Hi all,
looking for samples for using CoAP with DTLS 1.2 (PSK) on nRF9160. All the samples I can find are not using DTLS. Highly appreciate any hint!
Thank in advance,
Andre
Hi all,
Thank in advance,
Andre
Hi Andre,
What version of NCS are you working on? The Download client library can use CoAPS (DTLS 1.2). Have a look at the nRF9160: Download client sample.
Øyvind
Thanks for your answer Øyvind! I am using NCS 1.7.1 and will examine the download client sample , thanks for that. Having a first look to the source code of nordic_nrf_9160/sdk-nrf/samples/nrf9160/download/src/main.c it seems like the sample is using certificate for authentication both for HTTP and CoAP. What approach would you recommend to find some examples for using CoAP with PSK-based DTLS authentication? Thanks for any hint
Could you please elaborate more on what you are trying to achieve? From our modem FW release notes it states:
*** Limitations
- TLS/DTLS
- Up to three simultaneous TLS/DTLS connections are possible.
- Maximum server certificate chain size has a limit of 4kB.
- Server certificate expiry time is not verified.
- pkcs#8 is not supported.
- Absolute maximum number of supported credentials is 32. The actual amount depends on size of
credentials as memory area reserved for credentials may be a limiting factor as well.
- DTLS supports PSK authentication only.
- 2kB secure socket buffer size.
So PSK based DTLS is supported.
Andre23t said:What approach would you recommend to find some examples for using CoAP with PSK-based DTLS authentication?
We have several samples in which TLS/DTLS is used, I recommend looking through our official nRF9160 samples, and the modem library documentation on TLS/DTLS configuration
