Error when trying to enable extended advertising on code based on NUS example
I'm working on an nRF5340 project using nRF Connect SDK v1.7.0 with VS Code. I started my project with the NUS example.
I've been able to customize the standard/legacy advertising packets as required by my customer with no problem using bt_le_adv_start(), but they also want me to be able to use extended advertising in certain circumstances.
In order to do that I see that I have to not only switch to calling bt_le_ext_adv_start, but also create an advertising set using bt_le_ext_adv_create. I found an example that does that for reference (iso_broadcast), but when I call bt_le_ext_adv_create I get a -5 return code (-EIO).
The full sequence of calls is bt_le_ext_adv_create calls le_ext_adv_param_set, which calls bt_hci_cmd_send_sync(BT_HCI_OP_LE_SET_EXT_ADV_PARAM, buf, &rsp);
The send_sync function gets a 1  from this call: status = cmd(buf)->status;
That causes the function to send the -5 back up the chain.
What am I doing wrong?
Glen
