can't seem to see Rx for either UART0 or UART2
I'm trying to see serial data (polling async method) coming from a single-wire signal.  I have verified via an oscilloscope that there is indeed data on that wire.  However I when I plug the wire into the GPIO Rx (for both UART0 and UART2), I see nothing triggering the callback that RX is ready.  There is no flow control
Here are the specifics:
From Uart.C:
void uart_callback(const struct device *dev,
                   struct uart_event *evt,
                   void *user_data)
    struct device *uart = user_data;
    int err;
    switch (evt->type) {
        case UART_TX_DONE:
            //printk("Tx sent %d bytes\n", evt->data.tx.len);
        case UART_TX_ABORTED:
            printk("Error: Tx aborted\n\r");
        case UART_RX_RDY: {
            struct uart_event_rx *pRX = &evt->data.rx;
            size_t length = 0;
            size_t offset = 0;
            struct event_item event = { 0 };
            event.data = NULL;
            event.uart = uart;
            offset =  pRX->offset;
            length = pRX->len;
            printk("Received %d bytes (%s)\n\r", pRX->len, (const char *)&pRX->buf[offset]);
#if 0
            event.data = k_calloc(length, 1);
            memcpy(event.data, (char *)&pRX->buf[offset],  length - 1);
            //printk("Received data %d bytes  (%s)\n", length - 1, (char *)event.data);
            err = k_msgq_put(&event_msgq, &event, K_NO_WAIT);
            if (err) {
                /* Failed to put event into queue */
                k_free(event.data);
        case UART_RX_BUF_REQUEST:
            uint8_t *buf;
            //printk("allocating memory\n");
            err = k_mem_slab_alloc(&uart_slab, (void **)&buf, K_NO_WAIT);
            __ASSERT(err == 0, "Failed to allocate slab");
            //printk("setting up buffer response.\n");
            err = uart_rx_buf_rsp(uart, buf, BUF_SIZE);
            __ASSERT(err == 0, "Failed to provide new buffer");
        case UART_RX_BUF_RELEASED:
            //printk("Releasing memory");
            k_mem_slab_free(&uart_slab, (void **)&evt->data.rx_buf.buf);
        case UART_RX_DISABLED:
            printk("Rx Disabled.\n");
        case UART_RX_STOPPED:
            printk("Rx Stopped.\n");
From prj.conf:
CONFIG_THREAD_MONITOR=y
CONFIG_NRF_MODEM_LIB=y                # implies CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NRF_MODEM_LIB_SYS_INIT=n       # The application will take care of initializing Modem in main.c
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS=y                  # Will provide BSD name support. e.g. setsockopt() instead of nrf_setsockopt()
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_NATIVE=n                   # We are using socket offload, so set this to no
CONFIG_BUILD_WITH_TFM=y
# Memory size for k_malloc()
CONFIG_HEAP_MEM_POOL_SIZE=4096
# 4096 is the default
CONFIG_MAIN_STACK_SIZE=8192
CONFIG_MODEM_KEY_MGMT=y               # Application wants to make calls to store keys
CONFIG_LTE_LINK_CONTROL=y             # Enable the API's to setup and configure the LTE link
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n    # The application will take care of initializing the LTE stuff in main.c
CONFIG_NEWLIB_LIBC=y                  # Use the "new" libc
CONFIG_SAMPLE_TFM_MBEDTLS=y
CONFIG_CJSON_LIB=y
CONFIG_HTTP_CLIENT=y
# MbedTLS and security
CONFIG_NORDIC_SECURITY_BACKEND=y            # Required when commenting out BUILD_WITH_TFM
CONFIG_MBEDTLS_VANILLA_BACKEND=y
CONFIG_NET_SOCKETS_SOCKOPT_TLS=y
CONFIG_NET_SOCKETS_OFFLOAD_TLS=n
CONFIG_MBEDTLS_ENABLE_HEAP=y
CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=8192
CONFIG_MBEDTLS_HEAP_SIZE=44000
CONFIG_MBEDTLS_TLS_LIBRARY=y
CONFIG_MBEDTLS_PKCS1_V15=y
CONFIG_MBEDTLS_RSA_C=y
CONFIG_MBEDTLS=y                              # Required when commenting out CONFIG_NORDIC_SECURITY_BACKEND
CONFIG_LOG=n
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
CONFIG_UART_CONSOLE=n
# Event management which handles network-related events (like ip address change, or net iface up/down for examples)
# CONFIG_NET_MGMT=y
# CONFIG_NET_MGMT_EVENT=y
# CONFIG_NET_SOCKETS_NET_MGMT=y
From the conf and overlay files:
/* SPDX-License-Identifier: LicenseRef-Nordic-5-Clause */
&uart2 {
	reg = < 0xa000 0x1000 >;
	interrupts = < 0xa 0x1 >;
	status = "okay";
	label = "UART_2";
	current-speed = < 0x1C200 >;
	tx-pin = < 0x00 >;
	rx-pin = < 0x01 >;
	/delete-property/ rts-pin;
	/delete-property/ cts-pin;
	/delete-property/ hw-flow-control;
&uart1 {
	status = "disabled";
// &gpiote {
//	interrupts = <13 NRF_DEFAULT_IRQ_PRIORITY>;
CONFIG_TFM_SECURE_UART1=n
CONFIG_UART_ASYNC_API=y
CONFIG_UART_2_ASYNC=y
CONFIG_UART_2_INTERRUPT_DRIVEN=n
CONFIG_UART_2_NRF_HW_ASYNC=y
CONFIG_UART_2_NRF_HW_ASYNC_TIMER=2
CONFIG_NRFX_TIMER2=y
CONFIG_RESET_ON_FATAL_ERROR=n
CONFIG_TRUSTED_EXECUTION_NONSECURE=y
And for UART2 What is the GPIO config?  In one part it reads Rx is PIN 0.  In another part it reads Tx is PIN 1.
Please help.
Thanks
/Loren
