Power Profiler software returns an error after I updated it to v3.2.0 with nRfConnect v3.8.0.
Error message: Error while probing devices: EnumerateWorker json error
Resulting into non detection of Power Profiler Kit ii
Please help.
Thank you.
Please help.
Thank you.
Have the same issue on macOS 10.15.7, can't revert back to the old version, because if I download nRF Connect 3.7.2, it wants to download and run the new version of the Power Profiler tool, which doesn't work with nRF Connect 3.7.2.
I have reported this internally to the developers, and they are working on it.
Marte
Our developers are still looking into this issue. In the meantime, a temporary workaround is to downgrade to 3.7 and install app versions compatible with 3.7:
I will let you know when the issue is fixed, or if I have any other updates.
Marte
Thank you for providing the work around, reverting back 3.7 version works. While performing the workaround I noticed that the problematic version 3.8.0 of nRF connect is still available for download probably causing many others to run in to this issue. If not already done can the problematic version be removed from Nordic site?
Our developers have found that having a JLink device, such as JLink Lite or JLink Plus debuggers, connected to your computer without the device being connected to anything (DK/SoC), will cause this issue. This will be fixed in a new release of nRF Connect for Desktop. I will notify you when this is released. Until then, their solution is to disconnect all JLink devices that are not connected to anything.
Marte
