Hi
We are using a nrf52840 on a custom board.
The board always worked fine.
Flashing is done with :
- SEGGER J-Link EFM32GG-STK3700
- nrfjprog version: 10.15.0 external
- JLinkARM.dll version: 6.94a
- Platform : Linux
We ported the sensor exemple from nrf5_SDK_for_Mesh_v5.0.0. to our custom board and it worked fine.
Suddenly we were not able to erase/flash any code on it any more.
We discover that the reset pin is always low so it reboot in loop.
After soldering a 100 ohm pull up resistor we are again able to reset the board :
nrfjprog --eraseall
After this we can flash SoftDevice and Application.
Everything is working fine with the resistor.
If we remove the pull-up resistor, as soon as we flash any application, including a simple Arduino blink example, the board is locked again in reset loop.
We must right after the erase of the flash, do a :
nrfjprog --recover -f nrf52
After that the application work only without CONFIG_GPIO_AS_PINRESET but then our reset button isn't working.
After some tests it happen that the bug only affect some boards and not other.
Other boards work fine with CONFIG_GPIO_AS_PINRESET.
Is it possible that the state is not properly reset ?
