nrf52832 uart tx works only with NRF_UARTE0 read after EndTx
FormerMember
FormerMember
Greetings, There is a bit of strange operation in UARTE peripheral in nrf52832 with the DK. In the simple code below, if both of the if statements with comments 'Check 1' and 'Check 2' are removed the 'hello' prints are not sent and I get some junk value. If either of the two reads to the UARTE registers is made in these if statement, then the 'hello' prints are sent out correctly. What's happening? I don't see any errata related to UARTE peripheral.
Thanks.
Toolchain: GCC 4.9.3q2 on Linux
#include <stdbool.h>
#include <stdint.h>
#include "nrf_delay.h"
#include "nrf52-gpio.h"
#include "nrf52-clock.h"
#include "board.h"
#include "nrf52-uart.h"
	nrf_gpio_cfg_output(LED1);
	nrf_gpio_cfg_output(LED2);
	nrf_gpio_cfg_output(LED3);
	nrf_gpio_cfg_output(LED4);
	/* Configure TX and RX pins from board.h */
	nrf_gpio_cfg_output(TX_PIN_NUMBER);
	nrf_gpio_cfg_input(RX_PIN_NUMBER, GPIO_PIN_CNF_PULL_Disabled);
	NRF_UARTE0->PSEL.TXD = TX_PIN_NUMBER;
	NRF_UARTE0->PSEL.RTS = RX_PIN_NUMBER;
	nrf_gpio_cfg_output(RTS_PIN_NUMBER);
	nrf_gpio_cfg_input(CTS_PIN_NUMBER, GPIO_PIN_CNF_PULL_Disabled);
	NRF_UARTE0->PSEL.RTS = RTS_PIN_NUMBER;
	NRF_UARTE0->PSEL.CTS = CTS_PIN_NUMBER;
	NRF_UARTE0->CONFIG = (UARTE_CONFIG_HWFC_Enabled << UARTE_CONFIG_HWFC_Pos);
	/* Configure other UART parameters, BAUD rate is defined in nrf52-uart.h	*/
	NRF_UARTE0->BAUDRATE = (UARTE_BAUDRATE << UARTE_BAUDRATE_BAUDRATE_Pos);
	NRF_UARTE0->ENABLE = (UARTE_ENABLE_ENABLE_Enabled << UARTE_ENABLE_ENABLE_Pos);
    // Toggle LEDs.
    while (true)
    	uint32_t i;
        for (i = 0; i < 2; i++)
        	if(i){
        		NRF_P0->OUTSET = (1<<LED1);
        	} else {
        		NRF_P0->OUTCLR = (1<<LED1);
        	nrf_delay_ms(500);
            uint8_t str[] = "hello\n";
            uint32_t len = 6;
            NRF_UARTE0->EVENTS_ENDTX = 0;
            NRF_UARTE0->TASKS_STOPTX = 0;
        	NRF_UARTE0->TXD.PTR = (uint32_t)((uint8_t *) str);
        	NRF_UARTE0->TXD.MAXCNT = (uint32_t) len;
        	NRF_UARTE0->TASKS_STARTTX = 1;
        	while((0 == NRF_UARTE0->EVENTS_ENDTX)&&(0 == NRF_UARTE0->EVENTS_TXSTOPPED)){}
            /*****Check 1*****/
        	if(NRF_UARTE0->EVENTS_ENDTX){
        		NRF_P0->OUTSET = (1<<LED3);
            /*****Check 2*****/
        	if(6 == NRF_UARTE0->TXD.AMOUNT){
        		NRF_P0->OUTSET = (1<<LED2);
  • And the answer - which I have come around to believing, is the code falls into 'implementation dependent' and gcc is within its rights to decide that string isn't used and remove it.
    Since the code was a piece of test code and not something anyone would be likely to write for real, initialized string on the stack going to a register and then wait for it to clock out, I don't think it's going to be a huge problem. It was however an interesting intellectual exercise.
  • FormerMember
    0 FormerMember in reply to RK
    Thanks a ton for following up with the question and diving so deep for this. And even though there are some bits of unanswered parts, I guess we can rest in peace that this should bother any driver implementations.
