stack error with BLE and FreeRtos
I am trying to make a code running the Ble stack adn the FreeRtos one, i started from the project ble_app_hrs_freertos_pca10040_s132, i've just removed some things and added a task :
 * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
// Board/nrf6310/ble/ble_app_hrs_rtx/main.c
 * @brief Heart Rate Service Sample Application with RTX main file.
 * This file contains the source code for a sample application using RTX and the
 * Heart Rate service (and also Battery and Device Information services).
 * This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_bas.h"
#include "ble_hrs.h"
#include "ble_dis.h"
#include "ble_conn_params.h"
#include "sensorsim.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_freertos.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "FreeRTOS.h"
#include "task.h"
#include "timers.h"
#include "semphr.h"
#include "fds.h"
#include "ble_conn_state.h"
#include "nrf_drv_clock.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define DEVICE_NAME                         "Nordic_HRM"                            /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME                   "NordicSemiconductor"                   /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_BLE_OBSERVER_PRIO               3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG                1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_ADV_INTERVAL                    300                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION                    18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL                   MSEC_TO_UNITS(400, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.4 seconds). */
#define MAX_CONN_INTERVAL                   MSEC_TO_UNITS(650, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.65 second). */
#define SLAVE_LATENCY                       0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                    MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory time-out (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY      5000                                    /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY       30000                                   /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT        3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                      1                                       /**< Perform bonding. */
#define SEC_PARAM_MITM                      0                                       /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                      0                                       /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS                  0                                       /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES           BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
#define SEC_PARAM_OOB                       0                                       /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE              7                                       /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE              16                                      /**< Maximum encryption key size. */
#define DEAD_BEEF                           0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define OSTIMER_WAIT_FOR_QUEUE              2                                       /**< Number of ticks to wait for the timer queue to be ready */
NRF_BLE_GATT_DEF(m_gatt);                                           /**< GATT module instance. */
BLE_ADVERTISING_DEF(m_advertising);                                 /**< Advertising module instance. */
static uint16_t m_conn_handle         = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
#if NRF_LOG_ENABLED
static TaskHandle_t m_logger_thread;                                /**< Definition of Logger thread. */
static void advertising_start(void * p_erase_bonds);
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in]   line_num   Line number of the failing ASSERT call.
 * @param[in]   file_name  File name of the failing ASSERT call.
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    // Initialize timer module.
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
    ret_code_t              err_code;
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
/**@brief Function for initializing the GATT module. */
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
 * @param[in]   p_evt   Event received from the Connection Parameters Module.
/**@brief Function for handling a Connection Parameters error.
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for initializing the Connection Parameters module. */
    //cp_init.start_on_notify_cccd_handle    = m_qwr.hrm_handles.cccd_handle;
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            NRF_LOG_INFO("Disconnected");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
    uint32_t ram_start = 0;
    // Enable BLE stack.
 * @param[in]   event   Event generated by button press.
static void bsp_event_handler(bsp_event_t event)
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
        case BSP_EVENT_WHITELIST_OFF:
/**@brief Function for initializing the Advertising functionality. */
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    //init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    //init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
static void log_init(void)
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
/**@brief Function for starting advertising. */
    ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
#if NRF_LOG_ENABLED
/**@brief Thread for handling the logger.
 * @details This thread is responsible for processing log entries if logs are deferred.
 *          Thread flushes all log entries and suspends. It is resumed by idle task hook.
 * @param[in]   arg   Pointer used for passing some arbitrary information (context) from the
 *                    osThreadCreate() call to the thread.
static void logger_thread(void * arg)
    UNUSED_PARAMETER(arg);
    while (1)
        NRF_LOG_FLUSH();
        vTaskSuspend(NULL); // Suspend myself
#endif //NRF_LOG_ENABLED
/**@brief A function which is hooked to idle task.
 * @note Idle hook must be enabled in FreeRTOS configuration (configUSE_IDLE_HOOK).
void vApplicationIdleHook( void )
#if NRF_LOG_ENABLED
     vTaskResume(m_logger_thread);
/**@brief Function for initializing the clock.
static void clock_init(void)
    ret_code_t err_code = nrf_drv_clock_init();
TaskHandle_t  A_function_task_handle;
static void A_function(void * pvParameter)
	NRF_LOG_INFO("||function||---->>A_function---->>enter!");
	UNUSED_PARAMETER(pvParameter);
	while (true)
    NRF_LOG_INFO("=================================================");
    NRF_LOG_FLUSH();
		//bsp_board_led_invert(BSP_BOARD_LED_2);
		vTaskDelay(1000);
/**@brief Function for application main entry.
    bool erase_bonds;
    // Initialize modules.
    log_init();
    clock_init();
    // Do not start any interrupt that uses system functions before system initialisation.
    // The best solution is to start the OS before any other initalisation.
#if NRF_LOG_ENABLED
    // Start execution.
    if (pdPASS != xTaskCreate(logger_thread, "LOGGER", 256, NULL, 1, &m_logger_thread))
        APP_ERROR_HANDLER(NRF_ERROR_NO_MEM);
		NRF_LOG_INFO("||Initialize||---->>xTaskCreate---->>completed!");
    // Activate deep sleep mode.
    SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
    // Configure and initialize the BLE stack.
    ble_stack_init();
    timers_init();
    gap_params_init();
    gatt_init();
    advertising_init();
    conn_params_init();
    // Create a FreeRTOS task for the BLE stack.
    // The task will run advertising_start() before entering its loop.
    nrf_sdh_freertos_init(advertising_start, &erase_bonds);
    NRF_LOG_INFO("HRS FreeRTOS example started.");
		if (pdPASS != xTaskCreate(A_function, "FunA", 60, NULL, 2, &A_function_task_handle))
    // Start FreeRTOS scheduler.
    vTaskStartScheduler();
    NRF_LOG_INFO("||Wrong    ||---->>FreeRTOS---->>Quite !!");
    for (;;)
        APP_ERROR_HANDLER(NRF_ERROR_FORBIDDEN);
When creating the tasks if a put a task depth of 256 the code leave the Task Sheduler like this :
<error> app: Fatal error
<warning> app: System reset
<info> app: ||Initialize||---->>xTaskCreate---->>completed!
<info> app: HRS FreeRTOS example started.
<info> app: ||Wrong ||---->>FreeRTOS---->>Quite !!
so i reduced the size to the minimum (60 i belive) and the code can start :
<info> app: Fast advertising.
<info> app: ||function||---->>A_function---->>enter!
<info> app: =================================================
But i cannont connect to the BLE, the nRf connect app on my phone detects the module (so advertising works) but can't connect.
So i removed the Log from my "FunA" task
	while (true)
    //NRF_LOG_INFO("=================================================");
    //NRF_LOG_FLUSH();
		vTaskDelay(1000);
But now i have this issue :
<error> hardfault: HARD FAULT at 0x0002B12E
<error> hardfault: R0: 0x00000000 R1: 0x00000000 R2: 0x0002B12E R3: 0x200070CC
<error> hardfault: R12: 0xA5A5A5A5 LR: 0x0002B67D PSR: 0x60000000
<error> hardfault: Cause: The processor has attempted to execute an instruction that makes illegal use of the EPSR.
How exctly can i use as a parameter for the task depth ? I plan to have 4 or 5 tasks running at the same time.
Thank you for your help.
