Cannot see NRF_LOG_INFO in Segger Embedded Studio
I can find some other topics about this:
Like this one:
https://devzone.nordicsemi.com/f/nordic-q-a/43370/nrf_log_info-and-printf-does-not-work
or this article:
https://westsideelectronics.com/getting-logging-to-work-in-segger-embedded-studio/
But the problem is, I can not find the define:
NRF_LOG_BACKEND_RTT_ENABLED
Should I just replace config_sdk.h with another file with the right defines ?
Using the blinky example.
    What version of SDK are you using?
    Are you using SAADC Example? If so, start a terminal emulator like PuTTY and connect to the used COM port to get the log with the following UART settings:
    • Baud rate: 115.200
    • 8 data bits
    • 1 stop bit
    • No parity
    • HW flow control: None
    To get the RTT log, you could enable NRF_LOG_BACKEND_RTT_ENABLED (1) & NRFX_SAADC_CONFIG_LOG_ENABLED (1) and disable NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED (0) in the sdk_config.h to get the log.
    Please let me know this can help or not. Thanks.
    -Amanda
  • I tested it with saadc example from SDK 17.1.0 and did the define's you say.
    The application works fine:
    But no NRFX_LOG_INFO outputs, it just skips that line, also when put a debug point over there there is a question mark, probably a missing define ?
    But you are getting the NRFX_LOG_OUTPUT to work ?
    Add the following config to sdk_config.h:
    // <e> SAADC_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef SAADC_CONFIG_LOG_ENABLED
    #define SAADC_CONFIG_LOG_ENABLED 1
    Since this example doesn't use using nrfx_saadc directly, but through nrf_drv_saadc (legacy layer), you have to enable the legacy config. If not, the NRFX_ config will be overwritten by apply_old_config.h.
    -Amanda
