nRF connect app's bonding feature and Random address
Dear Nordic,
I'm using the nRF connect app for the smart phone to test BLE bonding.
I hope to know the bonding feature on the nRF connect app is working with Random Address or not.
If support the Random address,
how can I check it is working now, and can I enable/disable the Random Address from bonding feature?
Regards.
Brown.
    There are several types of random addresses:
    • Static address, which must stay the same within the same power cycle. When the device is turned off and on again, it may change address.
    • Private addresses, of which
      • Non-resolvable private adresses changes periodically and cannot be tracked, so you cannot bond with the device and then find it again later
      • Resolvable private addresses, which can be resolved by any bonded peer
    The nRF Connect smartphone app is compatible with all address types. Please note that if the address of the device changes it will no longer be recognized by other devices. The only exception is if it uses resolvable private addresses, in which case bonded peers (that have stored the Identity Resolving Key (IRK) of the device) will be able to identify the device by resolving the address.
    If an address is random, then you can tell what type of address it is by looking at the two most significant bits of the 48 bit address:
    Address [47:46] Sub-Type
    0b00 Non-resolvable private address
    0b01 Resolvable private address
    0b10 Reserved for future use
    0b11 Static device address
    Terje
