UART TX in particular seems to have a race condition with scheduler running
I am noticing that particularly with the transmission of bytes over UART while scheduler is running, either some bytes go missing or the entire set of bytes aren't sent or received. (I'm seeing the UART stuff in the serial port). Though, I can send bytes from the serial port just fine: the ISR is triggered as soon as I type in something for each byte
So for according to the code snippet, I am printing Hello at the start of the app and often times I see Ello being printed and sometimes none of it
I'm wondering if there's a race condition somewhere and any assistance shall be greatly appreciated.
void Uart::TxByte(uint8_t byte)
        setNrfEvent(NRF_UART_EVENT_TXDRDY, 0);
        pUARTx->TXD = byte;     // triggers the IRQ handler by writing the first byte
void Uart::StartTx(uint8_t *buffer, size_t bytesToSend, bool blockingTx)
    setNrfEvent(NRF_UART_TASK_STARTTX, 1);
    fifoTx.enqueElems(buffer, bytesToSend);
    uint8_t val = fifoTx.deque();
    TxByte(val);
void Uart::PrintToTerminal(const char *format, ...)
    char buffer[100] = {0};
    va_list args;
    va_start (args, format);
    vsnprintf (buffer, sizeof(buffer), format, args);
    strcat(buffer, "\r\n");
    size_t bytesToSend = strlen(buffer);
    StartTx((uint8_t*) buffer, bytesToSend);
    va_end (args);
void UARTE0_UART0_IRQHandler(void)
    bool isTxdRdyIrqSet	   = getIrqRegStatus(NRF_UART_INT_MASK_TXDRDY);
    bool isTxdRdyEvntSet   = getNrfEventStatus(NRF_UART_EVENT_TXDRDY);
    if (isTxdRdyIrqSet && isTxdRdyEvntSet)
        setNrfEvent(NRF_UART_EVENT_TXDRDY, 0);	    // clear the TXDRDY bit
        // continue to send bytes till the FIFO is empty
        if (!fifoTx.isEmpty())
    	  uint8_t byte = fifoTx.deque();
    	  TxByte(byte);
    	  // transmission ended
    	  setNrfEvent(NRF_UART_TASK_STOPTX, 1);
bool Uart::getNrfEventStatus(nrf_uart_event_t reg) const
    return (bool) *(volatile uint32_t *)((uint8_t *)pUARTx + (uint32_t)reg);
bool Uart::getIrqRegStatus(uint32_t mask)
    return (bool) (pUARTx->INTENSET & mask);
int main()
    uart.PrintToTerminal("Hello");
    vTaskStartScheduler();
  • Hi
    Thanks. It does make sense to clear the TXDRDY event inside StartTx so that when the interrupt is fired, it's already enabled which can be disabled then and it does seem to do the trick in this case.
    However, I'm seeing an interesting behavior when I call PrintToTerminal() inside a sensor thread which is called as soon as a sensor value is read in a constant loop with a delay of 3 seconds.
    That's how I'm invoking PrintToTermina().
    snprintf(_notification.msg, 50, "temp: %u", tmpValue); // temp: 20 (for e.g)
    _uart.PrintToTerminal(_notification.msg);
    seems like every byte is printed every 3 seconds or so as opposed to the each message being printed rightaway so every 3 seconds, we should be seeing a new message. Do you see what could be going wrong here?
    in case you can't see the video: https://imgur.com/a/FKmEPrp
  • Hi
    Any chance you are calling _uart.PrintToTerminal() from interrupt context, with higher or equal interrupt priority to the UART interrupt?
    Best regards
    Torbjørn
  • No, _uart.PrintToTermina() is invoked within a thread context and not ISR I believe.
    I am setting TWI_IRQ_PRIORITY as the interrupt priority for the I2C sensor and for UART, I'm passing in  APP_IRQ_PRIORITY_LOWEST as the priority. So perhaps it causes the UART interrupt to be preempted by the I2C's?
    Although I don't read I2C values until after 3 seconds and the UART transmission shouldn't take that long before the next I2C interrupt occurs no?
    void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
        MCP9808 *obj = static_cast<MCP9808*>(p_context);
        BaseType_t xHigherPriorityTaskWoken = pdFALSE;
        switch (p_event->type)
            case NRF_DRV_TWI_EVT_DONE:
                if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
                    // unblock the waiting thread (mainThread) once RX XFER is done
                    vTaskNotifyGiveFromISR(obj->taskHandle, &xHigherPriorityTaskWoken);
                else if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_TX)
                    NRF_LOG_INFO("TX transfer done...\n");
                    m_xfer_done = true;
    void MCP9808::mainThread()
        xferData(tmpBuffer, 1);
        vTaskDelay(pdMS_TO_TICKS(2000));
        uint32_t notifiedValue;
        while(true)
            uint32_t val = i2cRead(); // invokes TWI interrupt
            uint32_t taskNotify = ulTaskNotifyTake(pdTRUE, portMAX_DELAY);  // blocks the current thread by decrementing ulNotifiedValue to 0 (taking a semaphore)
            if (taskNotify != 0)
    	        NRF_LOG_WARNING("Transmission ended as expected...\n");
    	        NRF_LOG_WARNING("The call to ulTaskNotifyTake timed out\n");
            // if here, ISR is done executing and signalling to unblock this thread
            readTempInC();
            notify(this);       // calling _uart.PrintToTermina() within notify()
            vTaskDelay(pdMS_TO_TICKS(3000));
  • Hi
    Have you checked with the debugger if the UART interrupt is actually called?
    And if it is called, will it get to the point where the TxByte() function is called to load the next byte?
    If you only see one byte of data every time you try to write a string it seems like the UART interrupt is not working properly.
    Best regards
    Torbjørn
  • UART interrupt is firing fine and so does the TxByte(). It's not that I don't see anything in terminal, but moreso the rate at which I see the output is waay too slow as you can see in the video shared above. And this only happens for the sensor data that I'm outputting over UART in a thread
