nrf52832+SPI+AD5940 cannot get ad5940id
Hi,I am trying to use nrf52832 to drive the ad5940 chip, but using the function in the SPIM driver library to initialize the ad5940, I have been unable to get the ID of the chip. If I use gpio to simulate spi, I can get the ID smoothly. What is the reason? My ad5940 transplant code as follows.
SDK ver:17.1.0_DDDE560
static const nrf_drv_spi_t ad5940_spi_handler = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE); /**< SPI instance. */ static volatile bool ad5940_spi_xfer_done; /**< Flag used to indicate that SPI instance completed the transfer. */ void ad5940_spi_event_handler(nrf_drv_spi_evt_t const *p_event,void *p_context) {     if(p_event->type == NRF_DRV_SPI_EVENT_DONE)     {         ad5940_spi_xfer_done = true;     } } static void ad5940_spi_init(void) {     nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;     spi_config.ss_pin   = NRF_DRV_SPI_PIN_NOT_USED;     spi_config.miso_pin = AD5940_SPI_MISO_PIN;     spi_config.mosi_pin = AD5940_SPI_MOSI_PIN;     spi_config.sck_pin  = AD5940_SPI_SCLK_PIN;     spi_config.frequency = NRF_DRV_SPI_FREQ_8M;     spi_config.bit_order = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST;     spi_config.mode     = NRF_DRV_SPI_MODE_0;     APP_ERROR_CHECK(nrf_drv_spi_init(&ad5940_spi_handler, &spi_config, ad5940_spi_event_handler, NULL)); } void AD5940_ReadWriteNBytes(unsigned char *pSendBuffer,unsigned char *pRecvBuff,unsigned long length) { APP_ERROR_CHECK(nrf_drv_spi_transfer(&ad5940_spi_handler, pSendBuffer, length, pRecvBuff, length)); while(!ad5940_spi_xfer_done); ad5940_spi_xfer_done = false; } uint32_t ad5940_port_Init(void) { ad5940_spi_init(); ad5940_int0_init(); return 0; } uint32_t AD5940_MCUResourceInit(void *pCfg) { nrf_gpio_cfg_output(AD5940_SPI_CS_PIN); nrf_gpio_cfg_output(AD5940_SPI_SCLK_PIN); nrf_gpio_cfg_output(AD5940_SPI_MOSI_PIN); nrf_gpio_cfg_input (AD5940_SPI_MISO_PIN,NRF_GPIO_PIN_PULLUP); nrf_gpio_cfg_output(AD5940_RESET_PIN); AD5940_CsSet(); AD5940_RstSet(); return ad5940_port_Init(); }
  • static const nrf_drv_spi_t ad5940_spi_handler = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
        ad5940_spi_init();
        ad5940_int0_init();
        return 0;
    void AD5940_CsClr(void)
        AD5940_CS_CLEAR();//
    void AD5940_CsSet(void)
        AD5940_CS_SET();
    void AD5940_RstClr()
        nrf_gpio_pin_clear(AD5940_RESET_PIN);//
    void AD5940_RstSet()
        nrf_gpio_pin_set(AD5940_RESET_PIN);//
    void AD5940_Delay10us(uint32_t time)
        time/=100;
        if(time == 0) time =1;
        nrf_delay_ms(time);
    uint32_t AD5940_GetMCUIntFlag(void)
       return ucInterrupted;
    uint32_t AD5940_ClrMCUIntFlag(void)
       ucInterrupted = 0;
       return 0;
        AD5940_CsSet();
        AD5940_RstSet();
