Hello all,
I am trying to on implement a custom 802.15.4 implementation (not thread nor zigbee) from the nrfxlib 802.15.4 radio driver in NCS. The goal is to run it in multiprotocol mode with BLE. I however can't get it to work at all, nor can I find any sample using only 802.15.4 (but the phy test, which I don't understand).
Is there any guide in how to enable the 802.15.4 radio driver, or any smaller sample?
I have tried to implement a simple hello world, but as soon as I enable the CONFIG_NRF_802154_RADIO_DRIVER=y in prj.conf I get runtime assertions.
My main.c (note that I'm not even using any nrf_802154_ functionality):
#include <zephyr.h> #include <logging/log.h> // #include <nrf_802154.h> LOG_MODULE_REGISTER(app); void main(void) { printk("Hello world\n"); }
This is my prj.conf. Note that it works if I uncomment CONFIG_NRF_802154_ symbols.
CONFIG_ASSERT=y CONFIG_NCS_SAMPLES_DEFAULTS=y CONFIG_UART_INTERRUPT_DRIVEN=y CONFIG_SERIAL=y CONFIG_GPIO=y # Make sure printk is not printing to the UART console CONFIG_CONSOLE=y CONFIG_UART_CONSOLE=y CONFIG_HEAP_MEM_POOL_SIZE=2048 CONFIG_MAIN_THREAD_PRIORITY=7 # Enable DK LED and Buttons library CONFIG_DK_LIBRARY=y CONFIG_NRFX_TEMP=y CONFIG_NRFX_POWER=y CONFIG_NRFX_RNG=y CONFIG_XOROSHIRO_RANDOM_GENERATOR=y CONFIG_NRFX_TIMER2=y CONFIG_NRF_802154_RADIO_DRIVER=y # CONFIG_NRF_802154_RADIO_CONFIG=y CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=2 CONFIG_NRF_802154_TEMPERATURE_UPDATE_PERIOD=10000 CONFIG_NRF_802154_ENCRYPTION=n # This example requires more workqueue stack CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048 # Enable nRF ECB driver CONFIG_CRYPTO=y CONFIG_CRYPTO_NRF_ECB=y CONFIG_CRYPTO_INIT_PRIORITY=80 # Cryptocell is not supported through CSPRNG driver API: NCSDK-4813 CONFIG_ENTROPY_CC3XX=n # Networking CONFIG_NET_IPV6_MLD=n CONFIG_NET_IPV6_NBR_CACHE=n CONFIG_NET_IPV6_RA_RDNSS=n CONFIG_NET_IP_ADDR_CHECK=n CONFIG_NET_UDP=n
The runtime error I get:
ASSERTION FAIL @ WEST_TOPDIR/nrfxlib/nrf_802154/driver/src/nrf_802154_request_swi.c:228 E: r0/a1: 0x00000004 r1/a2: 0x000000e4 r2/a3: 0x00000001 E: r3/a4: 0xe000e117 r12/ip: 0x00000000 r14/lr: 0x0000c949 E: xpsr: 0x41000000 E: Faulting instruction address (r15/pc): 0x0000bf2a E: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0 E: Current thread: 0x20000948 (unknown)
Or, if I instead use the exact prj.conf from 802.15.4 phy test:
ASSERTION FAIL [nrf_802154_irq_is_enabled(SWI3_EGU3_IRQn)] @ WEST_TOPDIR/nrfxlib/nrf_802154/driver/src/nrf_802154_request_swi.c:228
What am I missing? Do I need to enable any more kconfig symbols? Where can I read about which?
I'm running the project on a nRF52840DK, using NCS 1.7.0 in VS code.
