Set MTU size in Zephyr
I ran the throughput example ,but I found that setting the MTU size actually requires calling the bt_gatt_exchange_mtu function, which is different from sdk16.0 .
In sdk16.0 or other versions, I can set the MTU size by calling nrf_ble_gatt_att_mtu_periph_set()  and nrf_ble_gatt_att_mtu_central_set() .
Is there any way to automatically set the MTU size in Zephyr?
Best Regards,
Gray
  • What do you mean by automatically?
  • Hello, haakonsh
    Sorry, my description is not clear enough.
    What I mean is how to set the MTU before the connection, without calling bt_gatt_exchange_mtu() to set it after the connection.
    Best Regards,
    Gray
  • You can't set it before a connection as the MTU exchange is a negotiation between the Central and Peripheral (where the Central ultimately decides what value to use). You'll have to initiate such an exchange for each established connection.
  • Hi,haakonsh
    My doubt is why the Central does not choose to set MTU_SIZE?
    After connecting, I called bt_gatt_get_mtu() and the read size was 23 instead of the set size.
    https://github.com/nrfconnect/sdk-nrf/blob/master/samples/bluetooth/throughput/prj.conf
  • Hey Gray,
    You configs looks good.
    We need more information however. I suggest you start by enabling debug logs for the BT stack and share that. A sniffer trace would also help.
1 2
