Use supl_client_abort() A GPS SUPL nrf9160
Hi.
I use GPS with SUPL client library, so I need your help.
I enabled CONFIG_AGPS_SRC_SUPL and use gps_agps_request() function to request agps
I found that in supl_start(), you don't use supl_client_abort() function.
This document (https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/libraries/others/supl_os_client.html#supl-client) noted that  "The SUPL client OS integration library then starts the SUPL session by calling the supl_client_session() function from the SUPL client library with the supl_session_ctx_t parameter. The application does not return from this function until the SUPL session is finished or the supl_client_abort() function is called.".
I want use supl_client_abort() but segger embedded studio can't build it. It said "undefine reference supl_client_abort" although I included "supl_session.h".
How can I use it?
Thank you.
