nRF52810 uart ERROR 4 [NRF_ERROR_NO_MEM]
I'm using ble_app_uart to test AT.
When I sending a buffer
reset_buff[10]="AT+RESET\r\n";
RTT log showing an error
<error> app: ERROR 4 [NRF_ERROR_NO_MEM] at ..\..\..\main.c:561
00>
00> PC at: 0x0001EC51
00>
00> <error> app: End of error report
Here is the code
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t data_array[256];
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
//            UNUSED_VARIABLE(app_uart_get(&data_array[index]));
//            index++;
//						NRF_LOG_INFO("%02x",data_array[index]);
//            if ((data_array[index - 1] == '\n') ||
//                (data_array[index - 1] == '\r') ||
//                (index >= m_ble_nus_max_data_len))
//                if (index > 1)
//                    NRF_LOG_DEBUG("Ready to send data over BLE NUS");
//                    NRF_LOG_HEXDUMP_DEBUG(data_array, index);
//                    do
//                        uint16_t length = (uint16_t)index;
//                        err_code = ble_nus_data_send(&m_nus, data_array, &length, m_conn_handle);
//                        if ((err_code != NRF_ERROR_INVALID_STATE) &&
//                            (err_code != NRF_ERROR_RESOURCES) &&
//                            (err_code != NRF_ERROR_NOT_FOUND))
//                            APP_ERROR_CHECK(err_code);
//                    } while (err_code == NRF_ERROR_RESOURCES);
//                index = 0;
        case APP_UART_FIFO_ERROR:
static void uart_init(void)
        .rx_pin_no    = 18,
        .tx_pin_no    = 20,
        .rts_pin_no   = NULL,
        .cts_pin_no   = NULL,
        .use_parity   = false,
#if defined (UART_PRESENT)
        .baud_rate    = NRF_UART_BAUDRATE_9600
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
/**@brief Application main function.
    bool erase_bonds;
	uint8_t reset_buff[10]="AT+RESET\r\n";
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
//    printf("\r\nUART started.\r\n");
    advertising_start();
		for(int i=0;i<10;i++)
			  UNUSED_VARIABLE(app_uart_put(reset_buff[i]));
    // Enter main loop.
    for (;;)
        idle_state_handle();
  • The error message you're seeing is pulled from line 567 in your main.c file. What function is called in line 567 here? If you go to where this function is defined, comments generally provide some information on what various errors mean. Try checking out what NRF_ERROR_NO_MEM means for the function that returns this error and see if you understand what you need to do. It looks like you haven't added all of the code, so it's impossible to see which function is returning this error.
    Simon
