USB DFU on a NRF52833
I am trying to implement USB DFU on a NRF52833 with nRF5 SDK for Thread and Zigbee v4.1.0 and nRF5 SDK v16.0.0.
  •  In a first step I want to perform this on the devkit.
  •  In a second step on our custom PCB.
Unfortunatelly there is no NRF52833 USB bootloader example. So i performed this on a NRF52840 (pca10056).
1. What I managed to do is flashing the "pca10056_usb_debug" via the first USB port and then connecting to the other USB port. Then I performed
nrfutil dfu usb-serial -pkg blinky_mbr.zip -p COM16
which was also successful judging by the LEDs. Now I want to create an own .zip (infocenter.nordicsemi.com/index.jsp and this is where I have problems. Public and private keys are provided but when I run
nrfutil pkg generate --hw-version 52 --application out.hex --key-file priv.pem package.zip
I get the error message
Usage: nrfutil pkg generate [OPTIONS] ZIPFILE
Try 'nrfutil pkg generate --help' for help.
Error: --sd-req required.
Which means I have to specify a soft device version. I am confused about this because I though soft devices can be used but are not required since this is neither an BLE nor an ANT project.
How do I know which version I have to pass to create the .zip?
    Try to enable single-bank updates by setting NRF_DFU_SINGLE_BANK_APP_UPDATES to 1.
    Marte
    thanks for your quick reply. I get the same error message.
    I see that you have made changes to the memory layout in section placement macros. FLASH_START is the start address of the program, so in the bootloader project, secure_bootloader_usb_mbr_pca10100e, this will be the start address of the bootloader. This should be 0x78000, but you have set this to 0x24000, which is too low.
    If you look at the memory layout I linked to in one of my previous replies, you will see that for nRF52833 you have the following:
    Usage Memory range nRF52833 (S113 v7.0.x) Memory range nRF52833 (S140 v7.0.x)
    Bootloader settings 0x0007 F000 - 0x0008 0000 (4 kB) 0x0007 F000 - 0x0008 0000 (4 kB)
    MBR parameter storage 0x0007 E000 - 0x0007 F000 (4 kB) 0x0007 E000 - 0x0007 F000 (4 kB)
    Bootloader 0x0007 8000 - 0x0007 E000 (24 kB) 0x0007 8000 - 0x0007 E000 (24 kB)
    Application area (incl. free space) 0x0001 C000 - 0x0007 8000 (368 kB) 0x0002 6000 - 0x0007 8000 (328 kB)
    SoftDevice 0x0000 1000 - 0x0001 C000 (112 kB) 0x0000 1000 - 0x0002 6000 (148 kB)
    Master Boot Record (MBR) 0x0000 0000 - 0x0000 1000 (4 kB) 0x0000 0000 - 0x0000 1000 (4 kB)
    This is with SoftDevice, but even without SoftDevice and MBR the application area is 0x0 to 0x78000. You can also see this in the section placement macros in your application, where FLASH_START is 0x0 and FLASH_SIZE is 0x7e000. Right now you are programming the bootloader at 0x24000 - 0x36000, and then you try to perform DFU with an application that should be located in the area 0x0 - 0x78000, but part of this is already taken by the bootloader. The size of bootloader flash, 0x12000, is also larger than it needs to be. As you can see in the the memory layout, you only need 0x6000.
    Marte
    thank you for the info. I adjusted the values but get an error:
    <!DOCTYPE Linker_Placement_File>
    <Root name="Flash Section Placement">
      <MemorySegment name="FLASH1" start="$(FLASH_PH_START)" size="$(FLASH_PH_SIZE)">
        <ProgramSection load="no" name=".reserved_flash" start="$(FLASH_PH_START)" size="$(FLASH_START)-$(FLASH_PH_START)" />
        <ProgramSection alignment="0x100" load="Yes" name=".vectors" start="$(FLASH_START)" />
        <ProgramSection alignment="4" load="Yes" name=".init" />
        <ProgramSection alignment="4" load="Yes" name=".init_rodata" />
        <ProgramSection alignment="4" load="Yes" name=".text" size="0x4" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".crypto_data" inputsections="*(SORT(.crypto_data*))" address_symbol="__start_crypto_data" end_symbol="__stop_crypto_data" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".dfu_trans" inputsections="*(SORT(.dfu_trans*))" address_symbol="__start_dfu_trans" end_symbol="__stop_dfu_trans" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".nrf_queue" inputsections="*(.nrf_queue*)" address_symbol="__start_nrf_queue" end_symbol="__stop_nrf_queue" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_const_data" inputsections="*(SORT(.log_const_data*))" address_symbol="__start_log_const_data" end_symbol="__stop_log_const_data" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".nrf_balloc" inputsections="*(.nrf_balloc*)" address_symbol="__start_nrf_balloc" end_symbol="__stop_nrf_balloc" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_backends" inputsections="*(SORT(.log_backends*))" address_symbol="__start_log_backends" end_symbol="__stop_log_backends" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections" address_symbol="__start_nrf_sections" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".fs_data"  inputsections="*(.fs_data*)" runin=".fs_data_run"/>
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_dynamic_data"  inputsections="*(SORT(.log_dynamic_data*))" runin=".log_dynamic_data_run"/>
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_filter_data"  inputsections="*(SORT(.log_filter_data*))" runin=".log_filter_data_run"/>
        <ProgramSection alignment="4" load="Yes" name=".dtors" />
        <ProgramSection alignment="4" load="Yes" name=".ctors" />
        <ProgramSection alignment="4" load="Yes" name=".rodata" size="0x4" />
        <ProgramSection alignment="4" load="Yes" name=".ARM.exidx" address_symbol="__exidx_start" end_symbol="__exidx_end" />
        <ProgramSection alignment="4" load="Yes" runin=".fast_run" name=".fast" />
        <ProgramSection alignment="4" load="Yes" runin=".data_run" name=".data" />
        <ProgramSection alignment="4" load="Yes" runin=".tdata_run" name=".tdata" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".mbr_params_page" address_symbol="__start_mbr_params_page" end_symbol="__stop_mbr_params_page" start = "0x000FE000" size="0x1000" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".bootloader_settings_page" address_symbol="__start_bootloader_settings_page" end_symbol="__stop_bootloader_settings_page" start = "0x000FF000" size="0x1000" />
      </MemorySegment>
      <MemorySegment name="RAM1" start="$(RAM_PH_START)" size="$(RAM_PH_SIZE)">
        <ProgramSection load="no" name=".reserved_ram" start="$(RAM_PH_START)" size="$(RAM_START)-$(RAM_PH_START)" />
        <ProgramSection alignment="0x100" load="No" name=".vectors_ram" start="$(RAM_START)" address_symbol="__app_ram_start__"/>
        <ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections_run" address_symbol="__start_nrf_sections_run" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".fs_data_run" address_symbol="__start_fs_data" end_symbol="__stop_fs_data" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".log_dynamic_data_run" address_symbol="__start_log_dynamic_data" end_symbol="__stop_log_dynamic_data" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".log_filter_data_run" address_symbol="__start_log_filter_data" end_symbol="__stop_log_filter_data" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections_run_end" address_symbol="__end_nrf_sections_run" />
        <ProgramSection alignment="4" load="No" name=".fast_run" />
        <ProgramSection alignment="4" load="No" name=".data_run" />
        <ProgramSection alignment="4" load="No" name=".tdata_run" />
        <ProgramSection alignment="4" load="No" name=".bss" />
        <ProgramSection alignment="4" load="No" name=".tbss" />
        <ProgramSection alignment="4" load="No" name=".non_init" />
        <ProgramSection alignment="4" size="__HEAPSIZE__" load="No" name=".heap" />
        <ProgramSection alignment="8" size="__STACKSIZE__" load="No" place_from_segment_end="Yes" name=".stack"  address_symbol="__StackLimit" end_symbol="__StackTop"/>
        <ProgramSection alignment="8" size="__STACKSIZE_PROCESS__" load="No" name=".stack_process" />
      </MemorySegment>
      <MemorySegment name="uicr_bootloader_start_address" start="0x10001014" size="0x4">
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".uicr_bootloader_start_address" address_symbol="__start_uicr_bootloader_start_address" end_symbol="__stop_uicr_bootloader_start_address" start = "0x10001014" size="0x4" />
      </MemorySegment>
      <MemorySegment name="uicr_mbr_params_page" start="0x10001018" size="0x4">
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".uicr_mbr_params_page" address_symbol="__start_uicr_mbr_params_page" end_symbol="__stop_uicr_mbr_params_page" start = "0x10001018" size="0x4" />
      </MemorySegment>
    </Root>
    I can make it build with FLASH_START=0x75000 or lower.
    But this way it won't flash:
    For reference I used the nRF52840. According to the documentation the bootloader should start at 0x000F 8000. But in the working example it starts at 0xF4000.
    Nppn7 said:
    For reference I used the nRF52833. According to the documentation the bootloader should start at 0x000F 8000. But in the working example it starts at 0xF4000.
    You are looking at the memory layout for nRF52840. The memory layout in my previous reply is for nRF52833, and is what you should look at. This is the same as the two columns at the right in the picture you posted. You see there that the bootloader starts at 0x78000, and not 0xF8000, which is outside of range for the nRF52833, as it has a flash size of 512 kB, so it only goes up to 0x80000.
    Pca10010 projects with an e at the end (pca10010e) are nRF52820 projects, so secure_bootloader_usb_mbr_pca10010e is a nRF52820 project, and not nRF52833, which is why the flash and RAM settings do not correspond with the memory layout for nRF52833. The project is still configured as a nRF52820 project, which is causing you to get the errors you get. If you want to transfer this project to nRF52833 you can look at the guide Transferring the project to nRF52820 hardware, and reverse the steps there to transfer the project from nRF52820 to nRF52833, instead of from nRF52833 to nRF52820.
    Marte
