UART TX in particular seems to have a race condition with scheduler running
I am noticing that particularly with the transmission of bytes over UART while scheduler is running, either some bytes go missing or the entire set of bytes aren't sent or received. (I'm seeing the UART stuff in the serial port). Though, I can send bytes from the serial port just fine: the ISR is triggered as soon as I type in something for each byte
So for according to the code snippet, I am printing Hello at the start of the app and often times I see Ello being printed and sometimes none of it
I'm wondering if there's a race condition somewhere and any assistance shall be greatly appreciated.
void Uart::TxByte(uint8_t byte)
        setNrfEvent(NRF_UART_EVENT_TXDRDY, 0);
        pUARTx->TXD = byte;     // triggers the IRQ handler by writing the first byte
void Uart::StartTx(uint8_t *buffer, size_t bytesToSend, bool blockingTx)
    setNrfEvent(NRF_UART_TASK_STARTTX, 1);
    fifoTx.enqueElems(buffer, bytesToSend);
    uint8_t val = fifoTx.deque();
    TxByte(val);
void Uart::PrintToTerminal(const char *format, ...)
    char buffer[100] = {0};
    va_list args;
    va_start (args, format);
    vsnprintf (buffer, sizeof(buffer), format, args);
    strcat(buffer, "\r\n");
    size_t bytesToSend = strlen(buffer);
    StartTx((uint8_t*) buffer, bytesToSend);
    va_end (args);
void UARTE0_UART0_IRQHandler(void)
    bool isTxdRdyIrqSet	   = getIrqRegStatus(NRF_UART_INT_MASK_TXDRDY);
    bool isTxdRdyEvntSet   = getNrfEventStatus(NRF_UART_EVENT_TXDRDY);
    if (isTxdRdyIrqSet && isTxdRdyEvntSet)
        setNrfEvent(NRF_UART_EVENT_TXDRDY, 0);	    // clear the TXDRDY bit
        // continue to send bytes till the FIFO is empty
        if (!fifoTx.isEmpty())
    	  uint8_t byte = fifoTx.deque();
    	  TxByte(byte);
    	  // transmission ended
    	  setNrfEvent(NRF_UART_TASK_STOPTX, 1);
bool Uart::getNrfEventStatus(nrf_uart_event_t reg) const
    return (bool) *(volatile uint32_t *)((uint8_t *)pUARTx + (uint32_t)reg);
bool Uart::getIrqRegStatus(uint32_t mask)
    return (bool) (pUARTx->INTENSET & mask);
int main()
    uart.PrintToTerminal("Hello");
    vTaskStartScheduler();
  • Hi
    Can you confirm that you are using the nRF52840 device?
    First off you should use the UARTE peripheral rather than the UART peripheral in order to ensure that no bytes are lost.
    Secondly, you should use the nrfx_uarte driver rather than using the peripheral directly. These drivers have been developed by us over time to configure the peripherals optimally, and have been thoroughly tested to ensure they work well in different applications.
    Best regards
    Torbjørn
  • Yes, this is nRF62840.
    doesn't UARTE use DMA additionally? why would that ensure no bytes are lost?
    i am actually writing my own driver. do you see whether there's a possibility of a race condition in my snippet?
  • Hi
    That's one of the main reasons to use DMA in the first place.
    DMA allows UART TX and RX data to be read from and written to RAM in parallel, without the CPU having to be involved. This means that if the CPU is busy handling a high priority interrupt the UART data can still flow in and out of RAM seamlessly.
    All the CPU has to do is to prepare the TX and RX buffers in RAM, and let the UARTE peripheral know the address and size of these buffers, before starting a TX or RX transaction.
    Other advantages of DMA is less CPU usage and higher data throughput (more important for high speed peripherals like SPI).
    You are free to do that if you want, but please be aware that we can only offer limited support for custom driver implementations. If you are planning to enter production I would strongly discourage it, as the responsibility falls on you rather than Nordic to ensure the driver works satisfactorily.
    As for race conditions of the code, I find the fact that you clear the TXDRDY event both in the interrupt handler and in the TxByte function a bit worrying.
    Possibly it will work better if you only clear this in StartTx and in the interrupt.
    Since UART transmission is controlled from the nRF52 side there shouldn't be any risk of losing bytes here, even without DMA. It is more of an issue for RX data, since this can occur outside the control of the nRF.
    Best regards
    Torbjørn
  • Understood your point about DMA but like you also mentioned, it's mostly used for stuff that requires high throughput like SPI.
    Understood about being offered limited support for custom stuff and it's totally fair. It's just if you could see any issues with the logic and if not, it's fine and if so, great!
    my understanding is: TxByte() sends the first byte only and is never invoked after since the first-byte transmission should enable the TXDRDY event which the interrupt should handle from then on.
    why inside StartTx? What difference does clearing inside StartTx make than inside TxByte?
  • Hi
    You call the TxByte() function inside the interrupt handler, as long as there is data in the FIFO. Wouldn't this mean it's called for every transmitted byte, except for the last?
    Then you ensure that the TXDRDY event is cleared before you start a new transaction, but leave it up to the interrupt handler to clear it for every transmitted byte.
    Technically it should be enough just to clear it in the interrupt handler, so this might also work.
    Best regards
    Torbjørn
