SDK17 - Queue module - pushing elements to the queue
Hi everyone,
I want to integrate the Queue module into my firmware. I found three functions for writting elements in the queue
1. nrf_queue_push
2. nrf_queue_in
3. nrf_queue_write
To my understanding nrf_queue_push is used to push a single element to the end of the queue. If you want to push more than one elements you have to use pointers and call the function through a loop.
nrf_queue_in is used to push a portion of elements, defining the buffer and its elements number to push
nrf_queue_write is the same as nrf_queue_in? I do not see any difference rather that it supports debugging capabilities
When I use either nrf_queue_in or nrf_queue_write the elements get pushed to the end of the queue?
Do I miss something else? To push an array of elements into the queue is more convenient to use function 2 or 3 right?
    Yes, that is correct.
    There is a small but important difference. With nrf_queue_write() you write all elements, or none. Say you want to write 3 elements, but there are only room for 2. In that case, no elements are written and NRF_ERROR_NO_MEM is returned. If you use nrf_queue_in() in this case, 2 elements are written (but not all 3), and it returns 2 to let you know this. You can see this described in the API documentation in nrf_queue.h.
    Yes, that is the case. Which of these to use depends on what behavior you want if there is room for some elements, but not all.
