nrf5340DK program another nrf5340DK
I have a custom board based on the nrf5340 which I would like to program using one of my nrf5340DK boards.
As a starting point to test the external board programming workflow, I'm trying to program one nrf5340DK from a second nrf5340DK.
Configuration is:
Both boards are revision 0.11.0
Board 1: connected to Mac running VS Code (and am able to program this board standalone OK), P19 (Debug Out) connected via 1-1 ribbon cable to P18 (Debug In) of board 2.
Board 2: powered via USB from a different computer. P18 (Debug In) connected to P19 (Debug Out) of board 1. Have verified that 3V is present on P18 pin 1.
Attempting to program the above setup results in error messages:
ERROR: Unable to connect to a debugger.
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 33: nrfjprog --program /Users/skajam66/Projects/Nordic/peripheral_lbs/build/zephyr/GENERATED_CP_NETWORK_merged_domains.hex --sectorerase -f NRF53 --snr 960114329 --coprocessor CP_NETWORK
Is what I'm doing supposed to work? If yes, any suggestions are appreciated.
skajam66
  • I don't see any obvious reason this shouldn't work, but a few things to try:
    Make sure to install latest nRF Command line tools: https://www.nordicsemi.com/Products/Development-tools/nRF-Command-Line-Tools/Download
    Run the following commands should erase both cores of the target board:
    nrfjprog --recover --coprocessor CP_NETWORK
    nrfjprog --recover
    If still no luck, what is the versions printed on the nRF5340-DK's? Instead of connecting board2 to USB in a second PC, can you try connecting VDD(~3V) from  board1 to the external supply header of board2.
    Kenneth
  • Thanks Kenneth.
    I won't be in the workshop until Friday. I will try your suggestions then.
    skj
  • Hi Kenneth,
    I followed your instructions but no success:
    Step 1: Programmed board1 with a sample bluetooth application. Verified that it was working via LightBlue
    Step 2: Erased board 1 using commands below and verified that board1 was erased
    nrfjprog --recover
    Step 3: Connected board1 to board2. Powered board2 from VDD on board1. - LED4 lit up. Ribbon cable between board1 P19 and board2 P18
    Step 4: Attempted to erase board2 using above commands. Failed. Log file attached
    [2021-Nov-20 11:46:23] [ info] --------------------------------------------------------------------------------
    [2021-Nov-20 11:46:23] [ info] nrfjprog --recover --coprocessor CP_NETWORK --log
    [2021-Nov-20 11:46:23] [ info] nrfjprog version 10.15.0 external
    [2021-Nov-20 11:46:23] [ info] Load library at /Applications/Nordic Semiconductor/lib/libnrfjprogdll.dylib.
    [2021-Nov-20 11:46:23] [ info] Library loaded, loading member functions.
    [2021-Nov-20 11:46:23] [ info] Member functions succesfully loaded.
    [2021-Nov-20 11:46:23] [debug] [ Client] - open
    [2021-Nov-20 11:46:23] [debug] [ Client] - start
    [2021-Nov-20 11:46:23] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence c73295c4-29b4-4e02-89ae-ed0938b058b8.
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2021-Nov-20 11:46:23] [debug] [  JLink] - Logger sink registered in JLink logger
    [2021-Nov-20 11:46:23] [debug] [  nRFXX] - open
    [2021-Nov-20 11:46:23] [debug] [  nRFXX] - just_check_family
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - open_dll
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2021-Nov-20 11:46:23] [ info] [SeggerBackend] - Load library at /Applications/SEGGER/JLink/libjlinkarm.dylib.
    [2021-Nov-20 11:46:23] [trace] [ Client] - Command open executed for 28 milliseconds with result 0
    [2021-Nov-20 11:46:23] [debug] [ Client] - enum_emu_snr
    [2021-Nov-20 11:46:23] [trace] [ Client] - Command enum_emu_con_info executed for 0 milliseconds with result 0
    [2021-Nov-20 11:46:23] [debug] [ Client] - connect_to_emu_with_snr
    [2021-Nov-20 11:46:23] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2021-Nov-20 11:46:23] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - dll_version
    [2021-Nov-20 11:46:23] [ info] [SeggerBackend] - Segger dll version 7.56.a loaded.
    [2021-Nov-20 11:46:23] [trace] [ Worker] - Command open executed for 20 milliseconds with result 0
    [2021-Nov-20 11:46:23] [debug] [  nRFXX] - enum_emu_con_info
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - is_connected_to_emu
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - enum_emu_con_info
    [2021-Nov-20 11:46:23] [trace] [ Worker] - Command enum_emu_con_info executed for 0 milliseconds with result 0
    [2021-Nov-20 11:46:23] [debug] [  nRFXX] - connect_to_emu_with_snr
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - ---just_get_num_emus
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - Segger logging enabled.
    [2021-Nov-20 11:46:23] [trace] [  JLink] - Firmware: J-Link OB-K22-NordicSemi compiled Jul  2 2021 10:44:28
    [2021-Nov-20 11:46:23] [trace] [  JLink] - Hardware: V1.00
    [2021-Nov-20 11:46:23] [trace] [  JLink] - S/N: 960114329
    [2021-Nov-20 11:46:23] [trace] [  JLink] - OEM: SEGGER
    [2021-Nov-20 11:46:23] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    [2021-Nov-20 11:46:23] [trace] [  JLink] - TELNET listener socket opened on port 19021
    [2021-Nov-20 11:46:23] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [2021-Nov-20 11:46:23] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 25.666ms returns "O.K."
    [2021-Nov-20 11:46:23] [trace] [  JLink] - JLINK_HasError()
    [2021-Nov-20 11:46:23] [trace] [  JLink] - JLINK_Lock()
    [2021-Nov-20 11:46:23] [trace] [  JLink] - JLINK_GetHWStatus(...)
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.255ms returns 0
    [2021-Nov-20 11:46:23] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.029ms returns 0x01
    [2021-Nov-20 11:46:23] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.046ms returns 0x00
    [2021-Nov-20 11:46:23] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.030ms returns 0x00
    [2021-Nov-20 11:46:23] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
    [2021-Nov-20 11:46:23] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.014ms returns 0
    [2021-Nov-20 11:46:23] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.907ms returns 0x00
    [2021-Nov-20 11:46:23] [trace] [  JLink] - JLINK_SetSpeed(2000)
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.135ms
    [2021-Nov-20 11:46:23] [trace] [  JLink] - JLINK_GetSN()
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.003ms returns 960114329
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - read_debug_port_idr
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - read_debug_port_register
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - coresight_configure
    [2021-Nov-20 11:46:23] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 100.327ms returns 0
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2021-Nov-20 11:46:23] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.631ms returns -1
    [2021-Nov-20 11:46:23] [error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - ---just_abort_debug_action
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
    [2021-Nov-20 11:46:23] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.540ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.562ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.554ms returns -1
    [2021-Nov-20 11:46:23] [trace] [ Client] - Command connect_to_emu_with_snr executed for 172 milliseconds with result -102
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.588ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.563ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.556ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.550ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.558ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.573ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.544ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.523ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.549ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.561ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.533ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.551ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.541ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.612ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.580ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.520ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.535ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.018ms
    [2021-Nov-20 11:46:23] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 172 milliseconds with result -102
    [2021-Nov-20 11:46:23] [debug] [  nRFXX] - close
    [2021-Nov-20 11:46:23] [trace] [  JLink] - JLINK_IsOpen()
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.006ms returns 0x01
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - close
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - disconnect_from_emu
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - is_connected_to_device
    [2021-Nov-20 11:46:23] [trace] [  JLink] - JLINK_IsConnected()
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.003ms returns FALSE
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.572ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.614ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.555ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.536ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.553ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.575ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.512ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.574ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.513ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.559ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.530ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.557ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.569ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.560ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.515ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.517ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.531ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.532ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.628ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.568ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.524ms returns -1
    [2021-Nov-20 11:46:23] [trace] [  JLink] - - 0.016ms
    [2021-Nov-20 11:46:23] [trace] [  JLink] - JLINK_Close()
    [2021-Nov-20 11:46:23] [debug] [SeggerBackend] - Segger Backend closed.
    [2021-Nov-20 11:46:23] [debug] [  nRFXX] - nRF family DLL closed
    [2021-Nov-20 11:46:23] [trace] [ Client] - Command close executed for 53 milliseconds with result 0
    [2021-Nov-20 11:46:23] [debug] [ Client] - terminate
    [2021-Nov-20 11:46:23] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
    [2021-Nov-20 11:46:23] [trace] [ Worker] - Command close executed for 53 milliseconds with result 0
    [2021-Nov-20 11:46:23] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
    [2021-Nov-20 11:46:23] [trace] [ Worker] - Executed 5 commands for 245 milliseconds
    [2021-Nov-20 11:46:23] [debug] [ Client] - Worker process exited with code: 0
    [2021-Nov-20 11:46:23] [debug] [ Client] - Tried to wait on already ended process: wait error: No child processes
    [2021-Nov-20 11:46:23] [debug] [ Client] - Child process terminated with result 0
    [2021-Nov-20 11:46:23] [trace] [ Client] - Executed 5 commands for 253 milliseconds
    AC
    Sometimes a picture can say more than a thousand words, but can you provide the version number of the nRF5340-DK's you are using?
    Kenneth
  • Apologies, both boards are version 0.11.0
    Kind regards...
