nrf9160dk_nrf9160 v0.9.0 v1.7.1 mcp2515 canbus build problems.
Hi
Im trying to get the mcp2515 candriver example  to work  https://github.com/nrfconnect/sdk-zephyr/tree/main/samples/net/sockets/can#id3.
i have some error during build.
information bellow.
&spi3 {
    status = "okay";
    sck-pin = <10>;
    mosi-pin = <11>;
    miso-pin = <12>;
    cs-gpios = <&gpio0 13 GPIO_ACTIVE_LOW>;
    mcp2515@0 {
      compatible = "microchip,mcp2515";
		spi-max-frequency = <1000000>;
		/*int-gpios = <31>; /* D2 */
                             int-gpios = <&gpio0 31 GPIO_ACTIVE_LOW>; /* D2 */
		status = "okay";
		label = "CAN_3";
		reg = <0x0>;
		osc-freq = <16000000>;
		bus-speed = <125000>;
		sjw = <1>;
		prop-seg = <2>;
		phase-seg1 = <7>;
		phase-seg2 = <6>;
		#address-cells = <1>;
		#size-cells = <0>;
nrf9160dk_nrf9160_ns.overlay
CONFIG_SPI=y
CONFIG_I2C=n
CONFIG_SENSOR=y
CONFIG_CAN=y
CONFIG_CAN_INIT_PRIORITY=80
CONFIG_SHELL=y
CONFIG_CAN_SHELL=y
CONFIG_DEVICE_SHELL=y
prj.conf
cmake_minimum_required(VERSION 3.20.0)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(sockets_can)
target_sources(app PRIVATE src/main.c)
CMakeLists.txt
Building net_sockets_can
west build --build-dir c:\NordicApp\net_sockets_can\build c:\NordicApp\net_sockets_can --pristine --board nrf9160dk_nrf9160_ns -- -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=On -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="c:/NordicApp/net_sockets_can" -DDTC_OVERLAY_FILE:STRING="c:/NordicApp/net_sockets_can/nrf9160dk_nrf9160_ns.overlay" -DCONF_FILE:STRING="c:/NordicApp/net_sockets_can/prj.conf"
Including boilerplate (Zephyr base): C:/NordicSemi/v1.7.1/zephyr/cmake/app/boilerplate.cmake
-- Application: C:/NordicApp/net_sockets_can
-- Zephyr version: 2.6.99 (C:/NordicSemi/v1.7.1/zephyr), build: v2.6.99-ncs1-1
-- Found Python3: C:/NordicSemi/v1.7.1/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Found west (found suitable version "0.11.1", minimum required is "0.7.1")
-- Board: nrf9160dk_nrf9160_ns, Revision: 0.7.0
-- Cache files will be written to: C:/NordicSemi/v1.7.1/zephyr/.cache
-- Found dtc: C:/NordicSemi/v1.7.1/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (c:/NordicSemi/v1.7.1/toolchain/opt)
-- Found BOARD.dts: C:/NordicSemi/v1.7.1/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns.dts
-- Found devicetree overlay: c:/NordicApp/net_sockets_can/nrf9160dk_nrf9160_ns.overlay
-- Generated zephyr.dts: C:/NordicApp/net_sockets_can/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/NordicApp/net_sockets_can/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/NordicApp/net_sockets_can/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/NordicApp/net_sockets_can/build/zephyr/dts.cmake
Parsing C:/NordicSemi/v1.7.1/zephyr/Kconfig
Loaded configuration 'C:/NordicSemi/v1.7.1/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns_defconfig'
Merged configuration 'c:/NordicApp/net_sockets_can/prj.conf'
Configuration saved to 'C:/NordicApp/net_sockets_can/build/zephyr/.config'
Kconfig header saved to 'C:/NordicApp/net_sockets_can/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: C:/NordicSemi/v1.7.1/toolchain/opt/bin/arm-none-eabi-gcc.exe
Changed board to secure nrf9160dk_nrf9160 (NOT NS)
=== child image spm -  begin ===
-- Application: C:/NordicSemi/v1.7.1/nrf/samples/spm
-- Board: nrf9160dk_nrf9160, Revision: 0.7.0
-- Found toolchain: gnuarmemb (C:/NordicSemi/v1.7.1/toolchain/opt)
-- Found BOARD.dts: C:/NordicSemi/v1.7.1/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts
-- Found devicetree overlay: C:/NordicSemi/v1.7.1/nrf/samples/spm/nrf9160dk_nrf9160.overlay
-- Generated zephyr.dts: C:/NordicApp/net_sockets_can/build/spm/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/NordicApp/net_sockets_can/build/spm/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/NordicApp/net_sockets_can/build/spm/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/NordicApp/net_sockets_can/build/spm/zephyr/dts.cmake
Loaded configuration 'C:/NordicSemi/v1.7.1/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_defconfig'
Merged configuration 'C:/NordicSemi/v1.7.1/nrf/samples/spm/prj.conf'
Merged configuration 'C:/NordicSemi/v1.7.1/nrf/samples/spm/boards/nrf9160dk_nrf9160.conf'
Merged configuration 'C:/NordicSemi/v1.7.1/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration 'C:/NordicApp/net_sockets_can/build/spm/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/NordicApp/net_sockets_can/build/spm/zephyr/.config'
Kconfig header saved to 'C:/NordicApp/net_sockets_can/build/spm/zephyr/include/generated/autoconf.h'
CMake Warning (dev) at C:\NordicSemi\v1.7.1\nrfxlib\nrf_security\cmake\extensions.cmake:652:
  Syntax Warning in cmake code at column 32
  Argument not separated from preceding token by whitespace.
  C:\NordicSemi\v1.7.1\nrfxlib\nrf_security\CMakeLists.txt:185 (include)
This warning is for project developers.  Use -Wno-dev to suppress it.
CMake Warning at C:\NordicSemi\v1.7.1\zephyr\CMakeLists.txt:1612 (message):
-- Configuring done
-- Generating done
-- Build files have been written to: C:/NordicApp/net_sockets_can/build/spm
=== child image spm -  end ===
Dropping partition 'nrf_modem_lib_trace' since its size is 0.
-- Configuring done
-- Generating done
[1/190] Creating directories for 'spm_subimage'
[2/190] No download step for 'spm_subimage'
[3/190] No update step for 'spm_subimage'
[4/190] No patch step for 'spm_subimage'
[5/190] No configure step for 'spm_subimage'
[5/190] Performing build step for 'spm_subimage'
[1/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/aesni.c.obj
[2/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/arc4.c.obj
[3/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/aria.c.obj
[4/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/camellia.c.obj
[5/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/base64.c.obj
[6/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/asn1parse.c.obj
[7/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/asn1write.c.obj
[8/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/blowfish.c.obj
[9/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/debug.c.obj
[10/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/des.c.obj
[11/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/ctr_drbg.c.obj
[12/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/cipher_wrap.c.obj
[13/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/error.c.obj
[14/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/cipher.c.obj
[15/214] Generating objects/cc3xx.mon
[16/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/entropy.c.obj
[17/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/havege.c.obj
[18/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/entropy_poll.c.obj
[19/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/hkdf.c.obj
[20/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/gcm.c.obj
[21/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/hmac_drbg.c.obj
[22/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/bignum.c.obj
[23/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/nist_kw.c.obj
[24/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/md2.c.obj
[25/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/md.c.obj
[26/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/md4.c.obj
[27/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/pkcs12.c.obj
[28/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/md5.c.obj
[29/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/pk.c.obj
[30/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/pk_wrap.c.obj
[31/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/padlock.c.obj
[32/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/ripemd160.c.obj
[33/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/pkparse.c.obj
[34/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/oid.c.obj
[35/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/pkwrite.c.obj
[36/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/platform.c.obj
[37/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/timing.c.obj
[38/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/platform_util.c.obj
[39/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/version.c.obj
[40/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/xtea.c.obj
[41/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/pkcs5.c.obj
[42/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/psa_crypto.c.obj
[43/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/psa_crypto_ecp.c.obj
[44/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/version_features.c.obj
[45/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/psa_crypto_storage.c.obj
[46/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/psa_crypto_slot_management.c.obj
[47/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/psa_crypto_rsa.c.obj
[48/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/psa_crypto_client.c.obj
[49/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/psa_crypto_driver_wrappers.c.obj
[50/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/replacements/pem.c.obj
[51/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/shared/CMakeFiles/mbedcrypto_shared.dir/C_/NordicSemi/v1.7.1/mbedtls/library/sha512.c.obj
[52/214] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[53/214] Generating include/generated/driver-validation.h
[54/214] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[55/214] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a
[56/214] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[57/214] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[58/214] Generating include/generated/offsets.h
[59/214] Generating linker_zephyr_prebuilt.cmd
[60/214] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[61/214] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[62/214] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[63/214] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[64/214] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[65/214] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[66/214] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[67/214] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[68/214] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[69/214] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[70/214] Building C object zephyr/CMakeFiles/zephyr.dir/C_/NordicSemi/v1.7.1/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
[71/214] Linking C static library zephyr\arch\common\libisr_tables.a
[72/214] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[73/214] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[74/214] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[75/214] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[76/214] Linking C static library zephyr\arch\common\libarch__common.a
[77/214] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[78/214] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[79/214] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[80/214] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[81/214] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[82/214] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[83/214] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[84/214] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[85/214] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/tz/CMakeFiles/arch__arm__core__aarch32__cortex_m__tz.dir/arm_core_tz.c.obj
[86/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[87/214] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[88/214] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[89/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[90/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[91/214] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[92/214] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\tz\libarch__arm__core__aarch32__cortex_m__tz.a
[93/214] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
[94/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[95/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[96/214] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
[97/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[98/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[99/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[100/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[101/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[102/214] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[103/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[104/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[105/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[106/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[107/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[108/214] Building C object CMakeFiles/app.dir/src/main.c.obj
[109/214] Building C object zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj
[110/214] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[111/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[112/214] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
[113/214] Linking C static library app\libapp.a
[114/214] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
[115/214] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
[116/214] Building C object zephyr/boards/boards/arm/nrf9160dk_nrf9160/CMakeFiles/boards__arm__nrf9160dk_nrf9160.dir/nrf52840_reset.c.obj
[117/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[118/214] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
[119/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[120/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[121/214] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[122/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[123/214] Linking C static library zephyr\subsys\random\libsubsys__random.a
[124/214] Linking C static library zephyr\boards\boards\arm\nrf9160dk_nrf9160\libboards__arm__nrf9160dk_nrf9160.a
[125/214] Linking C static library zephyr\lib\posix\liblib__posix.a
[126/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[127/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[128/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[129/214] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/sys_clock_init.c.obj
[130/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[131/214] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/console/uart_console.c.obj
[132/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[133/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[134/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[135/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[136/214] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/clock_control/clock_control_nrf.c.obj
[137/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[138/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[139/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[140/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[141/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[142/214] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[143/214] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[144/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[145/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[146/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[147/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[148/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[149/214] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
[150/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj
[151/214] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
[152/214] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[153/214] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/power.c.obj
[154/214] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm_ctrl.c.obj
[155/214] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[156/214] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy/policy_residency.c.obj
[157/214] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[158/214] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/power.c.obj
[159/214] Building C object zephyr/CMakeFiles/zephyr.dir/C_/NordicSemi/v1.7.1/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[160/214] Building C object zephyr/CMakeFiles/zephyr.dir/C_/NordicSemi/v1.7.1/nrf/subsys/spm/spm.c.obj
[161/214] Building C object zephyr/CMakeFiles/zephyr.dir/C_/NordicSemi/v1.7.1/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[162/214] Building C object zephyr/CMakeFiles/zephyr.dir/C_/NordicSemi/v1.7.1/nrf/subsys/spm/secure_services.c.obj
[163/214] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
[164/214] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/nrf_rtc_timer.c.obj
[165/214] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/C_/NordicSemi/v1.7.1/nrf/drivers/entropy/entropy_cc310.c.obj
[166/214] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[167/214] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
[168/214] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
[169/214] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[170/214] Linking C static library zephyr\drivers\entropy\libdrivers__entropy.a
[171/214] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[172/214] Linking C static library modules\nrf\subsys\fw_info\lib..__nrf__subsys__fw_info.a
[173/214] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
[174/214] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
[175/214] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[176/214] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[177/214] Linking C static library zephyr\libzephyr.a
[178/214] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[179/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[180/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[181/214] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_uarte.c.obj
[182/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[183/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[184/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[185/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[186/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
[187/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[188/214] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[189/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[190/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
[191/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
[192/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[193/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
[194/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
[195/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[196/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
[197/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
[198/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
[199/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
[200/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[201/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[202/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
[203/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[204/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
[205/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
[206/214] Linking C static library zephyr\kernel\libkernel.a
[207/214] Linking C executable zephyr\zephyr_prebuilt.elf
[208/214] Generating linker.cmd
[209/214] Generating isr_tables.c, isrList.bin
[210/214] Generating dev_handles.c
[211/214] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
[212/214] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
[213/214] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
[214/214] Linking C executable zephyr\zephyr.elf
           FLASH:         64 KB        64 KB    100.00%
            SRAM:       11808 B        64 KB     18.02%
        IDT_LIST:          0 GB         2 KB      0.00%
[9/190] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[11/190] No install step for 'spm_subimage'
[12/190] Completed 'spm_subimage'
[13/190] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[14/190] Generating include/generated/offsets.h
[15/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[16/190] Generating linker_zephyr_prebuilt.cmd
[17/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[18/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[19/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[20/190] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[21/190] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[22/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[23/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[24/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[25/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[26/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[27/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[28/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[29/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[30/190] Linking C static library zephyr\arch\common\libisr_tables.a
[31/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[32/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[33/190] Linking C static library zephyr\arch\common\libarch__common.a
[34/190] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[35/190] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[36/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[37/190] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[38/190] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[39/190] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[40/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[41/190] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[42/190] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[43/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[44/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[45/190] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[46/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[47/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[48/190] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
[49/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[50/190] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[51/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[52/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[53/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[54/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[55/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[56/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[57/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[58/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[59/190] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[60/190] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[61/190] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
[62/190] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
[63/190] Building C object zephyr/boards/arm/nrf9160dk_nrf9160/CMakeFiles/boards__arm__nrf9160dk_nrf9160.dir/nrf52840_reset.c.obj
[64/190] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
[65/190] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
[66/190] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
[67/190] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[68/190] Linking C static library zephyr\lib\posix\liblib__posix.a
[69/190] Linking C static library zephyr\boards\arm\nrf9160dk_nrf9160\libboards__arm__nrf9160dk_nrf9160.a
[70/190] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/C_/NordicSemi/v1.7.1/nrf/drivers/entropy/entropy_cc310.c.obj
[71/190] Linking C static library zephyr\subsys\random\libsubsys__random.a
[72/190] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/shmem_sanity.c.obj
[73/190] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
[74/190] Linking C static library zephyr\drivers\entropy\libdrivers__entropy.a
[75/190] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj
[76/190] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
[77/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
[78/190] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_lib.c.obj
[79/190] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[80/190] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[81/190] Linking C static library zephyr\drivers\spi\libdrivers__spi.a
[82/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[83/190] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_os.c.obj
[84/190] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
[85/190] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
[86/190] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[87/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_ipc.c.obj
[88/190] Linking C static library modules\nrf\lib\nrf_modem_lib\lib..__nrf__lib__nrf_modem_lib.a
[89/190] Linking C static library modules\nrf\subsys\fw_info\lib..__nrf__subsys__fw_info.a
[90/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[91/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[92/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[93/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
[94/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[95/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[96/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[97/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[98/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[99/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[100/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_spim.c.obj
[101/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
[102/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[103/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[104/190] Building C object CMakeFiles/app.dir/src/main.c.obj
FAILED: CMakeFiles/app.dir/src/main.c.obj
C:\NordicSemi\v1.7.1\toolchain\opt\bin\arm-none-eabi-gcc.exe -DBUILD_VERSION=v2.6.99-ncs1-1 -DEXT_API_MAGIC=0x281ee6de,0xb845acea,23298 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,23298 -DKERNEL -DNRF9160_XXAA -DNRF_TRUSTZONE_NONSECURE -DUSE_PARTITION_MANAGER=1 -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/NordicSemi/v1.7.1/zephyr/include -Izephyr/include/generated -IC:/NordicSemi/v1.7.1/zephyr/soc/arm/nordic_nrf/nrf91 -IC:/NordicSemi/v1.7.1/zephyr/lib/util/fnmatch/. -IC:/NordicSemi/v1.7.1/nrf/include -IC:/NordicSemi/v1.7.1/modules/hal/cmsis/CMSIS/Core/Include -IC:/NordicSemi/v1.7.1/modules/hal/nordic/nrfx -IC:/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/drivers/include -IC:/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/mdk -IC:/NordicSemi/v1.7.1/zephyr/modules/hal_nordic/nrfx/. -IC:/NordicSemi/v1.7.1/nrfxlib/nrf_modem/include -isystem C:/NordicSemi/v1.7.1/zephyr/lib/libc/minimal/include -isystem c:/nordicsemi/v1.7.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/include -isystem c:/nordicsemi/v1.7.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/include-fixed -Os -imacros C:/NordicApp/net_sockets_can/build/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -imacros C:/NordicSemi/v1.7.1/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-address-of-packed-member -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=C:/NordicApp/net_sockets_can=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/NordicSemi/v1.7.1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/NordicSemi/v1.7.1=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir/src/main.c.obj -MF CMakeFiles\app.dir\src\main.c.obj.d -o CMakeFiles/app.dir/src/main.c.obj -c ../src/main.c
../src/main.c: In function 'tx':
c:\NordicApp\net_sockets_can\src\main.c:63:9: warning: implicit declaration of function 'send' [-Wimplicit-function-declaration]
   63 |   ret = send(fd, &frame, sizeof(frame), 0);
../src/main.c: In function 'create_socket':
c:\NordicApp\net_sockets_can\src\main.c:77:7: warning: implicit declaration of function 'socket' [-Wimplicit-function-declaration]
   77 |  fd = socket(AF_CAN, SOCK_RAW, CAN_RAW);
In file included from C:\NordicSemi\v1.7.1\zephyr\include\net\net_if.h:29,
                 from C:\NordicSemi\v1.7.1\zephyr\include\net\net_context.h:28,
                 from C:\NordicSemi\v1.7.1\zephyr\include\net\dns_resolve.h:17,
                 from C:\NordicSemi\v1.7.1\zephyr\include\net\socket.h:28,
                 from c:\NordicApp\net_sockets_can\src\main.c:12:
C:\NordicSemi\v1.7.1\zephyr\include\net\net_l2.h:82:32: error: '_net_l2_CANBUS_RAW' undeclared (first use in this function)
   82 | #define NET_L2_GET_NAME(_name) _net_l2_##_name
c:\NordicApp\net_sockets_can\src\main.c:84:29: note: in expansion of macro 'NET_L2_GET_NAME'
   84 |   net_if_get_first_by_type(&NET_L2_GET_NAME(CANBUS_RAW)));
C:\NordicSemi\v1.7.1\zephyr\include\net\net_l2.h:82:32: note: each undeclared identifier is reported only once for each function it appears in
c:\NordicApp\net_sockets_can\src\main.c:87:8: warning: implicit declaration of function 'bind' [-Wimplicit-function-declaration]
   87 |  ret = bind(fd, (struct sockaddr *)&can_addr, sizeof(can_addr));
c:\NordicApp\net_sockets_can\src\main.c:90:9: warning: implicit declaration of function 'close' [-Wimplicit-function-declaration]
   90 |   (void)close(fd);
c:\NordicApp\net_sockets_can\src\main.c:94:8: warning: implicit declaration of function 'setsockopt'; did you mean 'zsock_setsockopt'? [-Wimplicit-function-declaration]
   94 |  (void)setsockopt(fd, SOL_CAN_RAW, CAN_RAW_FILTER, filter,
      |        zsock_setsockopt
../src/main.c: In function 'rx':
c:\NordicApp\net_sockets_can\src\main.c:119:9: warning: implicit declaration of function 'recvfrom' [-Wimplicit-function-declaration]
  119 |   ret = recvfrom(fd, &frame, sizeof(struct can_frame),
../src/main.c: In function 'setup_socket':
c:\NordicApp\net_sockets_can\src\main.c:173:36: note: in expansion of macro 'NET_L2_GET_NAME'
  173 |  iface = net_if_get_first_by_type(&NET_L2_GET_NAME(CANBUS_RAW));
[105/190] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[106/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[107/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[108/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[109/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[110/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[111/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[112/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[113/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
FATAL ERROR: command exited with status 1: 'c:\NordicSemi\v1.7.1\toolchain\opt\bin\cmake.EXE' --build 'c:\NordicApp\net_sockets_can\build'
The terminal process terminated with exit code: 1.
Terminal will be reused by tasks, press any key to close it.
terminal build output.
  • With the adjustment abowe it seems that i got one step futher.
    now i´m running into this error:
    mcp2515_can: Device did not reset into configuration mode [7]
    *** Booting Zephyr OS build v2.6.99-ncs1-1  ***
    Flash regions           Domain          Permissions
    00 01 0x00000 0x10000   Secure          rwxl
    02 31 0x10000 0x100000  Non-Secure      rwxl
    Non-secure callable region 0 placed in flash region 1 with size 32.
    SRAM region             Domain          Permissions
    00 07 0x00000 0x10000   Secure          rwxl
    08 31 0x10000 0x40000   Non-Secure      rwxl
    Peripheral              Domain          Status
    00 NRF_P0               Non-Secure      OK
    01 NRF_CLOCK            Non-Secure      OK
    02 NRF_RTC0             Non-Secure      OK
    03 NRF_RTC1             Non-Secure      OK
    04 NRF_NVMC             Non-Secure      OK
    05 NRF_UARTE1           Non-Secure      OK
    06 NRF_UARTE2           Secure          SKIP
    07 NRF_TWIM2            Non-Secure      OK
    08 NRF_SPIM3            Non-Secure      OK
    09 NRF_TIMER0           Non-Secure      OK
    10 NRF_TIMER1           Non-Secure      OK
    11 NRF_TIMER2           Non-Secure      OK
    12 NRF_SAADC            Non-Secure      OK
    13 NRF_PWM0             Non-Secure      OK
    14 NRF_PWM1             Non-Secure      OK
    15 NRF_PWM2             Non-Secure      OK
    16 NRF_PWM3             Non-Secure      OK
    17 NRF_WDT              Non-Secure      OK
    18 NRF_IPC              Non-Secure      OK
    19 NRF_VMC              Non-Secure      OK
    20 NRF_FPU              Non-Secure      OK
    21 NRF_EGU1             Non-Secure      OK
    22 NRF_EGU2             Non-Secure      OK
    23 NRF_DPPIC            Non-Secure      OK
    24 NRF_REGULATORS       Non-Secure      OK
    25 NRF_PDM              Non-Secure      OK
    26 NRF_I2S              Non-Secure      OK
    27 NRF_GPIOTE1          Non-Secure      OK
    SPM: NS image at 0x10000
    SPM: NS MSP at 0x200182b8
    SPM: NS reset vector at 0x16565
    SPM: prepare to jump to Non-Secure image.
    [00:00:00.202,178] <dbg> mcp2515_can.socket_can_init: Init socket CAN device 0x26044 (SOCKET_CAN_1) for dev 0x26074 (CAN_3)
    [00:00:00.216,888] <err> mcp2515_can: Device did not reset into configuration mode [7]
    [00:00:00.227,752] <dbg> mcp2515_can.socket_can_iface_init: Init CAN interface 0x200149f8 dev 0x26044
    uart:~$ *** Booting Zephyr OS build v2.6.99-ncs1-1  ***
    [00:00:02.244,689] <err> net_socket_can_sample: Cannot create 1st CAN socket (-106)
    [00:00:02.255,310] <err> net_socket_can_sample: Cannot start CAN application (-106)
  • 7 is strange, as that does not correspond to any of the modes. It seems like it is not reading the register on the mcp2515 correctly, even though it is not detecting an error.
    This may be an issue with how the mcp2515 is setup or wired. Perhaps it is reading the wrong register?
    It seems like it is somewhat able to communicate with the mcp2515, though, it just isn't getting the response it is expecting.
  • I have checked  the SPI bus and the MISO line is not active at any time.
    it seems that the first information sent to the MCP2515 chip is 0xC0.
    i have no clue if that is the correct one.
  • Can you try using a different pin for the miso? P0.17 for example?
