CLI sample, Testing Thread 1.2 features. Fatal error
> Executing task: nRF Connect: Build CLI_2ndBoard/build_2 (active) <
Building CLI_2ndBoard
west build --build-dir c:\Nordic\myApps\CLI_2ndBoard\build_2 c:\Nordic\myApps\CLI_2ndBoard --pristine --board nrf5340dk_nrf5340_cpuapp -- -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=On -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONF_FILE:STRING="c:/Nordic/myApps/CLI_2ndBoard/prj_nrf5340dk_nrf5340_cpuapp.conf" -DOVERLAY_CONFIG:STRING="c:/Nordic/myApps/CLI_2ndBoard/overlay-thread_1_2.conf"
Including boilerplate (Zephyr base): C:/Nordic/v1.7.0/zephyr/cmake/app/boilerplate.cmake
-- Application: C:/Nordic/myApps/CLI_2ndBoard
-- Zephyr version: 2.6.99 (C:/Nordic/v1.7.0/zephyr), build: v2.6.99-ncs1
-- Found Python3: C:/Nordic/v1.7.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Found west (found suitable version "0.11.1", minimum required is "0.7.1")
-- Board: nrf5340dk_nrf5340_cpuapp
-- Cache files will be written to: C:/Nordic/v1.7.0/zephyr/.cache
-- Found dtc: C:/Nordic/v1.7.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (c:/Nordic/v1.7.0/toolchain/opt)
-- Found BOARD.dts: C:/Nordic/v1.7.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp.dts
-- Generated zephyr.dts: C:/Nordic/myApps/CLI_2ndBoard/build_2/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Nordic/myApps/CLI_2ndBoard/build_2/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Nordic/myApps/CLI_2ndBoard/build_2/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/Nordic/myApps/CLI_2ndBoard/build_2/zephyr/dts.cmake
Parsing C:/Nordic/myApps/CLI_2ndBoard/Kconfig
Loaded configuration 'C:/Nordic/v1.7.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
Merged configuration 'c:/Nordic/myApps/CLI_2ndBoard/prj_nrf5340dk_nrf5340_cpuapp.conf'
Merged configuration '../common/overlay-ot-defaults.conf'
Merged configuration 'c:/Nordic/myApps/CLI_2ndBoard/overlay-thread_1_2.conf'
Configuration saved to 'C:/Nordic/myApps/CLI_2ndBoard/build_2/zephyr/.config'
Kconfig header saved to 'C:/Nordic/myApps/CLI_2ndBoard/build_2/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: C:/Nordic/v1.7.0/toolchain/opt/bin/arm-none-eabi-gcc.exe
-- Application: C:/Nordic/v1.7.0/zephyr/samples/boards/nrf/ieee802154/802154_rpmsg
warning: NRF_802154_ENCRYPTION (defined at C:\Nordic\v1.7.0\zephyr\modules\hal_nordic\Kconfig:46,
C:\Nordic\v1.7.0\nrfxlib\nrf_802154\zephyr\Kconfig.nrfxlib:18, c:\Nordic\myApps\CLI_2ndBoard\build_2\modules\hal_nordic\Kconfig:46) was
assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies:
((!CRYPTO_NRF_ECB && NRF_802154_RADIO_DRIVER && HAS_NORDIC_DRIVERS) || (!CRYPTO_NRF_ECB &&
NRF_802154_RADIO_DRIVER) || (!CRYPTO_NRF_ECB && NRF_802154_RADIO_DRIVER && HAS_NORDIC_DRIVERS && 0))
(=n). See docs.zephyrproject.org/.../CONFIG_NRF_802154_ENCRYPTION.html
and/or look up NRF_802154_ENCRYPTION in the menuconfig/guiconfig interface. The Application
Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of
the manual might be helpful too.
Adding '802154_rpmsg' firmware as child image since CONFIG_NRF_802154_SER_HOST is set to y
=== child image 802154_rpmsg - CPUNET begin ===
-- Board: nrf5340dk_nrf5340_cpunet
-- Found toolchain: gnuarmemb (C:/Nordic/v1.7.0/toolchain/opt)
-- Found BOARD.dts: C:/Nordic/v1.7.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpunet.dts
-- Generated zephyr.dts: C:/Nordic/myApps/CLI_2ndBoard/build_2/802154_rpmsg/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Nordic/myApps/CLI_2ndBoard/build_2/802154_rpmsg/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Nordic/myApps/CLI_2ndBoard/build_2/802154_rpmsg/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/Nordic/myApps/CLI_2ndBoard/build_2/802154_rpmsg/zephyr/dts.cmake
Parsing C:/Nordic/v1.7.0/zephyr/Kconfig
Loaded configuration 'C:/Nordic/v1.7.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpunet_defconfig'
Merged configuration 'C:/Nordic/v1.7.0/zephyr/samples/boards/nrf/ieee802154/802154_rpmsg/prj.conf'
Merged configuration 'C:/Nordic/v1.7.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Configuration saved to 'C:/Nordic/myApps/CLI_2ndBoard/build_2/802154_rpmsg/zephyr/.config'
Kconfig header saved to 'C:/Nordic/myApps/CLI_2ndBoard/build_2/802154_rpmsg/zephyr/include/generated/autoconf.h'
-- libmetal version: 1.0.0 (C:/Nordic/v1.7.0/zephyr/samples/boards/nrf/ieee802154/802154_rpmsg)
-- Looking for include file stdatomic.h
-- Looking for include file stdatomic.h - found
-- open-amp version: 1.0.0 (C:/Nordic/v1.7.0/modules/lib/open-amp/open-amp)
-- Looking for include file fcntl.h
-- Build type:
-- Host: Windows/AMD64
-- Target: Generic/arm
-- Machine: cortexm
-- Machine: cortexm
-- C_FLAGS : -Wall -Wextra
-- Looking for include file fcntl.h - found
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Nordic/myApps/CLI_2ndBoard/build_2/802154_rpmsg
=== child image 802154_rpmsg - CPUNET end ===
-- OpenThread Source Directory: C:/Nordic/v1.7.0/modules/lib/openthread
-- Check if the system is big endian
-- Searching 16 bit integer
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of unsigned short
-- Check size of unsigned short - done
-- Searching 16 bit integer - Using unsigned short
-- Check if the system is big endian - little endian
-- Package Name: OPENTHREAD
-- Setting default package version: v1.7.0
-- Package Version: v1.7.0
-- libmetal version: 1.0.0 (C:/Nordic/myApps/CLI_2ndBoard)
-- Build type:
-- Machine: cortexm
-- Machine: cortexm
CMake Warning (dev) at C:\Nordic\v1.7.0\nrfxlib\nrf_security\cmake\extensions.cmake:652:
Syntax Warning in cmake code at column 32
Argument not separated from preceding token by whitespace.
C:\Nordic\v1.7.0\nrfxlib\nrf_security\CMakeLists.txt:185 (include)
This warning is for project developers. Use -Wno-dev to suppress it.
CMake Warning at C:\Nordic\v1.7.0\nrfxlib\nrf_802154\sl\sl\CMakeLists.txt:14 (message):
This combination of SoC and floating point ABI is not supported by the
nrf_802154_sl
lib.(C:/Nordic/v1.7.0/nrfxlib/nrf_802154/sl/sl/lib/nRF5340_CPUAPP/hard-float
doesn't exist.)
CMake Warning at C:\Nordic\v1.7.0\zephyr\CMakeLists.txt:1612 (message):
-- Configuring done
-- Generating done
[1/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/camellia.c.obj
[2/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/arc4.c.obj
[3/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/des.c.obj
[4/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/aria.c.obj
[5/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/cipher_wrap.c.obj
[6/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/aesni.c.obj
[7/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/ctr_drbg.c.obj
[8/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/cipher.c.obj
[9/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/asn1parse.c.obj
[10/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/asn1write.c.obj
[11/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/blowfish.c.obj
[12/761] Generating objects/cc3xx.mon
[13/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/base64.c.obj
[14/761] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[15/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/error.c.obj
[16/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/debug.c.obj
[17/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/entropy.c.obj
[18/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/gcm.c.obj
[19/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/entropy_poll.c.obj
[20/761] Creating directories for '802154_rpmsg_subimage'
[21/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/hmac_drbg.c.obj
[22/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/md2.c.obj
[23/761] No download step for '802154_rpmsg_subimage'
[24/761] Generating include/generated/driver-validation.h
[25/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/hkdf.c.obj
[26/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/havege.c.obj
[27/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/md.c.obj
[28/761] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[29/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/nist_kw.c.obj
[30/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/md4.c.obj
[31/761] No update step for '802154_rpmsg_subimage'
[32/761] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[33/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/padlock.c.obj
[34/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/oid.c.obj
[35/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/pkcs12.c.obj
[36/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/md5.c.obj
[37/761] No patch step for '802154_rpmsg_subimage'
[38/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/pk_wrap.c.obj
[39/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/bignum.c.obj
[40/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/pkcs5.c.obj
[41/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/multi_radio_api.cpp.obj
[42/761] No configure step for '802154_rpmsg_subimage'
[42/761] Performing build step for '802154_rpmsg_subimage'
[1/246] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[2/246] Generating include/generated/driver-validation.h
[3/246] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[4/246] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[5/246] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[6/246] Generating include/generated/offsets.h
[7/246] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[8/246] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[9/246] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[10/246] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[11/246] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Nordic/v1.7.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[12/246] Generating linker_zephyr_prebuilt.cmd
[13/246] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[14/246] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[15/246] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[16/246] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[17/246] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[18/246] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[19/246] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[20/246] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[21/246] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[22/246] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[23/246] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[24/246] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[25/246] Linking C static library zephyr\arch\common\libisr_tables.a
[26/246] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[27/246] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[28/246] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[29/246] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[30/246] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[31/246] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/debug.c.obj
[32/246] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[33/246] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[34/246] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[35/246] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[36/246] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[37/246] Linking C static library zephyr\arch\common\libarch__common.a
[38/246] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[39/246] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[40/246] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[41/246] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[42/246] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[43/246] Building C object zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj
[44/246] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
[45/246] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[46/246] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[47/246] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[48/246] Building C object CMakeFiles/app.dir/src/main.c.obj
[49/246] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[50/246] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
[51/246] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[52/246] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[53/246] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[54/246] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[55/246] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[56/246] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[57/246] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[58/246] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[59/246] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[60/246] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[61/246] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[62/246] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[63/246] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[64/246] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[65/246] Linking C static library app\libapp.a
[66/246] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[67/246] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[68/246] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[69/246] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[70/246] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[71/246] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[72/246] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[73/246] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[74/246] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf53/soc.c.obj
[75/246] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[76/246] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[77/246] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[78/246] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/clock_control/clock_control_nrf.c.obj
[79/246] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/rpmsg_service/rpmsg_backend.c.obj
[80/246] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/sys_clock_init.c.obj
[81/246] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/sl_opensource/platform/nrf_802154_gpiote_zephyr.c.obj
[82/246] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/nrf_rtc_timer.c.obj
[83/246] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/rpmsg_service/rpmsg_service.c.obj
[84/246] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/sl_opensource/platform/nrf_802154_irq_zephyr.c.obj
[85/246] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/sl_opensource/platform/nrf_802154_temperature_zephyr.c.obj
[86/246] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/sl_opensource/platform/nrf_802154_lp_timer_zephyr.c.obj
[87/246] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/sl_opensource/platform/nrf_802154_clock_zephyr.c.obj
[88/246] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/serialization/platform/nrf_802154_spinel_response_notifier.c.obj
[89/246] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/serialization/platform/nrf_802154_spinel_log.c.obj
[90/246] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/serialization/platform/nrf_802154_spinel_backend_ipc.c.obj
[91/246] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/serialization/platform/nrf_802154_init_net.c.obj
[92/246] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/serialization/platform/nrf_802154_serialization_crit_sect.c.obj
[93/246] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Nordic/v1.7.0/modules/hal/nordic/nrfx/mdk/system_nrf5340_network.c.obj
[94/246] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Nordic/v1.7.0/modules/hal/nordic/nrfx/drivers/src/nrfx_ipc.c.obj
[95/246] Linking C static library zephyr\libzephyr.a
[96/246] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/irq.c.obj
[97/246] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/dma.c.obj
[98/246] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/init.c.obj
[99/246] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[100/246] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/version.c.obj
[101/246] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/io.c.obj
[102/246] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Nordic/v1.7.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
[103/246] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/device.c.obj
[104/246] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/alloc.c.obj
[105/246] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/shmem.c.obj
[106/246] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/log.c.obj
[107/246] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/condition.c.obj
[108/246] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/device.c.obj
[109/246] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/irq.c.obj
[110/246] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/softirq.c.obj
[111/246] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/init.c.obj
[112/246] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/shmem.c.obj
[113/246] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/log.c.obj
[114/246] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/cortexm/sys.c.obj
[115/246] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/time.c.obj
[116/246] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/version.c.obj
[117/246] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[118/246] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/rpmsg/rpmsg.c.obj
[119/246] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/virtio/virtqueue.c.obj
[120/246] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/rsc_table_parser.c.obj
[121/246] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/virtio/virtio.c.obj
[122/246] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/rpmsg/rpmsg_virtio.c.obj
[123/246] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/remoteproc_virtio.c.obj
[124/246] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/elf_loader.c.obj
[125/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
[126/246] Linking C static library modules\libmetal\libmetal\lib\libmetal.a
[127/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
[128/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
[129/246] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/remoteproc.c.obj
[130/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
[131/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
[132/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_critical_section.c.obj
[133/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_aes_ccm.c.obj
[134/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154.c.obj
[135/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_debug.c.obj
[136/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_core_hooks.c.obj
[137/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_queue.c.obj
[138/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_pib.c.obj
[139/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_peripherals_alloc.c.obj
[140/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_debug_assert.c.obj
[141/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_encrypt.c.obj
[142/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_core.c.obj
[143/246] Linking C static library modules\open-amp\open-amp\lib\libopen_amp.a
[144/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_rx_buffer.c.obj
[145/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_swi.c.obj
[146/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_rssi.c.obj
[147/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_trx.c.obj
[148/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_trx_dppi.c.obj
[149/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_trx_ppi.c.obj
[150/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_stats.c.obj
[151/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_tx_work_buffer.c.obj
[152/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_csma_ca.c.obj
[153/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_ifs.c.obj
[154/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_frame_parser.c.obj
[155/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_filter.c.obj
[156/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_ie_writer.c.obj
[157/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_security_pib_ram.c.obj
[158/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/ack_generator/nrf_802154_ack_generator.c.obj
[159/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/ack_generator/nrf_802154_ack_data.c.obj
[160/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_delayed_trx.c.obj
[161/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_security_writer.c.obj
[162/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_priority_drop_swi.c.obj
[163/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_precise_ack_timeout.c.obj
[164/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_request_swi.c.obj
[165/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_notification_swi.c.obj
[166/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/ack_generator/nrf_802154_imm_ack_generator.c.obj
[167/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/serialization/CMakeFiles/nrf-802154-serialization.dir/src/nrf_802154_buffer_mgr_dst.c.obj
[168/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/serialization/CMakeFiles/nrf-802154-serialization.dir/src/nrf_802154_buffer_allocator.c.obj
[169/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/ack_generator/nrf_802154_enh_ack_generator.c.obj
[170/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/serialization/CMakeFiles/nrf-802154-serialization.dir/src/nrf_802154_spinel_dec.c.obj
[171/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/serialization/CMakeFiles/nrf-802154-serialization.dir/src/nrf_802154_buffer_mgr_src.c.obj
[172/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/serialization/CMakeFiles/nrf-802154-serialization.dir/src/nrf_802154_kvmap.c.obj
[173/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/serialization/CMakeFiles/nrf-802154-serialization.dir/src/nrf_802154_spinel.c.obj
[174/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/serialization/CMakeFiles/nrf-802154-serialization.dir/spinel_base/spinel.c.obj
[175/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/serialization/CMakeFiles/nrf-802154-serialization.dir/src/nrf_802154_spinel_dec_net.c.obj
[176/246] Building C object modules/nrfxlib/nrf_802154/nrf_802154/serialization/CMakeFiles/nrf-802154-serialization.dir/src/nrf_802154_spinel_net.c.obj
[177/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[178/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[179/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[180/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[181/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[182/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[183/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[184/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
[185/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[186/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[187/246] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[188/246] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[189/246] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[190/246] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[191/246] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[192/246] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[193/246] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[194/246] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
[195/246] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[196/246] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
[197/246] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[198/246] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
[199/246] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_nrf5.c.obj
[200/246] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[201/246] Building C object modules/nrf/drivers/mpsl/clock_control/CMakeFiles/..__nrf__drivers__mpsl__clock_control.dir/nrfx_clock_mpsl.c.obj
[202/246] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
[203/246] Building C object modules/nrf/lib/multithreading_lock/CMakeFiles/..__nrf__lib__multithreading_lock.dir/multithreading_lock.c.obj
[204/246] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[205/246] Building C object zephyr/drivers/ipm/CMakeFiles/drivers__ipm.dir/ipm_nrfx_ipc.c.obj
[206/246] Linking C static library zephyr\lib\posix\liblib__posix.a
[207/246] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
[208/246] Building C object modules/nrf/subsys/mpsl/init/CMakeFiles/..__nrf__subsys__mpsl__init.dir/mpsl_init.c.obj
[209/246] Linking C static library modules\nrf\lib\multithreading_lock\lib..__nrf__lib__multithreading_lock.a
[210/246] Building C object modules/nrf/subsys/ieee802154/CMakeFiles/..__nrf__subsys__ieee802154.dir/nrf_802154_configurator.c.obj
[211/246] Linking C static library zephyr\subsys\random\libsubsys__random.a
[212/246] Linking C static library zephyr\drivers\entropy\libdrivers__entropy.a
[213/246] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[214/246] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
[215/246] Building C object modules/nrf/drivers/mpsl/temp_nrf5/CMakeFiles/..__nrf__drivers__mpsl__temp_nrf5.dir/temp_nrf5_mpsl.c.obj
[216/246] Linking C static library zephyr\drivers\ipm\libdrivers__ipm.a
[217/246] Linking C static library modules\nrf\drivers\mpsl\clock_control\lib..__nrf__drivers__mpsl__clock_control.a
[218/246] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/radio/platform/nrf_802154_random_zephyr.c.obj
[219/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
[220/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
[221/246] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/sl_opensource/platform/nrf_802154_gpiote_crit_sect.c.obj
[222/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
[223/246] Linking C static library modules\nrf\subsys\mpsl\init\lib..__nrf__subsys__mpsl__init.a
[224/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
[225/246] Linking C static library modules\nrf\subsys\ieee802154\lib..__nrf__subsys__ieee802154.a
[226/246] Linking C static library modules\nrf\drivers\mpsl\temp_nrf5\lib..__nrf__drivers__mpsl__temp_nrf5.a
[227/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
[228/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
[229/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[230/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[231/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[232/246] Linking C static library modules\hal_nordic\nrf_802154\libnrf-802154-platform.a
[233/246] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[234/246] Linking C static library modules\nrfxlib\nrf_802154\nrf_802154\serialization\libnrf-802154-serialization.a
[235/246] Linking C static library modules\nrfxlib\nrf_802154\nrf_802154\driver\libnrf-802154-driver.a
[236/246] Linking C static library zephyr\kernel\libkernel.a
[237/246] Linking C executable zephyr\zephyr_prebuilt.elf
[238/246] Generating linker.cmd
[239/246] Generating isr_tables.c, isrList.bin
[240/246] Generating dev_handles.c
[241/246] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
[242/246] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
[243/246] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
[244/246] Linking C executable zephyr\zephyr.elf
Memory region Used Size Region Size %age Used
FLASH: 68188 B 256 KB 26.01%
SRAM: 26856 B 64 KB 40.98%
SRAM1: 0 GB 64 KB 0.00%
IDT_LIST: 0 GB 2 KB 0.00%
[245/246] Generating zephyr/app.hex
[246/246] Generating zephyr/merged_CPUNET.hex
[89/761] cmd.exe /C "cd /D C:\Nordic\myApps\CLI_2ndBoard\build_2\modules\openthread\build && C:\Nordic\v1.7.0\toolchain\opt\bin\cmake.exe -DLIST="OPENTHREAD_CONFIG_ASSERT_ENABLE=1;OPENTHREAD_CONFIG_BACKBONE_ROUTER_ENABLE=1;OPENTHREAD_CONFIG_BACKBONE_ROUTER_DUA_NDPROXYING_ENABLE=1;OPENTHREAD_CONFIG_BACKBONE_ROUTER_MULTICAST_ROUTING_ENABLE=1;OPENTHREAD_CONFIG_BORDER_AGENT_ENABLE=1;OPENTHREAD_CONFIG_BORDER_ROUTER_ENABLE=1;OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS=0;OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS_MANAGEMENT=0;OPENTHREAD_CONFIG_CHILD_SUPERVISION_ENABLE=1;OPENTHREAD_CONFIG_COAP_API_ENABLE=1;OPENTHREAD_CONFIG_COAP_SECURE_API_ENABLE=1;OPENTHREAD_CONFIG_COMMISSIONER_ENABLE=1;OPENTHREAD_CONFIG_MAC_CSL_RECEIVER_ENABLE=1;OPENTHREAD_CONFIG_MAC_CSL_AUTO_SYNC_ENABLE=1;OPENTHREAD_CONFIG_DHCP6_CLIENT_ENABLE=1;OPENTHREAD_CONFIG_DHCP6_SERVER_ENABLE=1;OPENTHREAD_CONFIG_DIAG_ENABLE=1;OPENTHREAD_CONFIG_DNS_CLIENT_ENABLE=1;OPENTHREAD_CONFIG_ECDSA_ENABLE=1;OPENTHREAD_CONFIG_DUA_ENABLE=1;OPENTHREAD_CONFIG_MLR_ENABLE=1;OPENTHREAD_CONFIG_HEAP_EXTERNAL_ENABLE=1;OPENTHREAD_CONFIG_IP6_FRAGMENTATION_ENABLE=1;OPENTHREAD_CONFIG_JAM_DETECTION_ENABLE=1;OPENTHREAD_CONFIG_JOINER_ENABLE=1;OPENTHREAD_CONFIG_LINK_RAW_ENABLE=1;OPENTHREAD_CONFIG_MLE_LINK_METRICS_INITIATOR_ENABLE=1;OPENTHREAD_CONFIG_MLE_LINK_METRICS_SUBJECT_ENABLE=1;OPENTHREAD_CONFIG_MAC_FILTER_ENABLE=1;OPENTHREAD_CONFIG_TMF_NETWORK_DIAG_MTD_ENABLE=1;OPENTHREAD_CONFIG_PING_SENDER_ENABLE=1;OPENTHREAD_CONFIG_TMF_NETDATA_SERVICE_ENABLE=1;OPENTHREAD_CONFIG_IP6_SLAAC_ENABLE=1;OPENTHREAD_CONFIG_SNTP_CLIENT_ENABLE=1;OPENTHREAD_CONFIG_UDP_FORWARD_ENABLE=1;OPENTHREAD_SPINEL_CONFIG_RCP_RESTORATION_MAX_COUNT=0;PACKAGE_NAME="OPENTHREAD";OPENTHREAD_CONFIG_THREAD_VERSION=OT_THREAD_VERSION_1_2;OPENTHREAD_CONFIG_NCP_HDLC_ENABLE=1;OPENTHREAD_CONFIG_PLATFORM_CSL_UNCERT=5;KERNEL;__ZEPHYR__=1;_FORTIFY_SOURCE=2;BUILD_VERSION=v2.6.99-ncs1;__LINUX_ERRNO_EXTENSIONS__;USE_PARTITION_MANAGER=1;__PROGRAM_START;NRF5340_XXAA_APPLICATION;NRF_802154_USE_RAW_API=1;NRF_802154_PENDING_SHORT_ADDRESSES=;NRF_802154_PENDING_EXTENDED_ADDRESSES=;NRF_802154_RX_BUFFERS=16;NRF_802154_CCA_CORR_LIMIT_DEFAULT=;NRF_802154_CCA_CORR_THRESHOLD_DEFAULT=;NRF_802154_CCA_ED_THRESHOLD_DEFAULT=;NRF_802154_CSMA_CA_ENABLED=1;NRF_802154_TX_STARTED_NOTIFY_ENABLED=1;NRF_802154_ACK_TIMEOUT_ENABLED=1;NRF_802154_ENCRYPTION_ENABLED=0;NRF_802154_SECURITY_WRITER_ENABLED=0;NRF_802154_IE_WRITER_ENABLED=0;NRF_802154_INTERNAL_RADIO_IRQ_HANDLING=0;PSA_CRYPTO_SECURE;MBEDTLS_CONFIG_FILE="nrf-config.h"" -P C:/Nordic/v1.7.0/modules/lib/openthread/etc/cmake/print.cmake"
PACKAGE_NAME=OPENTHREAD
KERNEL
__ZEPHYR__=1
_FORTIFY_SOURCE=2
__PROGRAM_START
PSA_CRYPTO_SECURE
MBEDTLS_CONFIG_FILE=nrf-config.h
[214/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/link_metrics.cpp.obj
[216/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/lowpan.cpp.obj
[217/761] No install step for '802154_rpmsg_subimage'
[218/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/mesh_forwarder.cpp.obj
[219/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/mesh_forwarder_ftd.cpp.obj
[220/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/mlr_manager.cpp.obj
[221/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/neighbor_table.cpp.obj
[222/761] Completed '802154_rpmsg_subimage'
[223/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_local.cpp.obj
[224/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_publisher.cpp.obj
[225/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_tlvs.cpp.obj
[226/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/mle.cpp.obj
[227/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_leader_ftd.cpp.obj
[228/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_notifier.cpp.obj
[229/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/radio_selector.cpp.obj
[230/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_leader.cpp.obj
[231/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data.cpp.obj
[232/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/time_sync_service.cpp.obj
[233/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_service.cpp.obj
[234/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/mle_router.cpp.obj
[235/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_types.cpp.obj
[236/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/channel_monitor.cpp.obj
[237/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/panid_query_server.cpp.obj
[238/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/router_table.cpp.obj
[239/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/channel_manager.cpp.obj
[240/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/uri_paths.cpp.obj
[241/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/flash.cpp.obj
[242/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/heap.cpp.obj
[243/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/src_match_controller.cpp.obj
[244/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/tmf.cpp.obj
[245/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/history_tracker.cpp.obj
[246/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/lookup_table.cpp.obj
[247/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_diagnostic.cpp.obj
[248/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/thread_netif.cpp.obj
[249/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/otns.cpp.obj
[250/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/child_supervision.cpp.obj
[251/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/srp_client_buffers.cpp.obj
[252/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/topology.cpp.obj
[253/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/parse_cmdline.cpp.obj
[254/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/crypto/ecdsa.cpp.obj
[255/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/crypto/pbkdf2_cmac.cpp.obj
[256/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/crypto/hkdf_sha256.cpp.obj
[257/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/jam_detector.cpp.obj
[258/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/crypto/hmac_sha256.cpp.obj
[259/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/mac/data_poll_handler.cpp.obj
[260/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/crypto/mbedtls.cpp.obj
[261/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/mac/mac_links.cpp.obj
[262/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/slaac_address.cpp.obj
[263/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/ping_sender.cpp.obj
[264/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/crypto/sha256.cpp.obj
[265/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/backbone_router_ftd_api.cpp.obj
[266/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/mac/channel_mask.cpp.obj
[267/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/channel_manager_api.cpp.obj
[268/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/channel_monitor_api.cpp.obj
[269/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/dataset_ftd_api.cpp.obj
[270/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/diags/factory_diags.cpp.obj
[271/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/commissioner_api.cpp.obj
[272/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/backbone_router_api.cpp.obj
[273/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/border_agent_api.cpp.obj
[274/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/border_router_api.cpp.obj
[275/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/dataset_updater_api.cpp.obj
[276/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/child_supervision_api.cpp.obj
[277/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/entropy_api.cpp.obj
[278/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/coap_secure_api.cpp.obj
[279/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/coap_api.cpp.obj
[280/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/error_api.cpp.obj
[281/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/crypto_api.cpp.obj
[282/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/history_tracker_api.cpp.obj
[283/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/dataset_api.cpp.obj
[284/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/diags_api.cpp.obj
[285/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/dns_server_api.cpp.obj
[286/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/dns_api.cpp.obj
[287/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/icmp6_api.cpp.obj
[288/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/heap_api.cpp.obj
[289/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/joiner_api.cpp.obj
[290/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/ip6_api.cpp.obj
[291/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/multi_radio_api.cpp.obj
[292/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/instance_api.cpp.obj
[293/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/jam_detection_api.cpp.obj
[294/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/link_api.cpp.obj
[295/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/netdata_publisher_api.cpp.obj
[296/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/network_time_api.cpp.obj
[297/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/message_api.cpp.obj
[298/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/link_raw_api.cpp.obj
[299/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/logging_api.cpp.obj
[300/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/random_noncrypto_api.cpp.obj
[301/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/random_crypto_api.cpp.obj
[302/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/link_metrics_api.cpp.obj
[303/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/srp_client_api.cpp.obj
[304/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/netdiag_api.cpp.obj
[305/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/tcp_api.cpp.obj
[306/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/netdata_api.cpp.obj
[307/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/srp_server_api.cpp.obj
[308/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/sntp_api.cpp.obj
[309/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/ping_sender_api.cpp.obj
[310/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/thread_ftd_api.cpp.obj
[311/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/backbone_router/backbone_tmf.cpp.obj
[312/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/server_api.cpp.obj
[313/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/srp_client_buffers_api.cpp.obj
[314/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/backbone_router/bbr_local.cpp.obj
[315/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/backbone_router/bbr_manager.cpp.obj
[316/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/backbone_router/ndproxy_table.cpp.obj
[317/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/border_router/router_advertisement.cpp.obj
[318/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/tasklet_api.cpp.obj
[319/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/border_router/infra_if_platform.cpp.obj
[320/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/backbone_router/multicast_listeners_table.cpp.obj
[321/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/border_router/routing_manager.cpp.obj
[322/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/error.cpp.obj
[323/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/backbone_router/bbr_leader.cpp.obj
[324/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/crc16.cpp.obj
[325/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/udp_api.cpp.obj
[326/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/thread_api.cpp.obj
[327/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/coap/coap_secure.cpp.obj
[328/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/random_manager.cpp.obj
[329/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/coap/coap_message.cpp.obj
[330/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/heap_string.cpp.obj
[331/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/instance.cpp.obj
[332/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/string.cpp.obj
[333/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/coap/coap.cpp.obj
[334/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/logging.cpp.obj
[335/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/settings.cpp.obj
[336/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/tlvs.cpp.obj
[337/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/crypto/aes_ecb.cpp.obj
[338/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/message.cpp.obj
[339/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/notifier.cpp.obj
[340/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/channel_manager.cpp.obj
[341/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/crypto/aes_ccm.cpp.obj
[342/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/trickle_timer.cpp.obj
[343/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/time_ticker.cpp.obj
[344/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/time_sync_service.cpp.obj
[345/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/uri_paths.cpp.obj
[346/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/timer.cpp.obj
[347/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/tasklet.cpp.obj
[348/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/commissioner.cpp.obj
[349/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/announce_begin_client.cpp.obj
[350/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/mac/mac_types.cpp.obj
[351/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/tmf.cpp.obj
[352/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/topology.cpp.obj
[353/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/mac/sub_mac_callbacks.cpp.obj
[354/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/energy_scan_client.cpp.obj
[355/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/mac/sub_mac.cpp.obj
[356/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/border_agent.cpp.obj
[357/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/dataset_updater.cpp.obj
[358/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/dataset_local.cpp.obj
[359/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/meshcop_leader.cpp.obj
[360/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/dataset.cpp.obj
[361/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/panid_query_client.cpp.obj
[362/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/dataset_manager.cpp.obj
[363/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/dtls.cpp.obj
[364/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/joiner_router.cpp.obj
[365/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/dataset_manager_ftd.cpp.obj
[366/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/joiner.cpp.obj
[367/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/timestamp.cpp.obj
[368/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/meshcop_tlvs.cpp.obj
[369/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/ip4_address.cpp.obj
[370/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/checksum.cpp.obj
[371/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/dnssd_server.cpp.obj
[372/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/meshcop.cpp.obj
[373/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/dns_client.cpp.obj
[374/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/dhcp6_server.cpp.obj
[375/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/ip6_headers.cpp.obj
[376/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/dhcp6_client.cpp.obj
[377/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/icmp6.cpp.obj
[378/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/nd_agent.cpp.obj
[379/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/ip6_address.cpp.obj
[380/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/ip6_filter.cpp.obj
[381/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/tcp6.cpp.obj
[382/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/socket.cpp.obj
[383/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/dns_types.cpp.obj
[384/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/srp_server.cpp.obj
[385/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/srp_client.cpp.obj
[386/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/ip6_mpl.cpp.obj
[387/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/radio/trel_link.cpp.obj
[388/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/ip6.cpp.obj
[389/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/radio/trel_interface.cpp.obj
[390/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/sntp_client.cpp.obj
[391/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/address_resolver.cpp.obj
[392/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/child_table.cpp.obj
[393/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/netif.cpp.obj
[394/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/radio/radio_platform.cpp.obj
[395/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/radio/radio.cpp.obj
[396/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/radio/trel_packet.cpp.obj
[397/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/indirect_sender.cpp.obj
[398/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/udp6.cpp.obj
[399/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/radio/radio_callbacks.cpp.obj
[400/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/announce_begin_server.cpp.obj
[401/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/csl_tx_scheduler.cpp.obj
[402/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/announce_sender.cpp.obj
[403/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/energy_scan_server.cpp.obj
[404/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/discover_scanner.cpp.obj
[405/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/key_manager.cpp.obj
[406/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/dua_manager.cpp.obj
[407/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/mle_types.cpp.obj
[408/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/mle_router.cpp.obj
[409/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/link_quality.cpp.obj
[410/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/link_metrics.cpp.obj
[411/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/mesh_forwarder_mtd.cpp.obj
[412/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/lowpan.cpp.obj
[413/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/mesh_forwarder.cpp.obj
[414/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/mesh_forwarder_ftd.cpp.obj
[415/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/network_data_publisher.cpp.obj
[416/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/network_data_tlvs.cpp.obj
[417/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/neighbor_table.cpp.obj
[418/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/mlr_manager.cpp.obj
[419/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/network_data_leader_ftd.cpp.obj
[420/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/network_data.cpp.obj
[421/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/network_data_leader.cpp.obj
[422/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/network_data_local.cpp.obj
[423/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/mle.cpp.obj
[424/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/network_data_service.cpp.obj
[425/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/radio_selector.cpp.obj
[426/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/router_table.cpp.obj
[427/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/network_data_notifier.cpp.obj
[428/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/channel_monitor.cpp.obj
[429/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/src_match_controller.cpp.obj
[430/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/flash.cpp.obj
[431/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/heap.cpp.obj
[432/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/otns.cpp.obj
[433/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/history_tracker.cpp.obj
[434/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/network_data_types.cpp.obj
[435/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/panid_query_server.cpp.obj
[436/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/lookup_table.cpp.obj
[437/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/network_diagnostic.cpp.obj
[438/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/parse_cmdline.cpp.obj
[439/761] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp.dir/tcplp.c.obj
[440/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/thread_netif.cpp.obj
[441/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/srp_client_buffers.cpp.obj
[442/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/platform_util.c.obj
[443/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/pk.c.obj
[444/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/child_supervision.cpp.obj
[445/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/pkwrite.c.obj
[446/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/ripemd160.c.obj
[447/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/platform.c.obj
[448/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/version.c.obj
[449/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/timing.c.obj
[450/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/version_features.c.obj
[451/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/jam_detector.cpp.obj
[452/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/xtea.c.obj
[453/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/psa_crypto.c.obj
[454/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/psa_crypto_storage.c.obj
[455/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/pkparse.c.obj
[456/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/psa_crypto_slot_management.c.obj
[457/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/psa_crypto_ecp.c.obj
[458/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/slaac_address.cpp.obj
[459/761] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/ping_sender.cpp.obj
[460/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/C_/Nordic/v1.7.0/mbedtls/library/certs.c.obj
[461/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/psa_crypto_client.c.obj
[462/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/C_/Nordic/v1.7.0/mbedtls/library/pkcs11.c.obj
[463/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/psa_crypto_driver_wrappers.c.obj
[464/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/replacements/pem.c.obj
[465/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/Nordic/v1.7.0/mbedtls/library/psa_crypto_rsa.c.obj
[466/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/C_/Nordic/v1.7.0/mbedtls/library/x509write_csr.c.obj
[467/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/C_/Nordic/v1.7.0/mbedtls/library/x509_csr.c.obj
[468/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/C_/Nordic/v1.7.0/mbedtls/library/x509_crl.c.obj
[469/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/C_/Nordic/v1.7.0/mbedtls/library/net_sockets.c.obj
[470/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/C_/Nordic/v1.7.0/mbedtls/library/x509_create.c.obj
[471/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/C_/Nordic/v1.7.0/mbedtls/library/ssl_cache.c.obj
[472/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/C_/Nordic/v1.7.0/mbedtls/library/x509.c.obj
[473/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/C_/Nordic/v1.7.0/mbedtls/library/platform.c.obj
[474/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/C_/Nordic/v1.7.0/mbedtls/library/ssl_ticket.c.obj
[475/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/C_/Nordic/v1.7.0/mbedtls/library/ssl_cookie.c.obj
[476/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/replacements/ssl_ciphersuites.c.obj
[477/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/cc310/CMakeFiles/mbedcrypto_cc3xx_noglue.dir/C_/Nordic/v1.7.0/mbedtls/library/ecjpake.c.obj
[478/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/C_/Nordic/v1.7.0/mbedtls/library/ssl_cli.c.obj
[479/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedx509.dir/C_/Nordic/v1.7.0/mbedtls/library/x509_crt.c.obj
[480/761] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a
[481/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/C_/Nordic/v1.7.0/mbedtls/library/ssl_srv.c.obj
[482/761] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\mbedtls\libmbedx509.a
[483/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/C_/Nordic/v1.7.0/mbedtls/library/ssl_msg.c.obj
[484/761] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls.dir/C_/Nordic/v1.7.0/mbedtls/library/ssl_tls.c.obj
[485/761] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\mbedtls\libmbedtls.a
[486/761] Linking CXX static library modules\openthread\build\third_party\tcplp\libtcplp.a
[487/761] Linking CXX static library modules\openthread\build\src\core\libopenthread-mtd.a
[488/761] Linking CXX static library modules\openthread\build\src\core\libopenthread-ftd.a
[489/761] Linking CXX static library modules\openthread\build\src\cli\libopenthread-cli-ftd.a
[490/761] Generating include/generated/offsets.h
[491/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[492/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[493/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[494/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[495/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[496/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[497/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[498/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/ring_buffer.c.obj
[499/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[500/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj
[501/761] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[502/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[503/761] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[504/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/util/fnmatch/fnmatch.c.obj
[505/761] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf53/soc.c.obj
[506/761] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf53/power.c.obj
[507/761] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[508/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_list.c.obj
[509/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[510/761] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[511/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_output.c.obj
[512/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg.c.obj
[513/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_fprintf.c.obj
[514/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_dtors.c.obj
[515/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_core.c.obj
[516/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_cmds.c.obj
[517/761] Building CXX object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_vtable.cpp.obj
[518/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_ctors.c.obj
[519/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/devmem_service.c.obj
[520/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/device_service.c.obj
[521/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_init_array.c.obj
[522/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_virtual.c.obj
[523/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/kernel_service.c.obj
[524/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell.c.obj
[525/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_utils.c.obj
[526/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_log_backend.c.obj
[527/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_history.c.obj
[528/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_help.c.obj
[529/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_uart.c.obj
[530/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_wildcard.c.obj
[531/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_cmds.c.obj
[532/761] Building CXX object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_new.cpp.obj
[533/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
[534/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/utils/addr_utils.c.obj
[535/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_ops.c.obj
[536/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/rpmsg_service/rpmsg_backend.c.obj
[537/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/rpmsg_service/rpmsg_service.c.obj
[538/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_line.c.obj
[539/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_nvs.c.obj
[540/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_init.c.obj
[541/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_store.c.obj
[542/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/power.c.obj
[543/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings.c.obj
[544/761] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/nrf_rtc_timer.c.obj
[545/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/nvs/nvs.c.obj
[546/761] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Nordic/v1.7.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[547/761] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Nordic/v1.7.0/nrfxlib/crypto/nrf_cc312_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[548/761] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Nordic/v1.7.0/nrfxlib/crypto/nrf_cc312_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
[549/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy/policy_residency.c.obj
[550/761] Generating linker_zephyr_prebuilt.cmd
[551/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm_ctrl.c.obj
[552/761] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/console/uart_console.c.obj
[553/761] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[554/761] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/sys_clock_init.c.obj
[555/761] Building C object zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj
[556/761] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/clock_control/clock_control_nrf.c.obj
[557/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[558/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[559/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[560/761] Building C object CMakeFiles/app.dir/src/main.c.obj
[561/761] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/ieee802154/ieee802154_nrf5.c.obj
FAILED: zephyr/CMakeFiles/zephyr.dir/drivers/ieee802154/ieee802154_nrf5.c.obj
C:\Nordic\v1.7.0\toolchain\opt\bin\arm-none-eabi-gcc.exe -DBUILD_VERSION=v2.6.99-ncs1 -DKERNEL -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DNRF5340_XXAA_APPLICATION -DNRF_802154_ACK_TIMEOUT_ENABLED=1 -DNRF_802154_CCA_CORR_LIMIT_DEFAULT="" -DNRF_802154_CCA_CORR_THRESHOLD_DEFAULT="" -DNRF_802154_CCA_ED_THRESHOLD_DEFAULT="" -DNRF_802154_CSMA_CA_ENABLED=1 -DNRF_802154_ENCRYPTION_ENABLED=0 -DNRF_802154_IE_WRITER_ENABLED=0 -DNRF_802154_INTERNAL_RADIO_IRQ_HANDLING=0 -DNRF_802154_PENDING_EXTENDED_ADDRESSES="" -DNRF_802154_PENDING_SHORT_ADDRESSES="" -DNRF_802154_RX_BUFFERS=16 -DNRF_802154_SECURITY_WRITER_ENABLED=0 -DNRF_802154_TX_STARTED_NOTIFY_ENABLED=1 -DNRF_802154_USE_RAW_API=1 -DPSA_CRYPTO_SECURE -DUSE_PARTITION_MANAGER=1 -D_FORTIFY_SOURCE=2 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/Nordic/v1.7.0/zephyr/kernel/include -IC:/Nordic/v1.7.0/zephyr/arch/arm/include -IC:/Nordic/v1.7.0/zephyr/include -Izephyr/include/generated -IC:/Nordic/v1.7.0/zephyr/soc/arm/nordic_nrf/nrf53 -IC:/Nordic/v1.7.0/zephyr/lib/libc/newlib/include -IC:/Nordic/v1.7.0/zephyr/lib/util/fnmatch/. -IC:/Nordic/v1.7.0/zephyr/subsys/net/lib/conn_mgr/. -IC:/Nordic/v1.7.0/zephyr/subsys/net/lib/openthread/platform/. -IC:/Nordic/v1.7.0/zephyr/subsys/settings/include -IC:/Nordic/v1.7.0/nrf/include -IC:/Nordic/v1.7.0/modules/hal/cmsis/CMSIS/Core/Include -IC:/Nordic/v1.7.0/modules/hal/nordic/nrfx -IC:/Nordic/v1.7.0/modules/hal/nordic/nrfx/drivers/include -IC:/Nordic/v1.7.0/modules/hal/nordic/nrfx/mdk -IC:/Nordic/v1.7.0/zephyr/modules/hal_nordic/nrfx/. -Imodules/libmetal/libmetal/lib/include -IC:/Nordic/v1.7.0/modules/lib/open-amp/open-amp/lib/include -Imodules/openthread/build/etc/cmake -IC:/Nordic/v1.7.0/modules/lib/openthread/etc/cmake -IC:/Nordic/v1.7.0/modules/lib/openthread/include -IC:/Nordic/v1.7.0/nrfxlib/nrf_802154/serialization/include -IC:/Nordic/v1.7.0/nrfxlib/nrf_802154/serialization/include/platform -IC:/Nordic/v1.7.0/nrfxlib/nrf_802154/serialization/include/serialization -IC:/Nordic/v1.7.0/nrfxlib/nrf_802154/serialization/include/host -Imodules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_generated/mbedtls -Imodules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_generated -Imodules/nrfxlib/nrfxlib/nrf_security/include -IC:/Nordic/v1.7.0/nrfxlib/nrf_security/include -Ic:/Nordic/v1.7.0/mbedtls/library -Ic:/Nordic/v1.7.0/mbedtls/include -Ic:/Nordic/v1.7.0/mbedtls/include/mbedtls -Ic:/Nordic/v1.7.0/mbedtls/include/psa -IC:/Nordic/v1.7.0/nrfxlib/nrf_security/include/mbedcrypto_glue/mbedtls/threading -isystem C:/Nordic/v1.7.0/zephyr/subsys/cpp/include -isystem C:/Nordic/v1.7.0/modules/lib/openthread/zephyr/../include -isystem C:/Nordic/v1.7.0/modules/lib/openthread/zephyr/../examples/platforms -isystem C:/Nordic/v1.7.0/nrfxlib/crypto/nrf_cc312_platform/include -Os -imacros C:/Nordic/myApps/CLI_2ndBoard/build_2/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard -imacros C:/Nordic/v1.7.0/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-address-of-packed-member -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=C:/Nordic/myApps/CLI_2ndBoard=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/Nordic/v1.7.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/Nordic/v1.7.0=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -std=c99 -MD -MT zephyr/CMakeFiles/zephyr.dir/drivers/ieee802154/ieee802154_nrf5.c.obj -MF zephyr\CMakeFiles\zephyr.dir\drivers\ieee802154\ieee802154_nrf5.c.obj.d -o zephyr/CMakeFiles/zephyr.dir/drivers/ieee802154/ieee802154_nrf5.c.obj -c C:/Nordic/v1.7.0/zephyr/drivers/ieee802154/ieee802154_nrf5.c
C:/Nordic/v1.7.0/zephyr/drivers/ieee802154/ieee802154_nrf5.c: In function 'nrf5_stop':
C:\Nordic\v1.7.0\zephyr\drivers\ieee802154\ieee802154_nrf5.c:659:6: warning: implicit declaration of function 'nrf_802154_sleep_if_idle'; did you mean 'nrf_802154_sleep'? [-Wimplicit-function-declaration]
659 | if (nrf_802154_sleep_if_idle() != NRF_802154_SLEEP_ERROR_NONE) {
| nrf_802154_sleep
C:\Nordic\v1.7.0\zephyr\drivers\ieee802154\ieee802154_nrf5.c:659:36: error: 'NRF_802154_SLEEP_ERROR_NONE' undeclared (first use in this function); did you mean 'NRF_802154_RX_ERROR_NONE'?
C:\Nordic\v1.7.0\zephyr\drivers\ieee802154\ieee802154_nrf5.c:659:36: note: each undeclared identifier is reported only once for each function it appears in
C:/Nordic/v1.7.0/zephyr/drivers/ieee802154/ieee802154_nrf5.c: In function 'nrf5_receive_at':
C:\Nordic\v1.7.0\zephyr\drivers\ieee802154\ieee802154_nrf5.c:782:2: warning: implicit declaration of function 'nrf_802154_receive_at'; did you mean 'nrf_802154_receive'? [-Wimplicit-function-declaration]
782 | nrf_802154_receive_at(start - TXTIME_OFFSET_US, TXTIME_OFFSET_US, duration, channel, id);
| nrf_802154_receive
C:/Nordic/v1.7.0/zephyr/drivers/ieee802154/ieee802154_nrf5.c: In function 'nrf5_config_csl_period':
C:\Nordic\v1.7.0\zephyr\drivers\ieee802154\ieee802154_nrf5.c:787:2: warning: implicit declaration of function 'nrf_802154_receive_at_cancel'; did you mean 'nrf_802154_receive_failed'? [-Wimplicit-function-declaration]
787 | nrf_802154_receive_at_cancel(DRX_SLOT_PH);
C:\Nordic\v1.7.0\zephyr\drivers\ieee802154\ieee802154_nrf5.c:790:2: warning: implicit declaration of function 'nrf_802154_csl_writer_period_set' [-Wimplicit-function-declaration]
790 | nrf_802154_csl_writer_period_set(period);
[562/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[563/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[564/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[565/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[566/761] Linking CXX static library app\libapp.a
[567/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[568/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[569/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[570/761] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
FATAL ERROR: command exited with status 1: 'c:\Nordic\v1.7.0\toolchain\opt\bin\cmake.EXE' --build 'c:\Nordic\myApps\CLI_2ndBoard\build_2'
The terminal process terminated with exit code: 1.
I selected "overlay-thread_1_2.conf" in "Kconfig fragment in a new "Generate configuration" screen.  I am using VS code 1,71. I get the error shown above.  If I use the build configuration that does not have a"Kconfig" fragment option selected, the build works fine and I can do the  "Testing communication between kits" and Testing diagnostic module.
  • Hi Dan,
    Try to set "CONFIG_OPENTHREAD_THREAD_VERSION_1_2=y" in your prj.conf instead.
    From The CLI sample documentation: "This optional extension allows you to test available features from the Thread 1.2 Specification. You can enable these features either by activating the overlay extension as described below or by setting Thread 1.2 Specification options."
    Sigurd Hellesvik
  • How exactly do I do this in VS code?
  • Hi
    You go to File -> Open File (Ctrl+O). Then you navigate to the project folder and open prj.conf.
    For example "C:\.something\nrf_connect_sdk\v1.7.0\nrf\samples\openthread\cli"
    Then write the line:
    into the file and save the file.
    Sigurd Hellesvik
    # Copyright (c) 2020 Nordic Semiconductor
    # Logging
    CONFIG_OT_COMMAND_LINE_INTERFACE_LOG_LEVEL_DBG=y
    CONFIG_NET_CONFIG_LOG_LEVEL_INF=y
    # Network shell
    CONFIG_NET_SHELL=y
    CONFIG_SHELL_ARGC_MAX=26
    CONFIG_SHELL_CMD_BUFF_SIZE=416
    # Enable OpenThread features set
    CONFIG_OPENTHREAD_NORDIC_LIBRARY_MASTER=y
    # Default PRNG entropy for nRF53 Series devices is CSPRNG CC312
    # which for that purpose is too slow yet
    # Use Xoroshiro128+ as PRNG
    CONFIG_XOROSHIRO_RANDOM_GENERATOR=y
    # Enable OpenThread 1.2 spec
    I added the bottom 2 lines, I assume this is correct?
    I Pristine built and programmed two nrf5340-DK boards with the same code.
    ot channel 11 for both boards (then checked both boards and channel = 11)
    ot panid 0xabcd   (then checked both boards and panid = 0xabcd)
    ot masterkey 00112233445566778899aabbccddeeff
    This command returns an error: on both boards: Error 35: invalid Command  Will this cause an issue?
    #1 DK board
    ot ifconfig up   feedback: role 0
    ot thread start   feedback: role 1, role 1, role 4
    ot state feedback: leader
    #2 DK board
    ot thread start   feedback: role 1, role 4
    #1 DK board
    ot bbr enable    Feedback: Error 35: invalid command.
    Trying to test the 1.2 spec, What am I doing wrong ?
  • Hi
    Thre OpenThread functionality in nRF Connect SDK is very modular. You will have to enable Backbone router functionality in the configuration to use it.
    See the OpenThread documentation on how to do this.
    Sigurd Hellesvik
