Cannot update modem (nrf9160) with "nrf connect 3.8.0"
Modem DFU failed with error: no matching trait found
Installing older versions eg. 3.7.1 -> have issue with Programmer v2.0.0
Same problem here on Linux:
# nRFConnect System Report - 2021-11-12T13-52-02.755Z
- System: Dell Inc. OptiPlex 7090
- BIOS: Dell Inc. 1.1.25
- CPU: 1 x Intel® Core™ i9-10900 2.8 GHz 20 cores (10 physical)
- Memory: 7 GB free of 31.1 GB total
- Filesystem: /dev/nvme0n1p3 (ext4) 436.4 GB 26.4% used
- OS: Arch Linux (unknown) linux x64
- Versions
- kernel: 5.14.16-arch1-1
- git: 2.33.1
- node: 14.16.0
- python: 3.9.7
- python3: 3.9.7
- Connected devices:
- /dev/ttyACM0: THINGY91_F51EAC28A624
- Current device:
- name: undefined
- serialNumber: THINGY91_F51EAC28A624
- cores: undefined
- website: undefined
Is your device a Thingy:91 or nRF9160 DK? If it is a Thingy, are you trying to update through USB or using an external debug probe? What are you using as external debug probe if that is the case?
The developers are working on fixing this, but in the meantime there are two possible workarounds you can try:
Downgrade nRF Connect for Desktop to 3.7 and installing app versions compatible with 3.7:
Use nrfjprog in a shell to perform the upgrade:
nrfjprog --program <path-to-fw-zip> -s <serial number> --verify
Marte
Hello Marte,
it's a custom board with SWD interface. As I said with nRFConnect 3.7 it is working. So I will stay on this older version and wait fior a fix.
Peter
