nRF52 hard fault when running sd_softdevice_enable
Received my nRF52 preview board yesterday and have been battling to get my S130 based nRF51 code running on it with the S132 soft device (the code is here: github.com/.../HomeKit including the current state of the NRF52 build under gcc/eclipse).
The code starts up and gets to the call to sd_softdevice_enable call in softdevice_handler.c. When it executes this call it always hits the HardFault_Handler seemingly regardless of the arguments I've tried it with. The last instruction it executes before the exception is "vmsr fpscr, r0" which I believe just moves the value of r0 into the floating point unit.
Any thoughts on what might be causing this greatly appreciated.
Thanks
  • Is the FPU enabled? It's a while since I read the FPU unit documentation but I remember most instructions cause a fault if the FPU isn't. There's code to enable it in system_nrf52.c
    I am however a little surprised the FPU is used in the softdevice since it's not required to be enabled and, apart from just generically setting things up to a known state, I can't see why the softdevice would use it.
    Do you have an address of that instruction, any other addresses in the stack would be handy too, I was going to take a look at the assembler see what's going on.
    I wish I had more time to play with my 52 devkit .. sigh.
  • After more experimenting I found this combination to compile, enable the FPU and not crash in the startup code:
    -mfloat-abi=softfp -mfpu=fpv4-sp-d16
    I have some assembly code which, though it doesn't use floating point, didn't like the hard float option.
