nRF5340 NFC and TAG4 library
Hi Everyone,
Wanted to test the NFC library provided by the nrfxlib on the nrf5340DK. Added the following config file:
# Copyright (c) 2020 Nordic Semiconductor ASA
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_WATCHDOG=y
CONFIG_SERIAL=y
CONFIG_GPIO=y
CONFIG_NFCT_PINS_AS_GPIOS=n
CONFIG_NFC_T4T_NRFXLIB=y
CONFIG_NFC_NDEF=y
CONFIG_NFC_NDEF_MSG=y
CONFIG_NFC_NDEF_RECORD=y
CONFIG_NFC_NDEF_URI_REC=y
CONFIG_NFC_NDEF_URI_MSG=y
# Make sure printk is not printing to the UART console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_MAIN_THREAD_PRIORITY=7
CONFIG_MAIN_STACK_SIZE=2048
CONFIG_ZIGBEE=y
CONFIG_ZIGBEE_APP_UTILS=y
CONFIG_ZIGBEE_ROLE_COORDINATOR=y
# Enable DK LED and Buttons library
CONFIG_DK_LIBRARY=y
# This example requires more workqueue stack
# Use software cryptography on nRF5340
CONFIG_TINYCRYPT=y
CONFIG_CTR_DRBG_CSPRNG_GENERATOR=y
CONFIG_ZIGBEE_USE_SOFTWARE_AES=y
#Networking
CONFIG_MPSL=n
CONFIG_NET_IPV6_MLD=n
CONFIG_NET_IPV6_NBR_CACHE=n
CONFIG_NET_IPV6_RA_RDNSS=n
CONFIG_NET_IP_ADDR_CHECK=n
CONFIG_NET_UDP=n
Resulted in:
gen_isr_tables.py: error: multiple registrations at table_index 17 for irq 17 (0x11)
Existing handler 0x5749, new handler 0xa379
Has IRQ_CONNECT or IRQ_DIRECT_CONNECT accidentally been invoked on the same irq multiple times?
How could I check the reason for collision? nrf sdk version is 1.7.0.
Milan
