mcuboot on nRF9160 custom board
I have written simple hello world code on nRF9160 custom board and enables the MCUBoot as bootloader using CONFIG_BOOTLOADER_MCUBOOT=y in prj.conf file.
Also, made some bootloader related configuration at mcuboot.conf file.
I have kept the break point on loader.c file but my program execution is not halting there.
my question is that. How to debug the mcuboot a bootloader code on nRF9160 custom board?
I am using Segger Embedded Studio IDE.
  • Hey Mayurkumar!
    I see you have another case that strictly isn't related to this, but still has the same title. Please keep the support tickets separate by giving them different and descriptive titles.
    When it comes to your issue though, it might be that the thread isn't running on the files you mentioned. Can you tell me more about what configurations you added?
    Elfving
    In my hello world application i have added the below prj.conf
    # Bootloader
    CONFIG_SECURE_BOOT=y
    #CONFIG_BUILD_S1_VARIANT=y
    CONFIG_IMG_MANAGER=y
    CONFIG_MCUBOOT_IMG_MANAGER=y
    # External Falsh for secondary storage
    CONFIG_FLASH=y
    CONFIG_FLASH_MAP=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_PM_EXTERNAL_FLASH=y
    CONFIG_PM_EXTERNAL_FLASH_DEV_NAME="MX25R64"
    CONFIG_PM_EXTERNAL_FLASH_BASE=0x0
    CONFIG_PM_EXTERNAL_FLASH_SIZE=0x800000
    mcuboot.conf as below
    CONFIG_SPI=y
    #CONFIG_SPI_1=y
    CONFIG_SPI_NOR=y
    CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    #CONFIG_SPI_NOR_STACK_WRITE_BUFFER_SIZE=16
    CONFIG_MULTITHREADING=y
    CONFIG_BOOT_MAX_IMG_SECTORS=512
    # Enable these for serial recovery
    CONFIG_LOG=y
    CONFIG_LOG_DEFAULT_LEVEL=4
    CONFIG_LOG_OVERRIDE_LEVEL=4
    CONFIG_PM_EXTERNAL_FLASH_SUPPORT_LEGACY=y
    #secondary image
    CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
    CONFIG_PM_PARTITION_SIZE_MCUBOOT_SECONDARY=0xf0000
    #OVERWRITE mode
    CONFIG_BOOT_UPGRADE_ONLY=y
    #shared memory area
    #CONFIG_MEASURED_BOOT=y
    CONFIG_MAIN_STACK_SIZE=10240
    CONFIG_GPIO=y
    # Enable regulators
    CONFIG_REGULATOR=y
    pm_static.yml as below
    mcuboot:
      address: 0x0
      end_address: 0xc000
      placement:
        before:
        - mcuboot_primary
      region: flash_primary
    EMPTY_0:
      address: 0xC000
      end_address: 0x10000
      placement:
        before:
        - mcuboot_pad
    mcuboot_primary:
      address: 0x10000
      end_address: 0x100000
      orig_span: &id001
      - mcuboot_pad
      - spm
      - app
      sharers: 0x1
      span: *id001
    mcuboot_primary_app:
      address: 0x10200
      orig_span: &id002
      - app
      - spm
      span: *id002
    mcuboot_pad:
      address: 0x10000
      end_address: 0x10200
      placement:
        align:
          start: 0x8000
        before:
        - mcuboot_primary_app
    spm:
      address: 0x10200
      end_address: 0x20200
      inside:
      placement:
        before:
        - app
    app:
      address: 0x20200
      inside:
    mcuboot_secondary:
      address: 0x0
      device: MX25R64
      end_address: 0xf0000
      placement:
        align:
          start: 0x000
      region: external_flash
    storage:
      address: 0xf0000
      end_address: 0x800000
      device: MX25R64
    Thank You,
    MayurKumar
  • Hey Mayur!
    Yes, this is possible. This is what you need to do:
    - Program the sample to the chip
    - Start an Ozone-session, and when you choose an elf file, then choose <sample>/<build folder>/mcuboot/zephyr/zephyr.elf.
    - Then you drag the file /bootloader/mcuboot/boot/bootutil/src/loader.c into the Ozone window.
    - Then choose debug --> start debug session --> Attach to running program
    - Then set a breakpoint in loader.c and press Debug --> reset
    This should work.
    Elfving
    I am able to debug my custom board using ozone debug as per your suggestion.
    My issue is that mcuboot is unable to read/swap the image. So i want to debug loader.c file on nRF9160 DK board. When i do same process for DK board i unable to debug it (program execution didn't halt at breakpoints)?
    Is there any settings to be enable for nRF9160DK board?
  • Hello! Sorry about the delay.
    I see, that is odd. And you do manage to set the breakpoints? Note that not every line gives you that option.
    What about at line 90 on loader.c? Place a breakpoint, then go to Debug --> Reset --> Reset & Run.
    Nothing you require for this to work, but speaking of which I believe CONFIG_DEBUG_OPTIMIZATIONS could be helpful.
    Elfving
