nRF Connect SDK undefined reference to nrfx_timer_*
I'm trying to build support for uart async api by adding:
CONFIG_SERIAL=y
CONFIG_UART_ASYNC_API=y
 to my prj.conf.  Without CONFIG_UART_ASYNC_API the app compiles, but uart_callback_set fails (as expected).  When I add CONFIG_UART_ASYNC_API to get support for CONFIG_UART_ASYNC_API, then the build fails with messages like this:
/opt/nordic/ncs/v1.7.1/toolchain/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.bfd: /Users/denis/sandbox/itamar/workspace/zephyr/drivers/serial/uart_nrfx_uarte.c:530: undefined reference to `nrfx_timer_increment'
Do I need something else to get the nrfx timer support?
    I do not get this if I error if I only add the 2 kconfig symbols you mentioned:
    CONFIG_SERIAL=y
    But I do if I also add CONFIG_UART_<instance>_NRF_HW_ASYNC=y. Can you check your .conf file if you may have this enabled (<build directory>\zephyr\.conf)?
    Alternatively, add CONFIG_UART_<uarte instance>_NRF_HW_ASYNC_TIMER=<timer instance>. This configuration should pull in the neccessary dependencies for HW byte counting (i.e. enable NRFX_TIMER and NRFX_PPI).
    Vidar
    Edit:
    Forgot to add that I tested this on the nRF9160, the nRF5340 might have other default settings for the async driver.
  • Hi Vidar,
    Just tried this again and am not seeing the compile error either.  Not sure why.  Maybe because I've done a west update?
    My dts has:
    &uart0 {
    status = "okay";
    current-speed = <115200>;
    tx-pin = <47>;
    rx-pin = <33>;
    and my prj.conf has:
    CONFIG_SERIAL=y
    CONFIG_UART_0_INTERRUPT_DRIVEN=n
    CONFIG_UART_0_ASYNC=y
    CONFIG_UART_0_NRF_HW_ASYNC=y
    CONFIG_UART_0_NRF_HW_ASYNC_TIMER=0
    And now uart_callback_set succeeds!
    This is on an nRF5340 design.
    Do the above prj.conf entries look correct?  Are they all needed?  Is there more I should have in there?  Is there documentation and/or examples of using uarte async somewhere?
    It might have been related to the west update. Good to hear that it works now at least!
    Yes, it looks to be correct. I tried to set up a similiar configuration here, and it worked fine.
    Async UART demo - loopback test:
    5756.async_uart_demo.zip
    We have integrated the async UART driver in our Bluetooth: Peripheral UART sample as well.
    Unfortunately, I could not find any documentation for this driver apart from its API documentation. There is more if you use our Low power UART driver, but this implementation requires routing of 2 extra control lines.
