Hi
Im trying to get the mcp2515 candriver example to work https://github.com/nrfconnect/sdk-zephyr/tree/main/samples/net/sockets/can#id3.
i have some error during build.
information bellow.
&spi3 {
status = "okay";
sck-pin = <10>;
mosi-pin = <11>;
miso-pin = <12>;
cs-gpios = <&gpio0 13 GPIO_ACTIVE_LOW>;
mcp2515@0 {
compatible = "microchip,mcp2515";
spi-max-frequency = <1000000>;
/*int-gpios = <31>; /* D2 */
int-gpios = <&gpio0 31 GPIO_ACTIVE_LOW>; /* D2 */
status = "okay";
label = "CAN_3";
reg = <0x0>;
osc-freq = <16000000>;
bus-speed = <125000>;
sjw = <1>;
prop-seg = <2>;
phase-seg1 = <7>;
phase-seg2 = <6>;
#address-cells = <1>;
#size-cells = <0>;
nrf9160dk_nrf9160_ns.overlay
CONFIG_SPI=y CONFIG_I2C=n CONFIG_SENSOR=y CONFIG_CAN=y CONFIG_CAN_INIT_PRIORITY=80 CONFIG_SHELL=y CONFIG_CAN_SHELL=y CONFIG_DEVICE_SHELL=y
prj.conf
cmake_minimum_required(VERSION 3.20.0)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(sockets_can)
target_sources(app PRIVATE src/main.c)
CMakeLists.txt
Building net_sockets_can
west build --build-dir c:\NordicApp\net_sockets_can\build c:\NordicApp\net_sockets_can --pristine --board nrf9160dk_nrf9160_ns -- -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=On -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="c:/NordicApp/net_sockets_can" -DDTC_OVERLAY_FILE:STRING="c:/NordicApp/net_sockets_can/nrf9160dk_nrf9160_ns.overlay" -DCONF_FILE:STRING="c:/NordicApp/net_sockets_can/prj.conf"
Including boilerplate (Zephyr base): C:/NordicSemi/v1.7.1/zephyr/cmake/app/boilerplate.cmake
-- Application: C:/NordicApp/net_sockets_can
-- Zephyr version: 2.6.99 (C:/NordicSemi/v1.7.1/zephyr), build: v2.6.99-ncs1-1
-- Found Python3: C:/NordicSemi/v1.7.1/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Found west (found suitable version "0.11.1", minimum required is "0.7.1")
-- Board: nrf9160dk_nrf9160_ns, Revision: 0.7.0
-- Cache files will be written to: C:/NordicSemi/v1.7.1/zephyr/.cache
-- Found dtc: C:/NordicSemi/v1.7.1/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (c:/NordicSemi/v1.7.1/toolchain/opt)
-- Found BOARD.dts: C:/NordicSemi/v1.7.1/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns.dts
-- Found devicetree overlay: c:/NordicApp/net_sockets_can/nrf9160dk_nrf9160_ns.overlay
-- Generated zephyr.dts: C:/NordicApp/net_sockets_can/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/NordicApp/net_sockets_can/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/NordicApp/net_sockets_can/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/NordicApp/net_sockets_can/build/zephyr/dts.cmake
Parsing C:/NordicSemi/v1.7.1/zephyr/Kconfig
Loaded configuration 'C:/NordicSemi/v1.7.1/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns_defconfig'
Merged configuration 'c:/NordicApp/net_sockets_can/prj.conf'
Configuration saved to 'C:/NordicApp/net_sockets_can/build/zephyr/.config'
Kconfig header saved to 'C:/NordicApp/net_sockets_can/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: C:/NordicSemi/v1.7.1/toolchain/opt/bin/arm-none-eabi-gcc.exe
Changed board to secure nrf9160dk_nrf9160 (NOT NS)
=== child image spm - begin ===
-- Application: C:/NordicSemi/v1.7.1/nrf/samples/spm
-- Board: nrf9160dk_nrf9160, Revision: 0.7.0
-- Found toolchain: gnuarmemb (C:/NordicSemi/v1.7.1/toolchain/opt)
-- Found BOARD.dts: C:/NordicSemi/v1.7.1/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts
-- Found devicetree overlay: C:/NordicSemi/v1.7.1/nrf/samples/spm/nrf9160dk_nrf9160.overlay
-- Generated zephyr.dts: C:/NordicApp/net_sockets_can/build/spm/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/NordicApp/net_sockets_can/build/spm/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/NordicApp/net_sockets_can/build/spm/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/NordicApp/net_sockets_can/build/spm/zephyr/dts.cmake
Loaded configuration 'C:/NordicSemi/v1.7.1/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_defconfig'
Merged configuration 'C:/NordicSemi/v1.7.1/nrf/samples/spm/prj.conf'
Merged configuration 'C:/NordicSemi/v1.7.1/nrf/samples/spm/boards/nrf9160dk_nrf9160.conf'
Merged configuration 'C:/NordicSemi/v1.7.1/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration 'C:/NordicApp/net_sockets_can/build/spm/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/NordicApp/net_sockets_can/build/spm/zephyr/.config'
Kconfig header saved to 'C:/NordicApp/net_sockets_can/build/spm/zephyr/include/generated/autoconf.h'
CMake Warning (dev) at C:\NordicSemi\v1.7.1\nrfxlib\nrf_security\cmake\extensions.cmake:652:
Syntax Warning in cmake code at column 32
Argument not separated from preceding token by whitespace.
C:\NordicSemi\v1.7.1\nrfxlib\nrf_security\CMakeLists.txt:185 (include)
This warning is for project developers. Use -Wno-dev to suppress it.
CMake Warning at C:\NordicSemi\v1.7.1\zephyr\CMakeLists.txt:1612 (message):
-- Configuring done
-- Generating done
-- Build files have been written to: C:/NordicApp/net_sockets_can/build/spm
=== child image spm - end ===
Dropping partition 'nrf_modem_lib_trace' since its size is 0.
-- Configuring done
-- Generating done
[1/190] Creating directories for 'spm_subimage'
[2/190] No download step for 'spm_subimage'
[3/190] No update step for 'spm_subimage'
[4/190] No patch step for 'spm_subimage'
[5/190] No configure step for 'spm_subimage'
[5/190] Performing build step for 'spm_subimage'
[1/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/aesni.c.obj
[2/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/arc4.c.obj
[3/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/aria.c.obj
[4/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/camellia.c.obj
[5/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/base64.c.obj
[6/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/asn1parse.c.obj
[7/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/asn1write.c.obj
[8/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/blowfish.c.obj
[9/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/debug.c.obj
[10/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/des.c.obj
[11/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/ctr_drbg.c.obj
[12/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/cipher_wrap.c.obj
[13/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/error.c.obj
[14/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/cipher.c.obj
[15/214] Generating objects/cc3xx.mon
[16/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/entropy.c.obj
[17/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/havege.c.obj
[18/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/entropy_poll.c.obj
[19/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/hkdf.c.obj
[20/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/gcm.c.obj
[21/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/hmac_drbg.c.obj
[22/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/bignum.c.obj
[23/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/nist_kw.c.obj
[24/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/md2.c.obj
[25/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/md.c.obj
[26/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/md4.c.obj
[27/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/pkcs12.c.obj
[28/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/md5.c.obj
[29/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/pk.c.obj
[30/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/pk_wrap.c.obj
[31/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/padlock.c.obj
[32/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/ripemd160.c.obj
[33/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/pkparse.c.obj
[34/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/oid.c.obj
[35/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/pkwrite.c.obj
[36/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/platform.c.obj
[37/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/timing.c.obj
[38/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/platform_util.c.obj
[39/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/version.c.obj
[40/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/xtea.c.obj
[41/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/pkcs5.c.obj
[42/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/psa_crypto.c.obj
[43/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/psa_crypto_ecp.c.obj
[44/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/version_features.c.obj
[45/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/psa_crypto_storage.c.obj
[46/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/psa_crypto_slot_management.c.obj
[47/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/psa_crypto_rsa.c.obj
[48/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/psa_crypto_client.c.obj
[49/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.7.1/mbedtls/library/psa_crypto_driver_wrappers.c.obj
[50/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/replacements/pem.c.obj
[51/214] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/shared/CMakeFiles/mbedcrypto_shared.dir/C_/NordicSemi/v1.7.1/mbedtls/library/sha512.c.obj
[52/214] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[53/214] Generating include/generated/driver-validation.h
[54/214] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[55/214] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a
[56/214] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[57/214] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[58/214] Generating include/generated/offsets.h
[59/214] Generating linker_zephyr_prebuilt.cmd
[60/214] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[61/214] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[62/214] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[63/214] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[64/214] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[65/214] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[66/214] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[67/214] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[68/214] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[69/214] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[70/214] Building C object zephyr/CMakeFiles/zephyr.dir/C_/NordicSemi/v1.7.1/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
[71/214] Linking C static library zephyr\arch\common\libisr_tables.a
[72/214] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[73/214] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[74/214] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[75/214] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[76/214] Linking C static library zephyr\arch\common\libarch__common.a
[77/214] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[78/214] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[79/214] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[80/214] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[81/214] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[82/214] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[83/214] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[84/214] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[85/214] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/tz/CMakeFiles/arch__arm__core__aarch32__cortex_m__tz.dir/arm_core_tz.c.obj
[86/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[87/214] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[88/214] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[89/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[90/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[91/214] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[92/214] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\tz\libarch__arm__core__aarch32__cortex_m__tz.a
[93/214] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
[94/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[95/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[96/214] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
[97/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[98/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[99/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[100/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[101/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[102/214] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[103/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[104/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[105/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[106/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[107/214] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[108/214] Building C object CMakeFiles/app.dir/src/main.c.obj
[109/214] Building C object zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj
[110/214] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[111/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[112/214] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
[113/214] Linking C static library app\libapp.a
[114/214] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
[115/214] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
[116/214] Building C object zephyr/boards/boards/arm/nrf9160dk_nrf9160/CMakeFiles/boards__arm__nrf9160dk_nrf9160.dir/nrf52840_reset.c.obj
[117/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[118/214] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
[119/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[120/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[121/214] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[122/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[123/214] Linking C static library zephyr\subsys\random\libsubsys__random.a
[124/214] Linking C static library zephyr\boards\boards\arm\nrf9160dk_nrf9160\libboards__arm__nrf9160dk_nrf9160.a
[125/214] Linking C static library zephyr\lib\posix\liblib__posix.a
[126/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[127/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[128/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[129/214] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/sys_clock_init.c.obj
[130/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[131/214] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/console/uart_console.c.obj
[132/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[133/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[134/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[135/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[136/214] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/clock_control/clock_control_nrf.c.obj
[137/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[138/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[139/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[140/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[141/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[142/214] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[143/214] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[144/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[145/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[146/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[147/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[148/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[149/214] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
[150/214] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj
[151/214] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
[152/214] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[153/214] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/power.c.obj
[154/214] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm_ctrl.c.obj
[155/214] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[156/214] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy/policy_residency.c.obj
[157/214] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[158/214] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/power.c.obj
[159/214] Building C object zephyr/CMakeFiles/zephyr.dir/C_/NordicSemi/v1.7.1/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[160/214] Building C object zephyr/CMakeFiles/zephyr.dir/C_/NordicSemi/v1.7.1/nrf/subsys/spm/spm.c.obj
[161/214] Building C object zephyr/CMakeFiles/zephyr.dir/C_/NordicSemi/v1.7.1/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[162/214] Building C object zephyr/CMakeFiles/zephyr.dir/C_/NordicSemi/v1.7.1/nrf/subsys/spm/secure_services.c.obj
[163/214] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
[164/214] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/nrf_rtc_timer.c.obj
[165/214] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/C_/NordicSemi/v1.7.1/nrf/drivers/entropy/entropy_cc310.c.obj
[166/214] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[167/214] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
[168/214] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
[169/214] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[170/214] Linking C static library zephyr\drivers\entropy\libdrivers__entropy.a
[171/214] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[172/214] Linking C static library modules\nrf\subsys\fw_info\lib..__nrf__subsys__fw_info.a
[173/214] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
[174/214] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
[175/214] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[176/214] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[177/214] Linking C static library zephyr\libzephyr.a
[178/214] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[179/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[180/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[181/214] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_uarte.c.obj
[182/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[183/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[184/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[185/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[186/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
[187/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[188/214] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[189/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[190/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
[191/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
[192/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[193/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
[194/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
[195/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[196/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
[197/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
[198/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
[199/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
[200/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[201/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[202/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
[203/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[204/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
[205/214] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
[206/214] Linking C static library zephyr\kernel\libkernel.a
[207/214] Linking C executable zephyr\zephyr_prebuilt.elf
[208/214] Generating linker.cmd
[209/214] Generating isr_tables.c, isrList.bin
[210/214] Generating dev_handles.c
[211/214] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
[212/214] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
[213/214] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
[214/214] Linking C executable zephyr\zephyr.elf
Memory region Used Size Region Size %age Used
FLASH: 64 KB 64 KB 100.00%
SRAM: 11808 B 64 KB 18.02%
IDT_LIST: 0 GB 2 KB 0.00%
[9/190] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[11/190] No install step for 'spm_subimage'
[12/190] Completed 'spm_subimage'
[13/190] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[14/190] Generating include/generated/offsets.h
[15/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[16/190] Generating linker_zephyr_prebuilt.cmd
[17/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[18/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[19/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[20/190] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[21/190] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[22/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[23/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[24/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[25/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[26/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[27/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[28/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[29/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[30/190] Linking C static library zephyr\arch\common\libisr_tables.a
[31/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[32/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[33/190] Linking C static library zephyr\arch\common\libarch__common.a
[34/190] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[35/190] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[36/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[37/190] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[38/190] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[39/190] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[40/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[41/190] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[42/190] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[43/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[44/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[45/190] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[46/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[47/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[48/190] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
[49/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[50/190] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[51/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[52/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[53/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[54/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[55/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[56/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[57/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[58/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[59/190] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[60/190] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[61/190] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
[62/190] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
[63/190] Building C object zephyr/boards/arm/nrf9160dk_nrf9160/CMakeFiles/boards__arm__nrf9160dk_nrf9160.dir/nrf52840_reset.c.obj
[64/190] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
[65/190] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
[66/190] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
[67/190] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[68/190] Linking C static library zephyr\lib\posix\liblib__posix.a
[69/190] Linking C static library zephyr\boards\arm\nrf9160dk_nrf9160\libboards__arm__nrf9160dk_nrf9160.a
[70/190] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/C_/NordicSemi/v1.7.1/nrf/drivers/entropy/entropy_cc310.c.obj
[71/190] Linking C static library zephyr\subsys\random\libsubsys__random.a
[72/190] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/shmem_sanity.c.obj
[73/190] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
[74/190] Linking C static library zephyr\drivers\entropy\libdrivers__entropy.a
[75/190] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj
[76/190] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
[77/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
[78/190] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_lib.c.obj
[79/190] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[80/190] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[81/190] Linking C static library zephyr\drivers\spi\libdrivers__spi.a
[82/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[83/190] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_os.c.obj
[84/190] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
[85/190] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
[86/190] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[87/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_ipc.c.obj
[88/190] Linking C static library modules\nrf\lib\nrf_modem_lib\lib..__nrf__lib__nrf_modem_lib.a
[89/190] Linking C static library modules\nrf\subsys\fw_info\lib..__nrf__subsys__fw_info.a
[90/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[91/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[92/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[93/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
[94/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[95/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[96/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[97/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[98/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[99/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[100/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_spim.c.obj
[101/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
[102/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[103/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[104/190] Building C object CMakeFiles/app.dir/src/main.c.obj
FAILED: CMakeFiles/app.dir/src/main.c.obj
C:\NordicSemi\v1.7.1\toolchain\opt\bin\arm-none-eabi-gcc.exe -DBUILD_VERSION=v2.6.99-ncs1-1 -DEXT_API_MAGIC=0x281ee6de,0xb845acea,23298 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,23298 -DKERNEL -DNRF9160_XXAA -DNRF_TRUSTZONE_NONSECURE -DUSE_PARTITION_MANAGER=1 -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/NordicSemi/v1.7.1/zephyr/include -Izephyr/include/generated -IC:/NordicSemi/v1.7.1/zephyr/soc/arm/nordic_nrf/nrf91 -IC:/NordicSemi/v1.7.1/zephyr/lib/util/fnmatch/. -IC:/NordicSemi/v1.7.1/nrf/include -IC:/NordicSemi/v1.7.1/modules/hal/cmsis/CMSIS/Core/Include -IC:/NordicSemi/v1.7.1/modules/hal/nordic/nrfx -IC:/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/drivers/include -IC:/NordicSemi/v1.7.1/modules/hal/nordic/nrfx/mdk -IC:/NordicSemi/v1.7.1/zephyr/modules/hal_nordic/nrfx/. -IC:/NordicSemi/v1.7.1/nrfxlib/nrf_modem/include -isystem C:/NordicSemi/v1.7.1/zephyr/lib/libc/minimal/include -isystem c:/nordicsemi/v1.7.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/include -isystem c:/nordicsemi/v1.7.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/include-fixed -Os -imacros C:/NordicApp/net_sockets_can/build/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -imacros C:/NordicSemi/v1.7.1/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-address-of-packed-member -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=C:/NordicApp/net_sockets_can=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/NordicSemi/v1.7.1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/NordicSemi/v1.7.1=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir/src/main.c.obj -MF CMakeFiles\app.dir\src\main.c.obj.d -o CMakeFiles/app.dir/src/main.c.obj -c ../src/main.c
../src/main.c: In function 'tx':
c:\NordicApp\net_sockets_can\src\main.c:63:9: warning: implicit declaration of function 'send' [-Wimplicit-function-declaration]
63 | ret = send(fd, &frame, sizeof(frame), 0);
../src/main.c: In function 'create_socket':
c:\NordicApp\net_sockets_can\src\main.c:77:7: warning: implicit declaration of function 'socket' [-Wimplicit-function-declaration]
77 | fd = socket(AF_CAN, SOCK_RAW, CAN_RAW);
In file included from C:\NordicSemi\v1.7.1\zephyr\include\net\net_if.h:29,
from C:\NordicSemi\v1.7.1\zephyr\include\net\net_context.h:28,
from C:\NordicSemi\v1.7.1\zephyr\include\net\dns_resolve.h:17,
from C:\NordicSemi\v1.7.1\zephyr\include\net\socket.h:28,
from c:\NordicApp\net_sockets_can\src\main.c:12:
C:\NordicSemi\v1.7.1\zephyr\include\net\net_l2.h:82:32: error: '_net_l2_CANBUS_RAW' undeclared (first use in this function)
82 | #define NET_L2_GET_NAME(_name) _net_l2_##_name
c:\NordicApp\net_sockets_can\src\main.c:84:29: note: in expansion of macro 'NET_L2_GET_NAME'
84 | net_if_get_first_by_type(&NET_L2_GET_NAME(CANBUS_RAW)));
C:\NordicSemi\v1.7.1\zephyr\include\net\net_l2.h:82:32: note: each undeclared identifier is reported only once for each function it appears in
c:\NordicApp\net_sockets_can\src\main.c:87:8: warning: implicit declaration of function 'bind' [-Wimplicit-function-declaration]
87 | ret = bind(fd, (struct sockaddr *)&can_addr, sizeof(can_addr));
c:\NordicApp\net_sockets_can\src\main.c:90:9: warning: implicit declaration of function 'close' [-Wimplicit-function-declaration]
90 | (void)close(fd);
c:\NordicApp\net_sockets_can\src\main.c:94:8: warning: implicit declaration of function 'setsockopt'; did you mean 'zsock_setsockopt'? [-Wimplicit-function-declaration]
94 | (void)setsockopt(fd, SOL_CAN_RAW, CAN_RAW_FILTER, filter,
| zsock_setsockopt
../src/main.c: In function 'rx':
c:\NordicApp\net_sockets_can\src\main.c:119:9: warning: implicit declaration of function 'recvfrom' [-Wimplicit-function-declaration]
119 | ret = recvfrom(fd, &frame, sizeof(struct can_frame),
../src/main.c: In function 'setup_socket':
c:\NordicApp\net_sockets_can\src\main.c:173:36: note: in expansion of macro 'NET_L2_GET_NAME'
173 | iface = net_if_get_first_by_type(&NET_L2_GET_NAME(CANBUS_RAW));
[105/190] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[106/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[107/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[108/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[109/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[110/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[111/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[112/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[113/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
FATAL ERROR: command exited with status 1: 'c:\NordicSemi\v1.7.1\toolchain\opt\bin\cmake.EXE' --build 'c:\NordicApp\net_sockets_can\build'
The terminal process terminated with exit code: 1.
Terminal will be reused by tasks, press any key to close it.terminal build output.
