Keil to the development board, but when I change the device to the AB variant for the same code, I get the errors below. I change the device setting through the "Options for Target" menu. Will a hex file compiled for AC work on AB (assuming the size is not an issue)?
C:\Keil_v5\ARM\PACK\NordicSemiconductor\nRF_Drivers\3.0.0\gpiote\nrf_drv_gpiote.c(30): error:  #20: identifier "GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS" is undefined
  nrf_drv_gpiote_evt_handler_t handlers[NUMBER_OF_GPIO_TE+GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS];
C:\Keil_v5\ARM\PACK\NordicSemiconductor\nRF_Drivers\3.0.0\gpiote\nrf_drv_gpiote.c(148): error:  #20: identifier "GPIOTE_CONFIG_IRQ_PRIORITY" is undefined
      nrf_drv_common_irq_enable(GPIOTE_IRQn, GPIOTE_CONFIG_IRQ_PRIORITY);
I am using the 110 softdevice within the 8.0.0 SDK. I have made the change to the target board as mentioned below. The vales for iROM and iRAM are auto-populated due to the change in target board, so I did not change them. I still get the two errors shown above with the target change.
Right now I am trying to just get an example to compile for the AB chip. The end application will be a custom board that will be emitting a custom advertising packet every 5 seconds and then going to sleep.
image description
