I have the same problem as this topic: https://devzone.nordicsemi.com/f/nordic-q-a/77267/nrf9160-azure-iot-hub-on-thingy91-mqtt-connect-error
I'm using nrf Connect v3.7.1, LTE link monitor v1.1.10. I made the last firmware update 2021-10-20. Sample in the ncs v1.7.1.
Maybe I forgot a step?
Here are the steps I did:
- prj.conf : add the CONFIG_AZURE_IOT_HUB_DEVICE_ID & CONFIG_AZURE_IOT_HUB_HOSTNAME & CONFIG_AZURE_IOT_HUB_DPS=y & CONFIG_AZURE_IOT_HUB_DPS_ID_SCOPE
- certificates.h: change name file and add the ca cert, client key and cert. I add it also with LTE link monitor to be sure.
If you have any useful tips or information, thank you in advance for your help!
Voici mes logs et traces :
