app_error_weak.c, 105, Mesh assert at 0x0002C628 (:0)
I have a question. I want to send continuous data in light-switch example,but it say  app_error_weak.c,  105, Mesh assert at 0x0002C628 (:0) how can i fix it?
main file is follow
#include <stdint.h>
#include <string.h>
/* HAL */
#include "boards.h"
#include "simple_hal.h"
#include "app_timer.h"
/* Core */
#include "nrf_mesh_config_core.h"
#include "nrf_mesh_gatt.h"
#include "nrf_mesh_configure.h"
#include "nrf_mesh.h"
#include "mesh_stack.h"
#include "device_state_manager.h"
#include "access_config.h"
/* Provisioning and configuration */
#include "mesh_provisionee.h"
#include "mesh_app_utils.h"
/* Models */
#include "generic_onoff_client.h"
/* Logging and RTT */
#include "log.h"
#include "rtt_input.h"
/* Example specific includes */
#include "app_config.h"
#include "nrf_mesh_config_examples.h"
#include "light_switch_example_common.h"
#include "example_common.h"
#include "ble_softdevice_support.h"
#include "nrf_delay.h"
#include "app_scheduler.h"
* Definitions
#define APP_STATE_OFF (0)
#define APP_STATE_ON (1)
#define APP_UNACK_MSG_REPEAT_COUNT (2)
/* Controls if the model instance should force all mesh messages to be segmented messages. */
#define APP_FORCE_SEGMENTATION (false)
/* Controls the MIC size used by the model instance for sending the mesh messages. */
#define APP_MIC_SIZE (NRF_MESH_TRANSMIC_SIZE_SMALL)
/* Delay value used by the OnOff client for sending OnOff Set messages. */
#define APP_ONOFF_DELAY_MS (50)
/* Transition time value used by the OnOff client for sending OnOff Set messages. */
#define APP_ONOFF_TRANSITION_TIME_MS (100)
* Forward declaration of static functions
static void app_gen_onoff_client_publish_interval_cb(access_model_handle_t handle, void * p_self);
static void app_generic_onoff_client_status_cb(const generic_onoff_client_t * p_self,
const access_message_rx_meta_t * p_meta,
const generic_onoff_status_params_t * p_in);
static void app_gen_onoff_client_transaction_status_cb(access_model_handle_t model_handle,
void * p_args,
access_reliable_status_t status);
* Static variables
static generic_onoff_client_t m_clients[CLIENT_MODEL_INSTANCE_COUNT];
static bool m_device_provisioned;
const generic_onoff_client_callbacks_t client_cbs =
.onoff_status_cb = app_generic_onoff_client_status_cb,
.ack_transaction_status_cb = app_gen_onoff_client_transaction_status_cb,
.periodic_publish_cb = app_gen_onoff_client_publish_interval_cb
static void device_identification_start_cb(uint8_t attention_duration_s)
hal_led_mask_set(HAL_LED_MASK, false);
hal_led_blink_ms(HAL_LED_MASK_HALF,
LED_BLINK_ATTENTION_INTERVAL_MS,
LED_BLINK_ATTENTION_COUNT(attention_duration_s));
static void provisioning_aborted_cb(void)
hal_led_blink_stop();
static void unicast_address_print(void)
dsm_local_unicast_address_t node_address;
dsm_local_unicast_addresses_get(&node_address);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Node Address: 0x%04x \n", node_address.address_start);
static void provisioning_complete_cb(void)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully provisioned\n");
#if MESH_FEATURE_GATT_ENABLED
/* Restores the application parameters after switching from the Provisioning
* service to the Proxy */
gap_params_init();
conn_params_init();
unicast_address_print();
hal_led_mask_set(HAL_LED_MASK, LED_MASK_STATE_OFF);
hal_led_blink_ms(HAL_LED_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_PROV);
/* This callback is called periodically if model is configured for periodic publishing */
__LOG(LOG_SRC_APP, LOG_LEVEL_WARN, "Publish desired message here.\n");
/* Acknowledged transaction status callback, if acknowledged transfer fails, application can
* determine suitable course of action (e.g. re-initiate previous transaction) by using this
* callback.
void * p_args,
switch(status)
case ACCESS_RELIABLE_TRANSFER_SUCCESS:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer success.\n"); // auto no add
case ACCESS_RELIABLE_TRANSFER_TIMEOUT:
hal_led_blink_ms(HAL_LED_MASK, LED_BLINK_SHORT_INTERVAL_MS, LED_BLINK_CNT_NO_REPLY);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer timeout.\n");
case ACCESS_RELIABLE_TRANSFER_CANCELLED:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer cancelled.\n");
ERROR_CHECK(NRF_ERROR_INTERNAL);
/* Generic OnOff client model interface: Process the received status message in this callback */
if (p_in->remaining_time_ms > 0)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "OnOff server: 0x%04x, Present OnOff: %d, Target OnOff: %d, Remaining Time: %d ms\n",
p_meta->src.value, p_in->present_on_off, p_in->target_on_off, p_in->remaining_time_ms);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "OnOff server: 0x%04x, Present OnOff: %d\n",
p_meta->src.value, p_in->present_on_off);
static void node_reset(void)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Node reset -----\n");
hal_led_blink_ms(HAL_LED_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_RESET);
/* This function may return if there are ongoing flash operations. */
mesh_stack_device_reset();
static void config_server_evt_cb(const config_server_evt_t * p_evt)
if (p_evt->type == CONFIG_SERVER_EVT_NODE_RESET)
node_reset();
#if NRF_MESH_LOG_ENABLE
static const char m_usage_string[] =
"\n"
"\t\t------------------------------------------------------------------------------------\n"
"\t\t Button/RTT 1) Send a message to the odd group (address: 0xC003) to turn on LED 1.\n"
"\t\t Button/RTT 2) Send a message to the odd group (address: 0xC003) to turn off LED 1.\n"
"\t\t Button/RTT 3) Send a message to the even group (address: 0xC002) to turn on LED 1.\n"
"\t\t Button/RTT 4) Send a message to the even group (address: 0xC002) to turn off LED 1.\n"
"\t\t------------------------------------------------------------------------------------\n";
static void button_event_handler(uint32_t button_number)
/* Increase button number because the buttons on the board is marked with 1 to 4 */
button_number++;
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number);
uint32_t status = NRF_SUCCESS;
generic_onoff_set_params_t set_params;
model_transition_t transition_params;
static uint8_t tid = 0;
switch(button_number)
case 1:
case 3:
set_params.on_off = APP_STATE_ON;
case 2:
case 4:
set_params.on_off = APP_STATE_OFF;
/*case 1:
set_params.on_off = !hal_led_pin_get(BSP_LED_0 + button_number);
case 2:
case 3:
case 4:
break;*/
set_params.tid = tid++;
transition_params.delay_ms = APP_ONOFF_DELAY_MS;
transition_params.transition_time_ms = APP_ONOFF_TRANSITION_TIME_MS;
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Sending msg: ONOFF SET %d\n", set_params.on_off);
switch (button_number)
case 1:
case 2:
/* Demonstrate acknowledged transaction, using 1st client model instance */
/* In this examples, users will not be blocked if the model is busy */
(void)access_model_reliable_cancel(m_clients[0].model_handle);
status = generic_onoff_client_set(&m_clients[0], &set_params, &transition_params); // have problem
hal_led_pin_set(BSP_LED_0, set_params.on_off);
case 3:
case 4:
/* Demonstrate un-acknowledged transaction, using 2nd client model instance */
status = generic_onoff_client_set_unack(&m_clients[1], &set_params,&transition_params, APP_UNACK_MSG_REPEAT_COUNT); // have problem
hal_led_pin_set(BSP_LED_1, set_params.on_off);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, m_usage_string);
switch (status)
case NRF_SUCCESS:
case NRF_ERROR_NO_MEM:
case NRF_ERROR_BUSY:
case NRF_ERROR_INVALID_STATE:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Client %u cannot send\n", button_number);
case NRF_ERROR_INVALID_PARAM:
/* Publication not enabled for this client. One (or more) of the following is wrong:
* - An application key is missing, or there is no application key bound to the model
* - The client does not have its publication state set
* It is the provisioner that adds an application key, binds it to the model and sets
* the model's publication state.
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Publication not configured for client %u\n", button_number);
ERROR_CHECK(status);
static void rtt_input_handler(int key)
if (key >= '1' && key <= '4')
uint32_t button_number = key - '1';
button_event_handler(button_number);
static void models_init_cb(void)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing and adding models\n");
for (uint32_t i = 0; i < CLIENT_MODEL_INSTANCE_COUNT; ++i)
m_clients[i].settings.p_callbacks = &client_cbs;
m_clients[i].settings.timeout = 0;
m_clients[i].settings.force_segmented = APP_FORCE_SEGMENTATION;
m_clients[i].settings.transmic_size = APP_MIC_SIZE;
ERROR_CHECK(generic_onoff_client_init(&m_clients[i], i + 1));
static void mesh_init(void)
mesh_stack_init_params_t init_params =
.core.irq_priority = NRF_MESH_IRQ_PRIORITY_LOWEST,
.core.lfclksrc = DEV_BOARD_LF_CLK_CFG,
.core.p_uuid = NULL,
.models.models_init_cb = models_init_cb,
.models.config_server_cb = config_server_evt_cb
uint32_t status = mesh_stack_init(&init_params, &m_device_provisioned);
switch (status)
case NRF_ERROR_INVALID_DATA:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Data in the persistent memory was corrupted. Device starts as unprovisioned.\n");
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Reboot device before starting of the provisioning process.\n");
case NRF_SUCCESS:
static void initialize(void)
__LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS | LOG_SRC_BEARER, LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Switch Client Demo -----\n");
ERROR_CHECK(app_timer_init());
hal_leds_init();
#if BUTTON_BOARD
ERROR_CHECK(hal_buttons_init(button_event_handler));
ble_stack_init();
gap_params_init();
conn_params_init();
mesh_init();
static void start(void)
rtt_input_enable(rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
if (!m_device_provisioned)
static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
mesh_provisionee_start_params_t prov_start_params =
.p_static_data = static_auth_data,
.prov_sd_ble_opt_set_cb = NULL,
.prov_complete_cb = provisioning_complete_cb,
.prov_device_identification_start_cb = device_identification_start_cb,
.prov_device_identification_stop_cb = NULL,
.prov_abort_cb = provisioning_aborted_cb,
.p_device_uri = EX_URI_LS_CLIENT
ERROR_CHECK(mesh_provisionee_prov_start(&prov_start_params));
mesh_app_uuid_print(nrf_mesh_configure_device_uuid_get());
ERROR_CHECK(mesh_stack_start());
hal_led_blink_ms(HAL_LED_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_START);
initialize();
start();
for (;;)
(void)sd_app_evt_wait();
rtt_input_handler('1');
nrf_delay_ms(1000);
rtt_input_handler('2');
nrf_delay_ms(1000);
rtt_input_handler('3');
nrf_delay_ms(1000);
rtt_input_handler('4');
nrf_delay_ms(1000);
    Note that bluetooth mesh is not optimal for sending/streaming a lot of data. In the Mesh documentation from our Infocenter:
    "Bluetooth Mesh primarily targets simple control and monitoring applications, like light control or sensor data gathering. The packet format is optimized for small control packets, issuing single commands or reports, and is not intended for data streaming or other high-bandwidth applications."
    What is your use-case? Depending on your application, bluetooth mesh might not be for you.
    What mesh SDK version are you using? You can use addr2line tool to check which line of code is at 0x0002C628, have a look at this.
    I also noticed that you have a lot of delays in main, this might cause potential issues. Which example are you running and have you made any other modifications other than the ones in main?
