I made a code on NCS1.5.0. The main function is to realize audio encoding and decoding. It runs and tests normally on nRF5340 DK. When I migrated this code to NCS1.7.1, a compilation error occurred. I checked it was a compilation error caused by a configuration item "CONFIG_DEPRECATED_ZEPHYR_INT_TYPES=y" in the prj.conf file. When I commented out this configuration item, the compilation was successful, but the test on the nRF5340 DK found that the audio encoding and decoding functions were abnormal, and the sound could not be restored.
I checked the zephyr documentation, this configuration item "CONFIG_DEPRECATED_ZEPHYR_INT_TYPES" was used in Zephyr 2.4.0, but it was abandoned after Zephyr 2.6.0. From the documentation, I understand that this configuration item is related to the data type used in the code. I don't want to modify the original code too much. It is ideal if the problem can be solved by adding or modifying configuration items. Do you have any good ideas or suggestions? Thanks!
Devin
