I am in the conceptual stages of development for a BLE test system.
The test system requires:
Fast transceiver and connection with BLE devices, preferably capable of scanning for devices in ms (5ms or lower preferably) with a high data rate (1 Mbps).
Capable of calculating the BLE channel received and controlling the BLE channel used.
Controlled modulated RF wave transmission (optional).
The test requires the capability to communicate and connect with 6 devices in parallel, is the nRF52840 capable of connecting with multiple devices?
I am planning to create a PCB using the nRF52840 chip or similar which fits the requirements. Can multiple (up to 6 depending on the number of devices that can be connected) nRF52840 dongle with PCB Altium documents provided by Nordicsemi be used on one larger PCB without interference? the BLE circuits will; share solid inner layer ground and power sources with the ground vias placed close to the pins, be located close to the edge of the PCB, be routed to avoid noise on Vcc and the area of the antennas will have a keep out area with no traces or metal near. The PCB dielectric thickness will match that of the nRF52840 dongle to prevent an effect on the antenna.
Can an external antenna then be added to the PCB using an SWF or similar surface mount RF connector?
