How to program PCA10028 by drag and drop
I want to use the Segger drag and drop programming feature on the PCA10028. I have got a running application with the S120 softdevice. To use the mass storage drag and drop feature of the PCA10028, I merged my application .hex file and the sofdevice .hex file into one complete.hex file with the nordic mergehex.exe tool.
When I drop the new app.hex file to the mass storage device, It seems that nRF51422 chip gets reprogrammed, but the application doesn`t start execution.
Is there any thing wrong in my workflow?
Regards, BTprogrammer
  • What is the role of your application? if you program softdevice and application separately with nrfjprog does your application work? Are you able to debug your application, if yes, then find out where it fails.
  • Good morning,
    What do you mean with "role"? The BLE role? My application runs as an peripheral.
    Yes, If the softdevice and my application .hex files are programmed separately with nrfjprog, it works. I used the following commands:
    1. nrfjprog.exe --program s120_softdevice.hex --chiperase
    2. nrfjprog.exe --program application.hex
    3. nrfjprog.exe --run
    But if I use the mass storage drag and drop feature, it seems as the device doesnt even start running. So I dont know how to debug the application when using the drag and drop feature.
  • Could you post the exact cmd you used for mergehex?
  • Hello again,
    I think I found my mistake. It seems that the order of how to merge the .hex files assumes a role:
    mergehex.exe -m application.hex s120_softdevice.hex -o complete.hex --> works fine with drag and drop feature
    mergehex.exe -m s120_softdevice.hex application.hex -o complete.hex --> doesn`t work with drag and drop feature
    Now I`m able to use the drag and drop feature. Thanks for support.
  • Seems like you have an overlapping addresses in the S120_softdevice.hex and application.hex. Is your application writing to UICR? It should not matter with the order of the hex while merging unless there is some conflict.
