SAADC oversampling + burst mode on three channel
    Sorry, I accidentally closed my last question and I don't know how to reopen it. So I create a new one to need your support.
I want to use 200ms to get ADC value from three channel and I want to get 30 times ADC value from every channel when 200ms timer trigger.
I change my code for three channel and every channel enable burst mode + oversample is 8x. Below is my setting source code.
static void adc_configure(void)
    ret_code_t err_code = nrf_drv_saadc_init(NULL, saadc_event_handler);
    nrf_saadc_channel_config_t config_current_sense =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
    err_code = nrf_drv_saadc_channel_init(0, &config_current_sense);
    nrf_saadc_channel_config_t config_adc_temp =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN2);
    err_code = nrf_drv_saadc_channel_init(1, &config_adc_temp);
    nrf_saadc_channel_config_t config_em_temp =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN3);
    err_code = nrf_drv_saadc_channel_init(2, &config_em_temp);
    err_code = nrf_drv_saadc_buffer_convert(adc_buf_adc[0], 3);
    err_code = nrf_drv_saadc_buffer_convert(adc_buf_adc[1], 3);
#define NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(PIN_P) \
        .resistor_p = NRF_SAADC_RESISTOR_DISABLED,     \
        .resistor_n = NRF_SAADC_RESISTOR_DISABLED,     \
        .gain       = NRF_SAADC_GAIN1_6,               \
        .reference  = NRF_SAADC_REFERENCE_INTERNAL,    \
        .acq_time   = NRF_SAADC_ACQTIME_10US,          \
        .mode       = NRF_SAADC_MODE_SINGLE_ENDED,     \
        .burst      = NRF_SAADC_BURST_ENABLED,         \
        .pin_p      = (nrf_saadc_input_t)(PIN_P),      \
        .pin_n      = NRF_SAADC_INPUT_DISABLED         \
// <o> SAADC_CONFIG_OVERSAMPLE  - Sample period
// <0=> Disabled
// <1=> 2x
// <2=> 4x
// <3=> 8x
// <4=> 16x
// <5=> 32x
// <6=> 64x
// <7=> 128x
// <8=> 256x
#ifndef SAADC_CONFIG_OVERSAMPLE
#define SAADC_CONFIG_OVERSAMPLE 3
Also, I create a 200ms timer to call nrf_drv_saadc_sample(), like as below.
static void data_process_handler(void * p_context)
    uint32_t err_code;
    //average_adc = true;
    nrf_drv_saadc_sample();
    //printf("%.4f-%.4f-%.4f\r\n",real_v_current_sense,real_v_adc_temp,real_v_em_temp);
    printf("%d-%d-%d\r\n",current_sense_vol,adc_temp_vol,em_temp_vol);
below is my ADC callback function and calibration function in main()
void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event)
    uint32_t err_code;
        nrf_saadc_value_t adc_result,adc_temp_result,em_temp_result;
        uint32_t          err_code;
        if((m_adc_evt_counter % 50000) == 0)               //Evaluate if offset calibration should be performed. Configure the SAADC_CALIBRATION_INTERVAL constant to change the calibration frequency
            m_saadc_calibrate = true;                                           // Set flag to trigger calibration in main context when SAADC is stopped
        if(m_saadc_calibrate == false)
            err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, 3);             //Set buffer so the SAADC can write to it again.
        adc_result = p_event->data.done.p_buffer[0];
        adc_temp_result = p_event->data.done.p_buffer[1];
        em_temp_result = p_event->data.done.p_buffer[2];
        //printf("Hello : %d-%d-%d\r\n",adc_result,adc_temp_result,em_temp_result);
        current_sense_vol = adc_result;
        adc_temp_vol = adc_temp_result;
        em_temp_vol = em_temp_result;
        m_adc_evt_counter++;
    else if (p_event->type == NRF_DRV_SAADC_EVT_CALIBRATEDONE)
        nrf_saadc_task_trigger(NRF_SAADC_TASK_STOP);
        while(!nrf_saadc_event_check(NRF_SAADC_EVENT_STOPPED));
        nrf_saadc_event_clear(NRF_SAADC_EVENT_STOPPED);
        //Need to setup both buffers, as they were both removed with the call to nrf_drv_saadc_abort before calibration.
    for (;;)
        if (m_saadc_calibrate == true)
            nrf_drv_saadc_abort();
            while(nrf_drv_saadc_calibrate_offset() != NRF_SUCCESS); //Trigger calibration task
            m_saadc_calibrate = false;
I will print my three channel ADC value every 200ms.
This works is very good and correct.
But I have a issue to need your support.
As described above, My channel 0 is AIN0 / channel 1 is AIN2 / channel 2 is AIN3
I expected that the arrangement of the data I printed should be 0->1->2
But It is 1->2->0. Why?? Maybe I can use it, but i am confused
Thank you.
John.
