Well, this one took me many hours of tracing to track down the root cause, so I hope it helps someone!
Note: I wasn't able to reproduce this directly with a sample included in the nRF Connect SDK. But it happens with my application, based on the "light_ctrl" mesh sample.
It occurs with the following 3-way combination (tested, only if all met);
I also had to enable CONFIG_BT_LL_SW_SPLIT=y for zephyr controller to be able to fit in the flash of the nRF52833DK I'm using, but not sure if this is related (yes I intend to move to the soft device and know it is now recommended).
To fix I've changed to CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=y
I've found these two issues which appear to have similar failure logs;
https://github.com/zephyrproject-rtos/zephyr/pull/25583
https://devzone.nordicsemi.com/f/nordic-q-a/76899/zephyr-build-smp_svr-for-thingy52-fails
Build error log below
Kevin
C:\freelance\git\pt118b_firmware>west build --pristine --board pt118a_nrf52833_3-1_3A --build-dir build-release_pt118a-3-1-3A -- -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=On -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -- west build: making build dir C:\freelance\git\pt118b_firmware\build-release_pt118a-3-1-3A pristine -- west build: generating a build system Including boilerplate (Zephyr base): C:/freelance/ncs/v1.7.1/zephyr/cmake/app/boilerplate.cmake -- Application: C:/freelance/git/pt118b_firmware -- Zephyr version: 2.6.99 (C:/freelance/ncs/v1.7.1/zephyr), build: v2.6.99-ncs1-1 -- Found Python3: C:/freelance/ncs/v1.7.1/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter -- Found west (found suitable version "0.11.1", minimum required is "0.7.1") -- Board: pt118a_nrf52833_3-1_3A -- Cache files will be written to: C:/freelance/ncs/v1.7.1/zephyr/.cache -- Found dtc: C:/freelance/ncs/v1.7.1/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6") -- Found toolchain: gnuarmemb (C:/freelance/ncs/v1.7.1/toolchain/opt) -- Found BOARD.dts: C:/freelance/git/pt118b_firmware/boards/arm/pt118a_nrf52833_3-1_3A/pt118a_nrf52833_3-1_3A.dts -- Generated zephyr.dts: C:/freelance/git/pt118b_firmware/build-release_pt118a-3-1-3A/zephyr/zephyr.dts -- Generated devicetree_unfixed.h: C:/freelance/git/pt118b_firmware/build-release_pt118a-3-1-3A/zephyr/include/generated/devicetree_unfixed.h -- Generated device_extern.h: C:/freelance/git/pt118b_firmware/build-release_pt118a-3-1-3A/zephyr/include/generated/device_extern.h -- Including generated dts.cmake file: C:/freelance/git/pt118b_firmware/build-release_pt118a-3-1-3A/zephyr/dts.cmake Parsing C:/freelance/ncs/v1.7.1/zephyr/Kconfig Loaded configuration 'C:/freelance/git/pt118b_firmware/boards/arm/pt118a_nrf52833_3-1_3A/pt118a_nrf52833_3-1_3A_defconfig' Merged configuration 'C:/freelance/git/pt118b_firmware/prj.conf' Configuration saved to 'C:/freelance/git/pt118b_firmware/build-release_pt118a-3-1-3A/zephyr/.config' Kconfig header saved to 'C:/freelance/git/pt118b_firmware/build-release_pt118a-3-1-3A/zephyr/include/generated/autoconf.h' -- The C compiler identification is GNU 9.2.1 -- The CXX compiler identification is GNU 9.2.1 -- The ASM compiler identification is GNU -- Found assembler: C:/freelance/ncs/v1.7.1/toolchain/opt/bin/arm-none-eabi-gcc.exe === child image mcuboot - begin === Including boilerplate (Zephyr base): C:/freelance/ncs/v1.7.1/zephyr/cmake/app/boilerplate.cmake -- Application: C:/freelance/ncs/v1.7.1/bootloader/mcuboot/boot/zephyr -- Zephyr version: 2.6.99 (C:/freelance/ncs/v1.7.1/zephyr), build: v2.6.99-ncs1-1 -- Found Python3: C:/freelance/ncs/v1.7.1/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter -- Found west (found suitable version "0.11.1", minimum required is "0.7.1") -- Board: pt118a_nrf52833_3-1_3A -- Cache files will be written to: C:/freelance/ncs/v1.7.1/zephyr/.cache -- Found dtc: C:/freelance/ncs/v1.7.1/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6") -- Found toolchain: gnuarmemb (C:/freelance/ncs/v1.7.1/toolchain/opt) -- Found BOARD.dts: C:/freelance/git/pt118b_firmware/boards/arm/pt118a_nrf52833_3-1_3A/pt118a_nrf52833_3-1_3A.dts -- Found devicetree overlay: C:/freelance/ncs/v1.7.1/bootloader/mcuboot/boot/zephyr/dts.overlay -- Generated zephyr.dts: C:/freelance/git/pt118b_firmware/build-release_pt118a-3-1-3A/mcuboot/zephyr/zephyr.dts -- Generated devicetree_unfixed.h: C:/freelance/git/pt118b_firmware/build-release_pt118a-3-1-3A/mcuboot/zephyr/include/generated/devicetree_unfixed.h -- Generated device_extern.h: C:/freelance/git/pt118b_firmware/build-release_pt118a-3-1-3A/mcuboot/zephyr/include/generated/device_extern.h -- Including generated dts.cmake file: C:/freelance/git/pt118b_firmware/build-release_pt118a-3-1-3A/mcuboot/zephyr/dts.cmake warning: The choice symbol BT_CTLR_TX_PWR_PLUS_8 (defined at subsys/bluetooth\controller/Kconfig:210) was selected (set =y), but no symbol ended up as the choice selection. See http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_BT_CTLR_TX_PWR_PLUS_8.html and/or look up BT_CTLR_TX_PWR_PLUS_8 in the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too. Parsing C:/freelance/ncs/v1.7.1/bootloader/mcuboot/boot/zephyr/Kconfig Loaded configuration 'C:/freelance/git/pt118b_firmware/boards/arm/pt118a_nrf52833_3-1_3A/pt118a_nrf52833_3-1_3A_defconfig' Merged configuration 'C:/freelance/ncs/v1.7.1/bootloader/mcuboot/boot/zephyr/prj.conf' Merged configuration 'C:/freelance/ncs/v1.7.1/nrf/subsys/partition_manager/partition_manager_enabled.conf' Configuration saved to 'C:/freelance/git/pt118b_firmware/build-release_pt118a-3-1-3A/mcuboot/zephyr/.config' Kconfig header saved to 'C:/freelance/git/pt118b_firmware/build-release_pt118a-3-1-3A/mcuboot/zephyr/include/generated/autoconf.h' -- The C compiler identification is GNU 9.2.1 -- The CXX compiler identification is GNU 9.2.1 -- The ASM compiler identification is GNU -- Found assembler: C:/freelance/ncs/v1.7.1/toolchain/opt/bin/arm-none-eabi-gcc.exe MCUBoot bootloader key file: C:/freelance/ncs/v1.7.1/bootloader/mcuboot/root-rsa-2048.pem -- Configuring done -- Generating done -- Build files have been written to: C:/freelance/git/pt118b_firmware/build-release_pt118a-3-1-3A/mcuboot === child image mcuboot - end === CMake Warning at C:/freelance/ncs/v1.7.1/nrf/modules/mcuboot/CMakeLists.txt:204 (message): --------------------------------------------------------- --- WARNING: Using default MCUBoot key, it should not --- --- be used for production. --- --------------------------------------------------------- -- Configuring done -- Generating done -- Build files have been written to: C:/freelance/git/pt118b_firmware/build-release_pt118a-3-1-3A -- west build: building application [5/319] Performing build step for 'mcuboot_subimage' [250/257] Linking C executable zephyr\zephyr_prebuilt.elf FAILED: zephyr/zephyr_prebuilt.elf zephyr/zephyr_prebuilt.map cmd.exe /C "cd . && C:\freelance\ncs\v1.7.1\toolchain\opt\bin\arm-none-eabi-gcc.exe zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj -o zephyr\zephyr_prebuilt.elf -Wl,-T zephyr/linker_zephyr_prebuilt.cmd -Wl,-Map=C:/freelance/git/pt118b_firmware/build-release_pt118a-3-1-3A/mcuboot/zephyr/zephyr_prebuilt.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/lib/posix/liblib__posix.a zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a zephyr/boards/boards/arm/pt118a_nrf52833_3-1_3A/lib..__..__..__git__pt118b_firmware__boards__arm__pt118a_nrf52833_3-1_3A.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/sensor/nrf5/libdrivers__sensor__nrf5.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/serial/libdrivers__serial.a modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a modules/mbedtls/libmodules__mbedtls.a modules/segger/libmodules__segger.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -L"c:/freelance/ncs/v1.7.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/thumb/v7e-m/nofp" -LC:/freelance/git/pt118b_firmware/build-release_pt118a-3-1-3A/mcuboot/zephyr -lgcc zephyr/arch/common/libisr_tables.a -mcpu=cortex-m4 -mthumb -mabi=aapcs -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -no-pie -Wl,-X -Wl,-N -Wl,--orphan-handling=warn && cmd.exe /C "cd /D C:\freelance\git\pt118b_firmware\build-release_pt118a-3-1-3A\mcuboot\zephyr && C:\freelance\ncs\v1.7.1\toolchain\opt\bin\cmake.exe -E echo "" c:/freelance/ncs/v1.7.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: zephyr/drivers/sensor/nrf5/libdrivers__sensor__nrf5.a(temp_nrf5.c.obj): in function `k_sem_give': C:\freelance\git\pt118b_firmware\build-release_pt118a-3-1-3A\mcuboot/zephyr/include/generated/syscalls/kernel.h:841: undefined reference to `z_impl_k_sem_give' c:/freelance/ncs/v1.7.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: zephyr/drivers/sensor/nrf5/libdrivers__sensor__nrf5.a(temp_nrf5.c.obj): in function `k_sem_init': C:\freelance\git\pt118b_firmware\build-release_pt118a-3-1-3A\mcuboot/zephyr/include/generated/syscalls/kernel.h:810: undefined reference to `z_impl_k_sem_init' c:/freelance/ncs/v1.7.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: zephyr/drivers/sensor/nrf5/libdrivers__sensor__nrf5.a(temp_nrf5.c.obj): in function `k_mutex_init': C:\freelance\git\pt118b_firmware\build-release_pt118a-3-1-3A\mcuboot/zephyr/include/generated/syscalls/kernel.h:708: undefined reference to `z_impl_k_mutex_init' c:/freelance/ncs/v1.7.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: zephyr/drivers/sensor/nrf5/libdrivers__sensor__nrf5.a(temp_nrf5.c.obj): in function `k_mutex_lock': C:\freelance\git\pt118b_firmware\build-release_pt118a-3-1-3A\mcuboot/zephyr/include/generated/syscalls/kernel.h:724: undefined reference to `z_impl_k_mutex_lock' c:/freelance/ncs/v1.7.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: zephyr/drivers/sensor/nrf5/libdrivers__sensor__nrf5.a(temp_nrf5.c.obj): in function `k_sem_take': C:\freelance\git\pt118b_firmware\build-release_pt118a-3-1-3A\mcuboot/zephyr/include/generated/syscalls/kernel.h:826: undefined reference to `z_impl_k_sem_take' c:/freelance/ncs/v1.7.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: zephyr/drivers/sensor/nrf5/libdrivers__sensor__nrf5.a(temp_nrf5.c.obj): in function `k_mutex_unlock': C:\freelance\git\pt118b_firmware\build-release_pt118a-3-1-3A\mcuboot/zephyr/include/generated/syscalls/kernel.h:738: undefined reference to `z_impl_k_mutex_unlock' collect2.exe: error: ld returned 1 exit status ninja: build stopped: subcommand failed. [212/319] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/adv.c.obj FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf cmd.exe /C "cd /D C:\freelance\git\pt118b_firmware\build-release_pt118a-3-1-3A\mcuboot && C:\freelance\ncs\v1.7.1\toolchain\opt\bin\cmake.exe --build . --" [218/319] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/gatt.c.obj ninja: build stopped: subcommand failed. FATAL ERROR: command exited with status 1: 'C:\freelance\ncs\v1.7.1\toolchain\opt\bin\cmake.EXE' --build 'C:\freelance\git\pt118b_firmware\build-release_pt118a-3-1-3A'
I later found the _SYNTH clock causes us issues with provisioning, so maybe this isn't the best approach! It may be better to solve the build issues with the _RC clock.
Yes, I think it would definitely be best to solve the build issue with the RC clock. The issue has been reported internally, and we are looking for a solution.
Regards,Terje
Identical (or very similar) bug is also tracked here - https://github.com/zephyrproject-rtos/zephyr/issues/40538
I also filed a private support case with Nordic and got some more info;
Okay, so it might not be due to a bug after all, but rather that the calibration routine for the 32kHz clock was changed (in nRFConnect SDk v1.6.0 I think). Basically, the 32kHz requires a calibration routine that depends on multithreading. So you will need to enable multithreading or disable the calibration in the sub-image that's not compiling. The temp_nrf5 files doesn't seem to handle calibration, but they do require multithreading, so please try enabling that in your application. I would think one of the configs CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=n or CONFIG_MULTITHREADING=y would be sufficient here
I ended up solving with CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=n to avoid the size overhead of multithreading. However someone on the Zephyr bug does say this isn't recommended. I'm not sure why but will post there.
Note: this only needs to be set for the MCUBOOT image, not the main image, i.e. adding to a \child_image\mcuboot.conf as per https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/ug_multi_image.html which then merges with the default MCUBOOT configuration.
Thank you very much for the update!Yes, I mentioned there that it isn't recommended, because the Zephyr docs say so: "If calibration is disabled when RC is used for low frequency clock then accuracy of the low frequency clock will degrade. Disable on your own risk.".
This makes sense for a functionality that requires higher precision clock like BLE, but I guess it's OK to use it in mcuboot (that's only my impression - feel free to correct me).I think I found the problem - https://github.com/mcu-tools/mcuboot/blob/main/boot/zephyr/Kconfig#L682
