I am using SD110 V8.0.0, SDK 8 and chipset nRF51822 QFAC. Sometimes my app get assert error from file A\a with random error code and 0x0000000 line number. How to debug this issue?
Thanks
Thanks
Some more information about what you are trying to do would be nice. What application are you using? Which variables are you watching?
Hi I am using Timer 1 and 2 for generating PWM. 4 PPI channel numbers 0,1,2,3 to control gpiote, I2C 1 and spi 0. GPIOTE has been used for external interrupt for Zero Crossing detection every 9.52 ms to 10.52 ms. (52.5 Hz to 47.5 Hz respectively). – Basically tracking 50 hz power line. SPI 0 is shared between energy metering IC and external flash.
Need to see some code as well, that is probably where the error lies anyway. If you have restrictions on sharing your code you can create a private support ticket at the mypage support portal.
