Need options for external 3.6V/3.3V power supply for nRF52 development board
I am trying to develop CAN communication using nRF52 dev kit based on nRF52832 (PCA10040) and a MIKROE CAN SPI click 3.3V board. This board has an mcp2515 stand alone CAN controller with SPI and an SN65HVD230 CAN transceiver. This board works on 3.3 V power supply. I have connected the SPI pins, VDD and GND of nrF52 dev board to that of the CAN board and powering the nrF52 using the USB. I analyzed the Vdd pin on the nRF52 and found it to be 2.9V, the Vcc pins of the CAN controller was 2.9V and that on the transceiver was also around the same. The transceiver data sheet mentions the operating voltage range to be 3V to 3.6V.
I saw it is mentioned in this nRF52 DK hardware desc page that "The 5V from the USB is regulated down to 3.3 V through an onboard voltage regulator.” But when I powered the board via USB and measured the voltage on VDD, it is around 2.9V. So I thought of using external power supply instead of the USB.
I need options on using external power supply 3.3V to 3.6V for nRF52 dev board. Kindly give me your suggestions. Part numbers/links would be great.
